Polo 6n2 Heater Replacement Guide: Access, Removal & Installation Steps - with Air Conditioning
bungar 22317 5
  • #1 16681482
    bungar
    Rate: 33
    Hello, I have to replace the heaters. Today I took the whole cockpit, everything is visible, but I have no idea what to do next, how to get to it? Everything looks as if it were connected together, there are also air conditioning cables. What to do next, I will be very grateful for your help, because I have no clue.
    Polo 6n2 Heater Replacement Guide: Access, Removal & Installation Steps - with Air Conditioning Polo 6n2 Heater Replacement Guide: Access, Removal & Installation Steps - with Air Conditioning
  • #2 16681541
    DriverMSG
    Help: 3984
    Rate: 4883
    From the engine compartment side, you unscrewed how many bolts (nuts)?
  • #3 16681669
    bungar
    Rate: 33
    From the engine side I can see one maybe two screws top. I understand that you have to remove this whole case, right?
  • #4 16681804
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Did you disconnect the air conditioning?
  • #5 16682097
    DriverMSG
    Help: 3984
    Rate: 4883
    3 are from the heater and were still plastic under the cabin filter.
    See in Google how it looks after dismantling - yes, you have to remove all.
  • #6 16682610
    milejow
    Help: 1563
    Rate: 5149
    In Polo IV 2003 (this is probably the next version, the one with lamps like a mercury spectacle :D ) the entire shearer is held by a metal cockpit frame, from the engine compartment side they are only held by air pipes and water pipes, maybe it is similar. Of course, you dismantle the whole plastic body with a blower, evaporator and heater, only after removing it you remove the heater.
    Działalność własna
    Mętów 99, Lublin, 20-388
