mercedes w203 + android station - Selection of an amplifier for the harman kardo
sweet_miru 8685 7
  • #1 16666576
    sweet_miru
    I have a Mercedes W203 with factory Harman Kardon sound system. I installed the radio:
    The problem is the factory fiber optic installation of the original H&K amplifier. I have no sound now, because the factory radio sent a signal via optical fiber to the amplifier in the trunk, where the entire loudspeaker beam is also located.
    I thought to drag the chinche from the radio to the trunk, where the factory speaker system is located, and use an aftermarket amplifier:
    BOSCHMANN Z-8528X
    PLN 429
    It is 5-channel. I would like to power the factory H&K speakers - front door, rear door and a woofer from the shelf.
    Is my way of thinking correct? What do you think about the mentioned amplifier?
    Do you connect additional speakers to the channels? Ie in the board, additional in the shelf? Is it better to leave it alone and connect the front, rear and woofers, as I wrote earlier?
    Maybe there would be a better amplifier in a similar budget?
  • #2 16667224
    ZeeWolf
    H&K + bushman? Man, they will bite you here for such a combination ... :D . Provide the model of your current radio, ideally whether it has coaxial output.
  • #3 16667523
    sweet_miru
    China Radio From Aliexpress:
    2017 HD 1024x600 Quad core Car DVD Player for Mercedes W203 android 7.1 c200 C230 C240 C320 C350 CLK W209 GPS Radio WiFi 3G
    http://s.aliexpress.com/NrU7FFzQ
    (from AliExpress Android)
    It has no such output.
    I found a used kruger martz km1005 for a similar price.
    The budget is small, but help me choose something ;)
  • #4 16667784
    tzok
    Wouldn't it be easier to buy an analog to TOSLINK converter and connect to the factory amplifier with a fiber optic cable?
  • #5 16667823
    sweet_miru
    I am not sure if the original one is functional. Someone before me messed with fiber optics, i.e. he replaced the original comand with an ordinary standard radio w203, made some workarounds, took the changer, took the gsm module.
    That's why I bought this android station, due to the functionality and costs of restoring the factory system to live.
    My factory H&K amplifier:
  • #6 17294579
    arek940228
    Hello. Could I know how you solved the sound problem because I have the same problem?
  • #7 18720400
    stotas
    I join the question, someone has figured out how to connect an android radio with the Harman Kardon installation?
  • #8 20964918
    hildebertolobao
    I two have the same problem run in to it today
✨ The discussion revolves around integrating an aftermarket Android radio into a Mercedes W203 equipped with a factory Harman Kardon sound system. The user faces challenges due to the original fiber optic connection to the factory amplifier, resulting in no sound output. Suggestions include using an analog to TOSLINK converter to connect to the factory amplifier or considering alternative amplifiers. The user also explores the possibility of using a Boschmann Z-8528X amplifier to power the existing speakers but is uncertain about the functionality of the original system due to previous modifications. Other participants express similar issues and seek solutions for connecting Android radios with the Harman Kardon installation.
