[Solved] Lenovo G50-80 - Installing Windows 7 on UEFI, the process hangs
Achrioptera 6306 5
  • Windows 7 UEFI install hangs at Starting Windows
    #1 16667695
    Achrioptera
    So far I was only a forum reader, today I am writing my first post. I understand something there, but I'm generally a layman in computer matters.
    I have a Lenovo G50-80 laptop. There is some Windows 7 x64 on it. I wanted to upload the original Windows 7 Home Premium x64 (for various reasons I do not want ten), not on the BIOS, but on UEFI. I prepared a bootable fat32 gpt flash drive from the original disc image. Boot mode on UEFI, Safe Boot disable. Diskpart clean, convert to GPT. I turn it on, the pendrive works, the first windows initialization bar is loaded, then the black screen with "Starting Windows" and such flying colorful dots of the logo. After a while, the dots freeze. Unfortunately, my pendrive does not have a working LED, but the computer left for about 40 minutes was unchanged. For a trial, I downloaded two other images of the same Windows. Same effect. All the advice I found on the net recommends changing working with UEFI to compatibility mode, but I really care about EFI. I even read that someone advised you to remove one of the RAM chips during installation. Maybe I would try, but I only have one.
    Help.
  • #2 16667711
    rtj71
    IT specialist
    Help: 474
    Rate: 353
    Uefi will stay anyway, it's just a compatibility mode, not a change from uefi to bios.
  • #3 16667750
    pl_chris
    Help: 34
    Rate: 22
    Probably the problem is that the win7 installer does not support USB3 ports. Try to burn the ISO image to DVD and run the installation from there.
  • #4 16667756
    Achrioptera
    So the Legacy and Boot UEFI First mode should be set and it will be fine? So I did not recognize that I already had what I wanted and rummaged everything for no reason? I can accept it, but why does the installation hang?
    No USB 3 support. I didn't think about that. In the evening it will try on USB 2. If it fails, it will try the CD.
    Edit: on USB port 2 the problem persists.
  • #5 16672364
    WojtasJD
    Help: 2920
    Rate: 1587
    W7 x64 needs INT 10h \ VBIOS interrupt (emulation) for UEFI boot graphics
    UEFI Firmware - Windows support of UEFI wrote:
    Windows(R) 7, Windows Vista(R) with Service Pack 1 (SP1), Windows Server(R) 2008 R2 and Windows Server(R) 2008
    o Support UEFI 2.0 or later on 64-bit systems. They also support BIOS-based PCs, and UEFI-based PCs running in legacy BIOS-compatibility mode.
    o Support on Class 2 systems running in legacy BIOS-compatibility mode by using a CSM, so they can use the legacy BIOS INT10 features .
    o Are not supported on Class 3 systems, because these operating systems assume the presence of legacy BIOS INT10 support in the firmware, which is not available in a Class-3 UEFI implementation.
    o Windows Server(R) 2008 R2 and Windows Server(R) 2008 also support EFI 1.10 on Itanium-based systems.
    so as in this G50-80 is the latest firmware and you tried different paragraphs. including Boot Mode: [Legacy Support] + Boot Priority: [UEFI First], or if there is something about OS like 'Other' (but probably not there) and freezes on the logo
    it cannot be installed with the 'normal' way ...
  • #6 17344671
    Achrioptera
    I gave up on Windows 7 and did what I wanted under Windows 10 without any problems.
