Toyota Yaris II (2017) Automatic Alarm Activation: Diagnosing Causes, Limit Switches & Reed Switch
Jerzy Pura 20880 7
  • Missing trunk-lid reed switch location needed
    #1 16668773
    Jerzy Pura
    How to diagnose the activation of the alarm without an external cause? I checked the limit switches in the door and under the engine cover. I didn't find the limit switch under the trunk lid. There is probably a reed switch or other sensor, but I have not located it, please hint.
    Car details:
    TOYOTA YARIS II HATCHBACK 3D 1.0 VVT-I (2017)
    Type: XP9F (A)
    Variant: KSP90 (G)
    Version: KSP90 (L) -CGMRKW (1B)
  • #2 16681673
    CameR
    Moderator of Vehicle Security
    Help: 1139
    Rate: 3272
    Jerzy Pura wrote:
    alarm activation without an external reason?
    Disconnect all alarm triggering lines from the control unit and test in this condition.
    Then connect the trigger lines and sensors to the control panel in turn - each time testing the system.
    Jerzy Pura wrote:
    TOYOTA YARIS II (2017)
    There is no guarantee?
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #3 16681696
    gimak
    Help: 614
    Rate: 1678
    Maybe you have a broken glass sensor installed, and it reacts not only to the noise of the broken glass, but sometimes to a loud car passing by or the shrinking of shrinking plastic.
  • #4 16681821
    CameR
    Help: 1139
    Rate: 3272
    gimak wrote:
    broken glass sensor fitted
    The broken glass sensor (with microphone) will not react to a passing car or shrinking plastic.
    Shock sensor (impact with piezoelectric element) is different
    ABC KOM
  • #5 16682350
    gimak
    Help: 614
    Rate: 1678
    I have such a sensor and it responds to more noise. At first I was also wondering about such accidental alarms. The sensor reacts (as it is active) to a stronger knock on the glass or body. I don't know if there is any possibility of increasing the sensor threshold.
  • Searching for the boot lid opening sensor
    #6 16683155
    Jerzy Pura
    I noticed that the alarm went off in the garage without any noise, it turned off after a short operation. Such switching probably caused the battery damage and replacement. When activated, the alarm sounds like the door is open, but the central locking works and the door is closed. The sound phenomenon once occurred, once not, but now it is still there. Previously, I wrote that there is no limit switch under the boot lid. I think I will unscrew the plastics to find the sensor of opening the lid, because I have not yet located it.
  • Uncertain sensor contact or overcharged battery causing alarm
    #7 16683818
    gimak
    Help: 614
    Rate: 1678
    In my garage, sometimes the alarm was triggered because it was signaled late when the alarm was deactivated.
    One has no relation with the other. The alarm (control panel) checks the status of the sensors and reacts to this. In this case, one of the sensors in the door, boot or engine compartment has an uncertain contact or there may be uncertain connection in one of the sensor circuits.
    Check your system voltage while the engine is running. Maybe the battery is heavily overcharged, and it can also trigger an alarm. At my old battery, sometimes the alarm was heard when the engine started (starter operation). After charging the battery, it was quiet for some time.
  • Faulty boot lid sensor triggered false alarm
    #8 16691081
    Jerzy Pura
    The reason for the accidental activation of the alarm was a malfunction of the boot lid closing sensor located in the tailgate. With the cover closed, the sensor should be in the "normally open contact" state, while with the cover open in the "closed contact" state - closed. The sensor's malfunctioning was that it sometimes got short-circuited when the boot lid was closed, probably due to shocks, and the alarm went off. I made the initial diagnosis by looking at the door opening indicator, sometimes it did not go out after closing the boot. After removing the plastic cover and unfastening the sensor cube, the defect subsided. After the leads to the cabin to measure the sensor, it turned out that the next time you open and close the trunk, the sensor is once closed, once open. I ordered a new lock on Allegro.
    Thank you all for your interest in my topic
    George
The discussion revolves around diagnosing the unexpected activation of the alarm system in a 2017 Toyota Yaris II. The user has checked limit switches in the doors and engine cover but is unable to locate the trunk lid sensor, suspected to be a reed switch or similar. Responses suggest disconnecting alarm triggering lines to test the system, checking for faulty sensors such as a broken glass or shock sensor, and ensuring proper connections in the sensor circuits. The user later identifies a malfunctioning boot lid closing sensor, which intermittently short-circuited, causing the alarm to trigger. After replacing the sensor, the issue was resolved.
