Acer Aspire 5720ZG - I am looking for an ACPI / ENE0100 driver.
afticn 8661 9
How can I find the ACPI\ENE0100 driver for an Acer Aspire 5720ZG running Windows 7?
You need the ENE0100 / ENE CIR Receiver driver for Windows 7, and the suggested hardware-ID driver pack is here: drp.su/en/hwids/ACPI%5CENE0100?os=windows-7-x64 [#16758952] Do not run the full installer application; unpack the drivers only, because the driver package itself is what you need [#16759046] The thread also notes that the ENE CIR Receiver link had already been given earlier [#16758853]
  • #1 16758836
    afticn
    Rate: 21
    I am looking for an Acer Aspire 5720ZG driver
    ACPI / ENE0100
    Thank you in advance.
    Greetings.
  • #2 16758841
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    If you can't specify what system you have, maybe write a little and enter google: ENE0100, then read the first few pages (forum hp).
  • #4 16758850
    afticn
    Rate: 21
    I am sorry than I realized that I did not provide the system, you were the first.
    System
    Windows 7
    I was on Acer's website but I don't know which one it is,
  • #5 16758853
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    To ENE CIR Receiver link juz dostales.
  • #6 16758938
    afticn
    Rate: 21
    Kolobos @
    Thank you, unfortunately the installation of this driver did not help.
    Further in the device manager shows the absence of the ACPI / ENE0100 driver
  • #8 16759034
    afticn
    Rate: 21
    Kolobos @
    Windows 7 Professional x32
    From the link you provided, the application was installed:
    ENE-FORCED-7x64-drp_985198832.1508087287
    The program scanned the entire computer and installed the missing driver.
    Device Manager does not indicate missing drivers.
  • #9 16759046
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    I see you have difficulty reading comprehension. I specifically wrote that you do not run this application but only unpacked the drivers!
    Now you need to remove it ...
  • #10 16759065
    afticn
    Rate: 21
    Kolobos @
    Thank you for your understanding,
    Of course, I already uninstalled this application ... I figured out that I do not want Russian.
The discussion revolves around the search for an ACPI / ENE0100 driver for the Acer Aspire 5720ZG, specifically for a Windows 7 system. Initial responses suggest searching online for the driver and provide a link to a driver repository. The user later clarifies their system specifications and reports that a driver installation did not resolve the issue, as the device manager still indicated a missing driver. Further assistance is provided with a link to a specific driver download, which ultimately resolves the issue, confirming that the missing driver was successfully installed and recognized by the system.
