Connecting Two Lamps & Two Switches in Garage: Double Staircase Switches, Flush-Mounted & Wiring
Prorok78 9282 4
  • #1 16679335
    Prorok78
    Rate: 28
    Welcome,
    Stupid thing because I should be able to, but I got mixed up ...
    I'm doing a new installation in my garage. Two doors, both with light switches. Two lamps on the ceiling. The idea is that from each input I could turn on each of the lamps independently (or both at once).
    I am thinking about double staircase switches, but I cannot find out if there are such 'basement-workshop' switches (flush-mounted, cheap) or only flush-mounted, too much money? :)
    And how to connect it to make it work? I have a standard LN PE 3x2.5mm2 brought to the garage.
    Thank you very much in advance for your help :)
    mawerix123
    Help: 482
    Rate: 950
    Prorok78 wrote:
    I just can't find out if there are such 'basement-workshop' switches (wall mounted, cheap) available,
    They are surface-mounted -> https://epstryk.pl/p/3313/31725/-lacznik-scho...we-bialy-kontakt-simon-aqw6-2l-11--pozostale- serie-kontakt-simon-sockets-switches.html? gclid = EAIaIQobChMIzPqj9caJ1gIViYKyCh3R3g3FEAQYBCABEgKHs_D_BwE
  • #3 16679408
    Prorok78
    Rate: 28
    Suuuper :) I was looking but somehow it did not show me :) And schemacik will someone give you? :)
  • #4 16679416
    krakarak
    Help: 681
    Rate: 1842
    @ Prorok78 "and the schematic was thrown" to you in the post above.
  • #5 16679477
    Prorok78
    Rate: 28
    Its not seen the first attachment :( Excuse me...
    And thank you very much !! :) This closes my dilemma :)
