Repairing Plastic Balcony Door: Fixing Spinning Handle & Improving Closing Mechanism
szyraf 113358 11
How can I fix a PVC balcony door handle that spins freely and no longer closes the door?
Remove the handle and test the door with another handle or a square pin; if the door then closes normally, the handle’s square shaft is too short or no longer reaches the mechanism [#11621699] If the handle reaches but still only spins, the fault is usually a worn or damaged gear/bolt cassette at the handle side, and that part may need replacing rather than adjusting the handle itself [#11656814][#16369173] To continue, remove the fitting/strip from the door and look for the manufacturer marking so you can identify the correct cassette or repair part [#11621629][#11658992] One user reported that a damaged gear cassette could be replaced with a repair cassette, but the exact brand and rack dimensions must match or the parts will not fit [#13820864][#16369173] The practical fix is therefore to diagnose whether the square drive is the issue first, then replace the damaged cassette if the internal mechanism is worn [#11621699][#16369173]
  • #1 11621607
    szyraf
    Rate: 16
    Who knows how to repair a balcony door (plastic)?
    The handle is spinning around and it does not close, I twisted it, oiled it and nothing.
    I will be grateful for your help because it's getting cold. :)
    Greetings.
    Raphael.
  • #2 11621629
    WP_elewator
    Help: 70
    Rate: 63
    On the walls of the balcony sash you have fittings (closing mechanism) installed and there should be a brand and marking on them.
    The rest will be found in google :D
  • #3 11621679
    szyraf
    Rate: 16
    I found it on the door myself, the problem is that the 9C Series No. 17148 is not on the net yet
  • #4 11621699
    andi
    Rate: 13
    Remove the handle from the balcony door and by inserting a handle, e.g. from the door, check if the door closes and the mechanism is working properly If everything is OK, then the metal part of the handle (the square section) is too short and does not reach the square hole in the closing mechanism .
  • #5 11645495
    szyraf
    Rate: 16
    the problem still exists, the handle reaches but does not twist the mechanism. What's more interesting, when the locking bolts are lifted manually on the fitting, the square turns in the hole.
  • #6 11647483
    _jta_
    Electronics specialist
    Help: 3212
    Rate: 4258
    And how do you put something in this square and turn it around? Perhaps there is something to the connection in between
    a stick (or whatever it is called) that goes into the square, and the handle - for example
    there is an element that can be moved on it, through which the handle is to turn the pin,
    and it is this element that has moved away from the handle so that it does not reach and turn it.
  • #7 11656814
    MariuszX49
    Help: 43
    Rate: 82
    Most likely, the gear wheel has worn out in the place where the handle is located, i.e. the square hole is the center of the gear wheel, if there is no load in the form of a handle, it turns, if not, then without removing the whole door from the door, it is impossible to make a further diagnosis.
    MariuszX49
  • Factory fitting inaccuracies cause mechanism wear and play
    #8 11657899
    retrofood
    Help: 1140
    Rate: 4798
    You know the button on the fittings. It is not that simple at all. The type that my colleague gave me does not tell me anything, because I am not a balcony door specialist, so there will be no specific advice, but I am struggling with this problem in the same way. And since I took it apart and analyzed it, I find it not that simple.
    The reason for the defect are factory inaccuracies, this cannot be hidden. But how after many years to pursue you don't know which factory? Inaccurate fitting of the mechanism, inaccurate machining, and during normal operation, all this causes bending of the elements, their side friction and, as a result, excessive wear, contribute to the wear and tear of the mechanism.
    Nobody probably counted these resistance, because what for? Szajs and crap. These are gills, like tinned food, they have slack in the guides, like from here to the moon, because who would care?
    I fixed this by squeezing a metal clip almost the thickness of a paperclip between the outer guides (on both sides, for experimentation), but it helped for two days. Besides, the breech rack was still increasing the play and it did not have any effect.
    Unfortunately! I have a balcony door that is just over 10 years old, supposed to be normal (these are already being replaced in the new system) and a button! There are problems to open them, there are also when I want to close. The search for such fittings on the Internet was unsuccessful. Probably the price will be higher than the new door. There are no such! Or they pretend to be dumb.
    That is why I do not bode well for you, although I wish you success.
    PS. Leave the handle alone, that's not the topic.
  • #9 11658992
    MariuszX49
    Help: 43
    Rate: 82
    If a colleague would like to pursue the topic further, it would be necessary to remove the fitting from the door, put it on the floor with a measure along the length, what the scale would be and maybe it would be possible to read the manufacturer. help.
    MariuszX49
  • Bolt guides fail to engage; pressure temporarily restores operation
    #10 12392110
    rugeer
    I have a similar problem.
    only for me, as if the guide of the "bolts" did not catch when turning the handle and I only hear the handle turns.
    I tried to put something in the guides by pressing it in the place where the handle turns and it works. and I have a problem there, but I have no idea how to fix it myself.
    because nothing stays there long enough for me to close and open without any problem.
    Maybe you have any ideas?
  • #11 13820864
    gladiator
    Rate: 34
    How to remove the side panel because after removing the handle I noticed a problem with the rack.
    how to replace this measure because it sticks.
    I found out that the gear cassette was damaged.
    Such:
    http://okucia24.com/winkhaus-kaseta-naprawcza-zasuwnicy-grm-grm-grk-grf,id1005.html
    And the best thing is that it is a bestseller from the manufacturer! :D
  • #12 16369173
    AdamEB
    Most likely, the bolt cassette has been damaged, it is most often made of metal and when the door starts to work harder it simply falls apart, I bought a new one online at okucia24.com. If you hit the type, the exchange takes 30-40 minutes. All you need to do is unscrew the handle and the bolts securing the strip with pins, the gear cassette unfolds in half, so all you need is a thin screwdriver. The real fun begins when you miss a producer and that's what happened to me. The cassette I bought was a WINKHASUS (the only one available) and I think the Roto movement. When trying to assemble it, it turned out that the casing did not fit anymore and it had to be treated with a needle (the damaged one was used as a model), time about 15 minutes. After adjusting the housing, another ... much more serious problem appeared. The cassette rack did not match the guide bar, different tooth thickness and pitch, no chance of fitting and please don't even try ... it's a waste of time. The only chance ... to use the rack from the damaged cassette and here another problem, the diameter of the old rack 13 mm, the slot in the new cassette 16 mm. The easiest way to use a steel reduction sleeve fi 13 on fi 16 with a thickness of 1.8 mm, if you have a familiar turner, he will do it in a few minutes, I took my door apart on Friday evening, so you could forget about finding a workshop. I made a sleeve from an ordinary eight washer by sawing the hole for fi 13 ... a bit of a watchmaker's job, but it was worth it. After folding, everything works fine.
    AE
The discussion revolves around repairing a plastic balcony door with a spinning handle and a malfunctioning closing mechanism. Users suggest various diagnostic approaches, including checking the handle's fit with the mechanism and inspecting the gear wheel for wear. One user mentions that the handle may not be engaging the mechanism properly due to a short metal part. Others discuss potential factory inaccuracies leading to excessive wear and suggest removing the fitting for further inspection. A damaged bolt cassette is identified as a common issue, with recommendations to purchase replacements online. Users share experiences with specific brands and models, highlighting the challenges of fitting new parts correctly.
