HP DJ 2130: Scans & Copies, Won't Print from Windows XP SP3 PC - Works on Other PCs
Vvieslav 4479 8
  • #1 16676707
    Vvieslav
    I have installed a new HP DJ 2130 printer. I have Windows XP SP3. The scanner is working. You can copy but not print if I print from PC.
    I tried on another computer it was ok.
  • #2 16676716
    ERESJOT
    Help: 63
    Rate: 21
    If it's OK on another computer, you have the wrong drivers installed. It is best to disconnect the printer from the computer, uninstall the current driver, and then be sure to reset the computer. Then, from the HP website, download the correct driver for that printer for your system. Install it and then connect the printer. Then it should be fine.
  • #3 16676753
    Vvieslav
    I did as you wrote. But the situation is the same: it scans, copies without problem. But it doesn't respond to a print command. You can see that the file is being sent to the printer, the printer icon appears on the bar for a moment, but then it disappears and there is no document selected for printing.
  • #4 16676780
    ERESJOT
    Help: 63
    Rate: 21
    Then there are incorrect settings in the printer settings. Check all printer settings on the computer running the printer and make the same in the printer settings of the other computer.
  • #5 16677146
    Vvieslav
    I checked all the settings are identical. The system is different. Maybe there is something wrong with Windows.
  • #6 16677224
    ERESJOT
    Help: 63
    Rate: 21
    Probably not. And whether the printer is not in the "off line" by chance.
  • #7 16677267
    Vvieslav
    No - it's online. Maybe this is interesting: if the printer is online then this is the situation (described above) with the printer icon appearing and disappearing in the bar. If the printer is offline, the icon does not disappear and in the tasks there is this document for printing only in the table of "pages" is not available. When switching to online, the document in the tasks disappears.
  • #8 16677386
    ERESJOT
    Help: 63
    Rate: 21
    If this is the case, you must have incorrectly set selections in the printing options. I don't remember which one it is exactly, but there are two functions which turning off will solve the problem. When I remember (because I haven't turned them off for a long time), I will let you know.
  • #9 16682656
    Vvieslav
    To ERESJOT: Is there any chance that you will remember or check which functions it is about?
✨ The user is experiencing issues with their HP DJ 2130 printer, which successfully scans and copies but fails to print from a Windows XP SP3 PC, despite functioning correctly on other computers. Initial troubleshooting involved uninstalling and reinstalling the correct drivers from the HP website, but the problem persisted. Further investigation suggested potential incorrect printer settings or configurations specific to the Windows XP system. The user confirmed that the printer is online, yet the print job appears briefly in the taskbar before disappearing, indicating a possible issue with print options or settings that need adjustment.
