What regulator for the Gas boiler Termet Silver, in the apartment?
poeta janusz 17409 13
What room regulator/programmer should I use with a Termet Silver 25 kW gas boiler in an apartment?
Use a separate room regulator; any daily or weekly thermostat that opens/closes the boiler’s RT control contact will work, and you can later extend the setup with an outside weather sensor [#16691239] If you want full boiler control from the regulator, Termet’s Easy Remote with OpenTherm was recommended; it was mentioned as costing about PLN 300 [#16691767][#16692157] If you do not need the extra features, a simple on/off regulator is enough [#16692157] Place the room regulator in the coldest room, and do not use thermostatic radiator heads in that room because the regulator replaces them [#16692970] A weekly programmer with time and day scheduling was also suggested as a practical option [#16692970]
  • #1 16691067
    poeta janusz
    Rate: 19
    Hello gentlemen, I am slowly finishing the installation planning, the choice of programmer remains.
    How would you recommend heating in a 5-room flat with the Termet Silver 25 KW stove?
    Does the furnace have any control and programming devices or should it be purchased separately?
  • #2 16691239
    andrzej lukaszewicz
    Help: 626
    Rate: 2121
    You can use any weekly or daily room regulator. On / off consists in closing / opening the control contact in the boiler described as RT.
    Control, regulation can be extended by adding a weather sensor.
  • #3 16691767
    BUCKS
    Help: 536
    Rate: 1087
    Termet offers an Easy Remote controller that is supposed to support Open Therm.
    I don't know how much it costs and exactly what options it supports, but I personally like to have access to as many boiler control options as possible, so the Open Therm controller seems to be the only choice for me.
  • #4 16692119
    poeta janusz
    Rate: 19
    That's how the driver for this OpenTherm is offered.
    I just don't know if such details are needed for adjustment.
  • #5 16692157
    BUCKS
    Help: 536
    Rate: 1087
    I checked and Easy Remote for Silver costs PLN 300.
    For me, 300 is an acceptable price, so I wouldn't think about it. If you make every 100 PLN a big difference and you do not feel the need to have controllers with "goodies", then buy a regular controller on an on / off basis without additional communication with the boiler.
  • #6 16692218
    poeta janusz
    Rate: 19
    I think that the programmed heating hours daily plus in advance of the week is all I need
    Added after 12 [hours] 5 [minutes]:
    I want to be able to set the temperature in advance depending on the time of day. And a portable thermometer to put it in one of the rooms
  • #7 16692970
    BUCKS
    Help: 536
    Rate: 1087
    Generally, the room regulator controls the temperature in the room (by design the coldest) in which it is located, so there should be no thermostatic heads on the radiators in this room, because the room regulator replaces those heads. In other rooms, on the other hand, you should have heaters selected so that the other rooms warm up at the same time. Thanks to this, the risk of underheating of one or more of the other rooms decreases if the controller gives a signal to the boiler "turn off heating".
    If you do not have large requirements, then you take a model with a weekly programmer and set the temperature for specific hours and days of the week, weekend, etc.
    At first, it seemed to me that I do not need much, but now, having more knowledge and knowing your boiler and the characteristics of your installation, I have greater requirements. The configuration options for my controller and the boiler itself are now a bit too small for me, but it is a technological solution from several years ago.
    Unnecessary options can always not be used, and if you run out of options in the future, you will not add it.
    In the pessimistic version, even if you never use the additional goodies of the controller, considering that the boiler is bought rather for several years, then saving e.g. PLN 100-150 on the controller can be negligible.
    I would also invest in condensate in the so-called weather, i.e. an outside temperature sensor, but I'm me, and everyone makes their own choices.
  • #8 16827184
    Grzewczypan
    I have this regulator but in a small apartment it does not work yet. every now and then turns on, turn off the stove. it works strangely, I probably still have to embrace it. but from my observations it is better to set the minimum temperature on the furnace, and then it works tiny, almost continuous.
    silver temret boiler, flat 65m2
  • #9 16827220
    wnoto
    Help: 58
    Rate: 744
    What does he give in addition? Over standard ones with weekly program settings?
