Suzuki Burgman 125: Rear Wheel Noise, Vibrations & Drive Issue - Solutions & Replacement Tips
niikii 12363 5
  • #1 16662354
    niikii
    Rate: 17
    There have been noises at the rear wheel (drive?) For some time. You feel the vibrations while equalizing the speed. Someone will tell you where to look, what to buy and replace? I can handle it, but I don't want to reinvent the wheel and replace half the scooter unnecessarily.
    Video here:
    [movie: 0e5d4d8846] https://filmy.elektroda.pl/84_1503654593.mp4 [/ movie: 0e5d4d8846]
    Staszek49
    Help: 228
    Rate: 1140
    Check the gearbox for proper oil condition. Bearings and sleeve bearings in the gearbox may have worn out. You need to listen to this noise well in order not to actually disassemble the vehicle unnecessarily. Check also how the belt transmission works, i.e. the variator (condition of the rollers and counter-discs) and the clutch (the condition of the spring, friction linings, it is also bearing). That the belt is in good condition and of the correct size.
  • #3 16664069
    niikii
    Rate: 17
    I can actually check the condition of the clutch myself, but what do the remaining elements look like? How do you know the consumption? As far as I know, the entire scooter was prepared for the season (e.g. the drive belt was replaced with a new one). I checked the oil level by unscrewing the oil filter from the housing. I understand that this is the only place where I check the oil level.
    E8600
    Help: 529
    Rate: 2520
    The engine drowns out everything. Bearings to check or socket somewhere broken in the housing.
    [youtube]https://www.youtube.com/watch?v=nPrcv7E7Qw0
    [/youtube]
  • #5 16731713
    niikii
    Rate: 17
    This is how you hear it with the engine off. The wheel has no side play. Knocking to hear only when moving the wheel rapidly back and forth.
    [video: 4a688a8a35] https://filmy.elektroda.pl/93_1506873864.mp4 [/ video: 4a688a8a35]
    E8600
    Help: 529
    Rate: 2520
    This is the tooth play of the gear. In my opinion it is too big, probably the modes are already worked out or someone was driving without oil or on the wrong oil. You have to undress and assess the condition. Excessive load could cause the transmission to wear faster.
