[Solved] Daewoo Matiz 2000 Heater Replacement: Step-by-Step Guide for Models with Air Conditioning
psilos1 24555 6
  • #1 16945179
    psilos1
    Level 32  
    Help: 203
    Rate: 878
    Hello, I need to replace the heaters in matiza with air conditioning 2000 ... how to go about it? Can anyone have a step-by-step description of this operation?
    g107r
    Help: 809
    Rate: 985
    I haven't seen it, but I don't read all forums, you would have to put together many posts into one, and the photos are trace.
    https://forum.autokacik.pl/index.php?/topic/383366-brak-ogarzenia/ there a friend promised, maybe he has some pictures, since he wrote about the photo manual. He gave one, only after dismantling the board.
    The option from the bottom probably falls off, because you will not open the housing without removing the evaporator, and in total now you are looking for https://www.google.pl/search?client=firefox-b...0&q=demonta%C5%BC+deski+rozdzielcza+matiz&sa= X & ved = & b and 0ahUKEwjR6JTO0sjYAhUHCywKHVeXAAo4ChDVAghlKAE = 1440 & bih = 726
  • #6 16950269
    psilos1
    Level 32  
    Help: 203
    Rate: 878
    Hello, successful surgery again, I used this guide ......
  • #7 17147604
    psilos1
    Level 32  
    Help: 203
    Rate: 878
    Subject exhausted ... I close
✨ The discussion revolves around the replacement of heaters in the 2000 Daewoo Matiz models equipped with air conditioning. Users seek a step-by-step guide for this operation. Initial responses suggest that the process may involve removing the window sill and potentially the dashboard, with links to video guides and forum discussions. However, some users express frustration over the lack of a comprehensive step-by-step manual. A follow-up indicates that one user successfully completed the replacement using available resources, while another notes the topic is now exhausted.
