Skoda Fabia II 1.4 TDI: Replacing Oil Pump Drive Chain, Timing Belt Reuse & Crankshaft Gear Safety
lukasz921 6657 3
  • #1 16568017
    lukasz921
    Rate: 35
    I am trying to replace the chain in the oil pump in the 1.4 TDI engine. I am an amateur, but I have already done many things with the car, although it is the most difficult topic I will meet. I googled the topic and one thing puzzles me. I have to remove the timing belt for this operation, or if it has a mileage of 20-25 thousand, can I reinstall it? I guess so. However, I am mainly wondering if I block the timing, I will have to unscrew the crankshaft gear. So, what is the best way to protect yourself so that this shaft does not shift? I found information somewhere on the forum that when the bowl is removed, it can be blocked with a wooden block? Or block somewhere on the flywheel side? Unless I can mark the shaft and if it changes, it can be properly adjusted? I would be grateful for help.
    best regards
    Luke
    mario 77
    Help: 66
    Rate: 335
    You can mount it again, just mark the direction in which it worked and assume the same.
    The wheel has a wedge, so otherwise you won't put it on and there are marks and locks to set the timing. Do not unscrew the central shaft on the installed lock.
  • #3 16568631
    lukasz921
    Rate: 35
    So if the camshaft is blocked and the shaft shifts? And I will have its position marked, it will be enough to live and return to the correct position and the marker and lock it and put the timing gear?
  • #4 16569541
    mario 77
    Help: 66
    Rate: 335
    Yes . It's best to get a description of the belt replacement procedure, you will know how to set, how to block the tensioner, etc. etc.