  • #10 16827238
    BUCKS
    Help: 536
    Rate: 1087
    @Grzewczypan
    I don't know how exactly this EasyRemote works.
    But most often regulators work on the principle of hysteresis.
    Having a hysteresis of e.g. 0.4 degrees, after setting e.g. 20 degrees the regulator will turn on heating at 19.8, and turn it off at 20.2.
    In practice it looks different but in general this is the principle.
    You must also take into account the speed of heating the water in the installation by the boiler, the speed of heat transfer by the radiators to the room, etc., because everything together will matter for the frequency of boiler start-ups.
    Therefore, in some situations, as you have noticed, lowering the temperature and slowing down the heating process extends the heating cycle, which increases comfort. In some boilers, the indirect power is regulated, so you have to tune everything for a specific installation. Without the weather, you have to manually adjust the boiler temperature settings depending on the frost outside.
    In fact, the area is indicative, because the most important is the demand for thermal energy, and it depends on the volume of the rooms (room height), heat loss, i.e. the possible insulation of the building, etc.
    Open Therm gives the possibility of full boiler control from the regulator, which would be useful for me, because you would not have to run to the boiler to check and change something.
    So much theory I read.
  • #11 16827254
    Grzewczypan
    And isn't it the most economical solution for the boiler to work as little as possible with a flame as small as possible so that it is comfortable at home at the moment?
    and this can be set just by setting the temperature on the boiler plus additional regulation on radiators.
    and that's it. I need regulators and other goodies.
  • #12 16827283
    BUCKS
    Help: 536
    Rate: 1087
    Yes you can, but the regulator is more precise than a thermostatic head, so thanks to the regulator you can gain a few percent savings.
    Assuming that you want to maintain 20 degrees constantly, the savings come from the right energy dosage, the greater the precision, the greater the savings, because you have less losses.
    You need to find your golden mean taking into account your needs and costs.
  • #13 16910146
    piloo1
    Help: 12
    Rate: 98
    Heater - what were your Easy Remote parameters with such a boiler behavior that it switches on and off every now and then?
  • #14 16910149
    tomk38
    Rate: 17
    it was not easy renovation only st292
The discussion revolves around selecting a suitable regulator for the Termet Silver 25 KW gas boiler in a 5-room apartment. Participants suggest using either a basic on/off room regulator or the more advanced Termet Easy Remote controller, which supports Open Therm technology. The Easy Remote is priced at PLN 300 and offers enhanced control options. Users emphasize the importance of setting the temperature accurately to optimize heating efficiency and comfort, with recommendations for a weekly programmer to manage heating schedules. The conversation also touches on the functionality of room regulators, the impact of hysteresis on heating cycles, and the potential for energy savings through precise temperature control.
TL;DR: For a Termet Silver in a flat, a room controller with 0.4°C hysteresis and OpenTherm support helps smoother, fewer cycles; “Open Therm gives the possibility of full boiler control.” [Elektroda, BUCKS, post #16827238]
Why it matters: This FAQ helps apartment owners choose and set up the right regulator to cut short-cycling and improve comfort.
What regulator works with the Termet Silver gas boiler in an apartment?
Use a room thermostat that switches on/off via the boiler’s RT terminals, or a compatible OpenTherm controller like Easy Remote. On/off models are simplest and handle daily or weekly schedules. OpenTherm units add deeper control from the living space without walking to the boiler. [Elektroda, andrzej lukaszewicz, post #16691239]
Is OpenTherm worth it compared to a basic weekly thermostat?
OpenTherm lets the room unit communicate more data and adjust boiler behavior directly. As one user notes, “Open Therm gives the possibility of full boiler control from the regulator,” which increases convenience and fine-tuning potential. If you want more than simple time/temperature scheduling, choose OpenTherm. [Elektroda, BUCKS, post #16827238]
How much does the Termet Easy Remote typically cost?
A user reported the Easy Remote for Termet Silver at PLN 300. Treat this as an indicative figure rather than a fixed price. Budget accordingly if you value added features; the small premium can pay off in convenience over several seasons. [Elektroda, BUCKS, post #16692157]
What is hysteresis and why does it matter for comfort?
