Hdmi Legrand socket - I'm trying to earn an hdmi socket, the tester displays
macoss 9810 7
  • #1 16662718
    macoss
    I am trying to earn a legranda hdmi socket (Catalog number: VALENA-HDMI), I unplugged the hdmi cable and connect it according to the diagram in the manual, after connecting all the wires, the image is not displayed, the Gembird cable tester (NCT-4) displays the error "cross (crossover or cross- talk interference) "and I'm not sure what it means?
  • #2 16662759
    Polon_us
    Help: 1184
    Rate: 1282
    Cross-over means crossed wires.
    For example -
    The wire X is attached to pin 2 plug A, and on plug B to pin3.
    Y - pin 3 cable plug A, pin2 plug B.
    With the help of Google, your friend will find a lot of information on this topic.
    macoss wrote:
    cross-talk interference
    These are interference -> crosstalk - the most common reason is inadequate shielding.
  • #3 16662988
  • #4 16673207
    macoss
    Is there anyone who has managed to earn hdmi on such a socket? I already try the second hdmi cable and each manufacturer uses the colors as they like, which means that reaching the correct solution seems impossible.
    Hdmi Legrand socket - I'm trying to earn an hdmi socket, the tester displays Hdmi Legrand socket - I'm trying to earn an hdmi socket, the tester displays
    attached a picture of the cable and a schematic from Legrand.
    There are 3 to be attached but the colors do not match.
  • #5 16676168
    bogi
    Help: 103
    Rate: 245
    Attach the others freely, but equally at both ends.
  • #6 16680687
    macoss
    there is a male connector on one side and a socket on the other.
    elektryku5
    Help: 460
    Rate: 1055
    macoss wrote:
    each manufacturer uses the colors he likes
    Insert the plug of the processed cable into the same socket and check with an ohmmeter how the colors of the wires are distributed (on one probe, the wire on the other, the terminal in the socket).
  • #8 16684104
    macoss
    Complete success!
The discussion revolves around troubleshooting an HDMI socket (Legrand VALENA-HDMI) that fails to display an image after proper wiring according to the manual. The user encounters a "cross" error on a Gembird cable tester (NCT-4), indicating crossed wires or crosstalk interference, often due to inadequate shielding or poor cable quality. Suggestions include ensuring consistent wiring at both ends and using an ohmmeter to verify wire connections. The user successfully resolves the issue after following the advice.
