LG K8 4G LTE: Connecting Pendrive/External Disk without OTG - Adapter & Alternatives
bigjack12 5523 6
  • #1 16535152
    bigjack12
    Rate: 8
    Hello. I have a LG K8 phone. I recently bought a micro USB-OTG adapter but the adapter does not work because this phone does not support OTG :( . My question is such or something "https://archiwum.allegro.pl/oferta/adapter-otg-nano-lg-k8-4g-lte-stylus-2-spree-i6424251007.html" will do the trick and I can connect pendrive or external disk. If you don't know any other ways to make your pen drive or external drive work without an OTG
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    Since you have written there:
    The adapter will sync with Phone models that have and support OTG functions
    And your phone does not support OTG, how does it work?
  • #3 16535741
    bigjack12
    Rate: 8
    I saw it but I was still hoping that it would work somehow :( . Are there any other methods for me to connect a USB stick to the phone?
    nutergsm
    Help: 1034
    Rate: 1665
    You won't figure anything out. Buy a phone with OTG support.
  • #5 16536147
    bigjack12
    Rate: 8
    The phone suits me, I'm more willing to buy a cheap tablet up to PLN 200. Well, I thought that there would be a solution because I saw on the net that if you root the phone then I could somehow use the otg function but too much of this west :(
    nutergsm
    Help: 1034
    Rate: 1665
    USB OTG is a hardware solution, not a software solution.
  • #7 16563657
    bigjack12
    Rate: 8
    Approx. Thank you all. I'm closing the topic.
The discussion revolves around the LG K8 4G LTE smartphone, specifically the user's inability to connect a USB pendrive or external disk due to the phone's lack of OTG (On-The-Go) support. Despite purchasing a micro USB-OTG adapter, the user finds it ineffective. Responses indicate that OTG functionality is a hardware feature, not software-based, and suggest that rooting the phone may not provide a viable solution. The consensus leans towards recommending the purchase of a device with native OTG support or considering alternative devices like a budget tablet.
