[Solved] vw polo 1.0 mpi 6n2 2000 - position of the air temperature sensor
zimnydz 12831 8
  • #1 16743771
    zimnydz
    Level 4  
    Rate: 45
    Please help me find the intake air sensor. In the previous car, I had an air filter in the housing, but in the VW Polo I can not track it. I know it is but where ??
  • #2 16743851
    autoas
    Help: 571
    Rate: 3924
    Maybe a photo will help you ....
  • #3 16744103
    zimnydz
    Level 4  
    Rate: 45
    Ok. I already know. So if someone wants to help me, this is his question. Map sensor what is it, what is it responsible for and where is it because I thought that the sensor indicated in the photo was a map sensor. Thank you in advance for your help.
  • #4 16744174
    Ireneo
    Help: 747
    Rate: 2472
    In this car, the map sensor is integrated with the intake air temperature sensor. Don't ask what the map sensor is, everything is in google.
  • #5 16745302
    jarek225
    Help: 64
    Rate: 221
    Absolute pressure sensor, the so-called The MAP Sensor is a sensor that uses vacuum in the intake manifold to give a signal about the engine load. In the event of damage, it results in increased combustion (the engine works in emergency mode, i.e. the fuel is fed rigidly)
    Here you have a nicely described: link
  • #6 16775538
    zimnydz
    Level 4  
    Rate: 45
    Problem solved Sensor found.
  • #7 17159071
    zimnydz
    Level 4  
    Rate: 45
    One more question from the sensors. What is outdoor air sensor ?? Does it perform a function in the engine or is it just the temperature outside the car?
  • #8 19570131
    jan.cichocki.pl
    zimnydz wrote:
    I am asking for help in finding the intake air sensor. In the previous car, I had an air filter in the housing, but in the VW Polo I cannot track it. I know it is but where ??
  • #9 19621378
    zimnydz
    Level 4  
    Rate: 45
    Car sold...engine had no oil pressure , despite this it would not seize, did not heat up and continued to run....
The discussion revolves around locating the intake air temperature sensor in a 2000 VW Polo 1.0 MPI (6N2). The original poster initially struggled to find the sensor, as they were accustomed to a different setup in their previous vehicle. Responses clarified that the manifold absolute pressure (MAP) sensor is integrated with the intake air temperature sensor in this model. The MAP sensor is responsible for measuring engine load via vacuum in the intake manifold. The original poster later confirmed that they successfully located the sensor.