Hysteresis is the temperature band around your setpoint that triggers heating on and off. Example: with 0.4°C hysteresis at 20°C, heating may start at 19.8°C and stop at 20.2°C. Smaller hysteresis can reduce swings but may increase cycling if the system isn’t tuned. [Elektroda, BUCKS, post #16827238]
What is a weather sensor (outdoor sensor) and should I add it?
A weather sensor measures outdoor temperature to adjust the boiler’s flow temperature automatically. This reduces manual tweaks as weather changes and can smooth operation. It is a recommended add-on for condensing setups to improve comfort and stability. [Elektroda, andrzej lukaszewicz, post #16691239]
I just want scheduled temperatures—will a weekly programmer be enough?
Yes. If your goal is to set daytime and nighttime temperatures for specific days, a weekly programmer covers it. Users aiming for simple schedules and portability often choose a battery-powered room unit placed in a representative room. [Elektroda, poeta janusz, post #16692218]
Why does my boiler short-cycle in a small flat (e.g., 65 m²)?
In compact spaces, the boiler can reach set temperature fast, then shut off and restart frequently. One user saw frequent cycling on a 65 m² flat until they adjusted settings and lowered boiler temperature to extend burn times. [Elektroda, Grzewczypan, post #16827184]
Can I run the boiler at the lowest flame for economy and use radiator valves to trim rooms?
You can, but a room regulator is more precise than thermostatic heads. Better dosing of energy around a constant 20°C target can save a few percent, improving comfort and reducing losses. “Find your golden mean” between needs and cost. [Elektroda, BUCKS, post #16827283]
What’s the best room to place the thermostat, and what about radiator heads there?
Place the thermostat in the reference room, usually the coldest living area. Do not use thermostatic heads on radiators in that room; the room controller replaces them. Size other radiators so rooms heat evenly before the boiler shuts off. [Elektroda, BUCKS, post #16692970]
How do I wire a basic on/off thermostat to the Termet Silver?
  1. Connect the thermostat’s dry contacts to the boiler’s RT terminals.
  2. Set desired daily or weekly schedule on the thermostat.
  3. Optionally add the outdoor sensor for weather-compensation later. This enables simple start/stop control from the room unit. [Elektroda, andrzej lukaszewicz, post #16691239]
What is OpenTherm in simple terms?
OpenTherm is a communication protocol between the boiler and room controller. It shares data both ways and lets the controller adjust boiler settings directly. Users value it to “check and change something” without visiting the boiler. [Elektroda, BUCKS, post #16827238]
My Easy Remote (or similar) keeps causing rapid on/off—what settings fix this?
First confirm the exact model in use. In one case, rapid cycling discussion turned out to involve a different controller (ST292), not Easy Remote. Check controller type, then tune hysteresis or target temperatures and minimize overshoot. [Elektroda, tomk38, post #16910149]
Is a 25 kW Termet Silver oversized for a 5-room flat?
Users discuss a 25 kW Silver in flats and highlight that area is only indicative; real need depends on volume and insulation. Oversizing can increase cycling, so tuning flow temperature and controls becomes important for comfort and efficiency. [Elektroda, BUCKS, post #16827238]
Do I still need to tweak boiler temperature without a weather sensor?
Yes. Without outdoor sensing, you must adjust boiler temperature as outdoor conditions change. Lowering the boiler setpoint often lengthens burn cycles and improves comfort, especially in small, fast-warming systems. [Elektroda, BUCKS, post #16827238]
Which offers more day-to-day convenience: OpenTherm or on/off?
On/off is simple and cheap, good for fixed schedules. OpenTherm centralizes control and information at the room unit, which many find more convenient over time. It reduces trips to the boiler and exposes more tuning options. [Elektroda, BUCKS, post #16827238]
What’s an edge case where a regulator still underperforms?
If radiators are unbalanced or the thermostat sits in a non-representative room, even a smart regulator can misread comfort. The controller may shut heating early, underheating distant rooms. Balance emitters and place the sensor wisely. [Elektroda, BUCKS, post #16692970]
