Inconsistent Heating Issue with Radiator: Heats Up After Venting, Then Cools Down
bubu87 23481 18
Why does a radiator heat up after bleeding, then cool down again after about 10 minutes, and how can I fix it?
The radiator is likely getting airlocked again because the valve/piping arrangement is wrong or the branch has an incorrect slope, so circulation stops after a short time [#14199369] [#14198518] [#14200173] Check that the lower valve is fully open and, after removing the thermostat head, set the valve insert/orifice to about 5–6 [#14202213] Do not drain the radiator; bleed it properly through the vent or by slightly loosening the union on the supply side if needed [#14202213] [#14200173] If the supply pipe rises and then falls before the radiator, correct the slope so it falls toward the radiator, or raise the vent side if necessary [#14198518] [#14200173] If the problem keeps coming back, the practical fix suggested in the thread is to install an automatic air vent [#14197374] [#14202213]
  • #1 14197323
    bubu87
    Rate: 20
    I have this problem with the radiator this year:
    Sometimes it heats up and sometimes not as it pleases. When I vent it gets hot and after 10 minutes it gets cold again.
    I thought there was no flow so I turned off the valve up and down and drained all the water from the radiator. Then I turned the valve on the top to see if the water was flowing all the way down and in. I poured water into the radiator, it was hot and cold again after 10 minutes.
    I live in a block of flats on the ground floor. Only one room problem.
    Regards
  • #2 14197374
    karol-jaskulski
    Help: 9
    Rate: 8
    I had a similar problem - solution - install the automatic air vent.
  • #3 14197409
    bubu87
    Rate: 20
    put it in the place where the manual vent is? ie the upper right side of the radiator.
    Will it drip water onto the floor?
    Regards
  • #4 14197435
    karol-jaskulski
    Help: 9
    Rate: 8
    Yes, install it in the upper corner of the radiator, for me it looks like this:
    I have installed this air vent for over 2 years and it did not shed a drop of water.
  • #5 14197442
    bubu87
    Rate: 20
    I was buying a nice little radiator and something like this will stick out :P I will not say that it is a bit disfiguring :)
    Overall, what's the problem? Is there air in the installation in a block of flats, or what? Because if the fault is not on my side, I will press the Housing Cooperative to fix the fault.
    Regards
  • #6 14197464
    karol-jaskulski
    Help: 9
    Rate: 8
    It's hard to say what the problem is, I don't know enough details to advise anything else. I suspect that the creative neighbors have come up with something with the central heating installation, or the radiator itself is faulty. Maybe it is actually worth reporting it to specialists from the cooperative for a good day, as it will not help, then install the vent.
  • #7 14197531
    bubu87
    Rate: 20
    What could the neighbors have found there? :)
  • #8 14198518
    Pawlo-3102
    Help: 24
    Rate: 56
    A friend had such a problem, it was not caused by the radiator but by the pipe that led to it - there was such a hinge - the pipe went up, went horizontally and then went down to the radiator. In this case, the radiator is filled with water, but the pipe is not and there is no flow. There it helped to mount the "automat" on the tube at the top.
  • #9 14198849
    mitsurugi
    Help: 93
    Rate: 222
    Buddy bubu87, if you upload photos of the radiator and the installation, it will make the diagnosis easier, because for now you can predict coffee grounds.
  • #10 14199200
    bubu87
    Rate: 20
    Inconsistent Heating Issue with Radiator: Heats Up After Venting, Then Cools Down Inconsistent Heating Issue with Radiator: Heats Up After Venting, Then Cools Down Inconsistent Heating Issue with Radiator: Heats Up After Venting, Then Cools Down
    mirrzo
    Help: 441
    Rate: 2609
    Screw in the return and bleed it properly.
    It should start working. Notice that you have a negative drop in the power supply.
    EURO-DOM
    Krótka, Elbląg, 82-300
  • #12 14199407
    bubu87
    Rate: 20
    I vent and only water flows, not air ...
  • #13 14199849
    mirrzo
    Help: 441
    Rate: 2609
    Try to bleed again at the valve.
    EURO-DOM
  • #14 14200085
    bubu87
    Rate: 20
    And how is it venting at the valve?
  • #15 14200173
    xXxXxMAXIMUSxXxXx
    Rate: 16
    It is vented with an air vent or by slightly unscrewing the union on the supply valve. You can put a pellet and unscrew it by gently dropping a little water on the return (so-called forcing circulation)
    But here, buddy .. I don't know who founded this radiator for you, but I think Rysiek with a Czech ...
    The reason for this is simple:
    The power branch goes up, from what I see, the installations are in copper, so you can boldly lower it gently on the handles so that the power knob is equal or with a minimum slope towards the radiator, if you do not get such a height, lift the duplex radiator (from the vent side) max. .
    that's the only solution in this matter. As long as Rysiek and Czech have screwed the vent properly .. {if you look from the top into the grille, it should be from the vent and the pipe, and from the valve side, it splits into both panels. I am an installer and I propose to close the topic because you will not do anything else. greetings
  • #16 14201182
    gersik
    Help: 164
    Rate: 639
    xXxXxMAXIMUSxXxXx wrote:
    While Rysiek and Czesiek screwed the air vent well ..
    And it can be screwed in wrongly.
    "bubu87" report to administration, you pay them in the end.
  • #17 14202128
    xXxXxMAXIMUSxXxXx
    Rate: 16
    Yes you can. There are types of radiators where the page is important and there are the so-called universal types, I do not know what he has to have a look under the masking grille then it would be certain that I could bring him back with coffee grounds.
    Ps, if you have a flat that has not been purchased for ownership and you have exchanged your heater yourself without writing a letter of consent to the cooperative or the community, you may still have a problem with this title.
  • #18 14202213
    arelektroda
    Help: 31
    Rate: 200
    Remove the thermostat head and check the position of the orifice on the valve. You have numbers there usually from 1-6. Set to 5-6. Also check that the lower valve is definitely open. Under its cap you have a mushroom that can be unscrewed with an Allen. It must be open, it is turned to the maximum (so that its face does not protrude beyond the valve because the plug may fall out).
    Do not pour this water out of the radiator, it is enough to vent it with the valve. If, after such a check, the radiator continues to air out, the only solution will be the automatic air vent valve.
  • #19 14876575
    bubu87
    Rate: 20
    ok. problem solved.
    you can close the topic.
    thank you for your help
The discussion revolves around an inconsistent heating issue with a radiator in a ground floor flat. The user reports that the radiator heats up after venting but cools down again within ten minutes. Various solutions are proposed, including the installation of an automatic air vent to prevent air accumulation, which could be causing the heating inconsistency. Users suggest checking the positioning of the radiator valves, ensuring proper flow in the pipes, and verifying that the radiator is not faulty. Some responses indicate that the problem may stem from the central heating installation or the pipe configuration leading to the radiator. The user ultimately resolves the issue after following the advice given in the forum.
