Troubleshooting Balcony Door Handle Issue: Cannot Close Vertically, Latch & Pin Positions
grajek82 22572 4
  • Handle likely blocked by the gearbox or internal lock mechanism
    #1 16668480
    grajek82
    I have a problem with the balcony door. I can not close the handle.
    It should be vertically down, but unfortunately I can only turn it that much. You can not get down. The problem would be simpler to solve if it happened with the door closed.
    Unfortunately, with the door open, the latch can not be moved. Therefore, the frame is not blocking, but something else.
    I would add that the position of the pins in different settings seems to be correct. You can also open the window without a problem.
    Do you have any ideas?
    Thanks for the help in advance.
  • #2 16668531
    Jawi_P
    Level 36  
    Help: 260
    Rate: 715
    There are eccentric screws on the side of the door or, as it is technically called. Regulation needed.
    On youtube you will probably find not one movie with adjustable windows and doors. Describe - it's a lot of writing.
  • #3 16668979
    grajek82
    Unfortunately not. The screws are well set. Something is blocking in the window wing itself (in the middle)
  • #4 16668986
    jurek54
    Help: 7
    Rate: 73
    I had a similar situation. Silicone spray lubricant on the pin strip, settled the matter.
  • #5 16669272
    telecaster1951
    Help: 829
    Rate: 818
    Unscrew the slat on the side of the profile. The mechanism is hidden under it. Probably a piece of plastic, which is supposed to stabilize the mechanism, broke up and blocks the lock.
