Samsung J3 phone - a strange icon on the top bar of the screen
AnikOwl 12663 7
  • #1 16688739
    AnikOwl
    Rate: 11
    Please, let me know what the icon that sometimes appears on the top bar of the phone screen - on the attached screen is quite on the left.
    Thank you in advance for your help :)
  • #2 16688785
    krzysiozak
    Level 40  
    Help: 512
    Rate: 1156
    See the instruction manual.
  • #3 16688817
    AnikOwl
    Rate: 11
    Unfortunately, the manual does not contain the indicated icon.
  • #4 16688844
    jarek225
    Help: 64
    Rate: 221
    Here you have it : link
    That is, transferring the image from the smartphone to the TV screen.
  • #5 16688884
    AnikOwl
    Rate: 11
    I do not use such a function, I did not even know about its existence. The icon appears in circumstances when there is even no television in the vicinity. Is it possible that this icon appears in some circumstances?
  • #6 16688911
    gruktel
    Level 32  
    Help: 200
    Rate: 309
    And it does not appear when using youtube ??
    GRUK Krystian Grudzień
    Chwałki 46, Sandomierz, 27-600
    jarek225
    Help: 64
    Rate: 221
    Disable the application and the icon will disappear.
  • #8 16854351
    AnikOwl
    Rate: 11
    In the end, it turned out that I had a spyware application on my phone that was installed without my knowledge. The icon appeared when taking a photo or tracking the screen.
    Later I happened to use the AZ Screen Recorder application - the same icon is displayed during the screen recording, only then I used the application consciously and I already knew what a mysterious stamp it was ;)
The discussion revolves around a mysterious icon that appears on the top bar of the Samsung J3 phone screen. The original poster inquires about the icon's meaning, noting that the user manual does not provide an explanation. Responses suggest that the icon may indicate screen mirroring to a TV, although the user does not utilize this feature. Further investigation reveals that the icon can appear even without a TV nearby and may be linked to specific applications. Ultimately, the user discovers that the icon was associated with a spyware application that was installed without their knowledge, which activated when taking photos or screen recording. The AZ Screen Recorder app also displays the same icon during screen recording, confirming its function.
