2SZ-FE - Toyota Yaris II 1.3 does not turn the starter, the buzzer relay under t
d3lta 23187 4
  • #1 16642017
    d3lta
    Help: 9
    Rate: 332
    Toyota Yaris II 1.3 VVT-i 2006.
    XP9F (A) SCP90 (H) SCP90L-CHMRKW (1A)
    VNKKL98320A083211
    The fault suddenly appeared.
    I get in, turn the key and this relay starts buzzing:
    2SZ-FE - Toyota Yaris II 1.3 does not turn the starter, the buzzer relay under t 2SZ-FE - Toyota Yaris II 1.3 does not turn the starter, the buzzer relay under t
    It is located under the hood, on the left, behind the battery.
    It buzzs all the time when the ignition is on, and after pressing the clutch (until the sensor operates) it stops buzzing. The car does not start, does not spin the starter at all.
    The lights on the board are lit but not all. No charging icon, engine ...
    I checked the fuses. Battery is full. What to check next?
    andrzej20001
    Help: 1578
    Rate: 6669
    Engine weight.
  • #3 16642114
    d3lta
    Help: 9
    Rate: 332
    Oh gosh!!!! You're right. I made an abbreviation of a battery welding wire and it works.
    andrzej20001
    Help: 1578
    Rate: 6669
    Wow, that's great ?
  • #5 16642802
    d3lta
    Help: 9
    Rate: 332
    Thank you for your help.
    The culprit turned out to be the untightened ground cable on the gearbox body.
