Seat Ibiza 1.2 TDI CR (CFWA Engine) - Timing Replacement Procedure & Diagram Guide
Bunny82 12903 2
  • #1 16669354
    Bunny82
    Help: 15
    Rate: 242
    Hello, I am looking for a procedure and a timing replacement diagram in ibiz with 1.2 tdi common rail engine code CFWA
  • #2 16672317
    drdrug
    Help: 25
    Rate: 178
    Like any CR :-) The procedure is such that we fasten the timing on the loose pulley of the shaft and the injection pump. Of course, on the blockades
    We assume the belt starting from the shaft, roller, tensioner, roller, water pump, roller between the roller and the cr pump, the cr pump, the roller between the cr pump and the water pump.
  • #3 16684417
    Bunny82
    Help: 15
    Rate: 242
    Thank you very much.
