Error: Incorrect Data Type in Access Query Criteria Expression - Form Parameters Issue
gnat1985 5439 2
  • #1 16692241
    gnat1985
    Hello!
    I am building a query with parameters. The query parameters are to come from the form.
    The form is ready, however, after entering the Criteria and running the query, an error appears: "Incorrect data type in the criterion expression"
    Code:
    Code: SQL
    I am asking for a hint what is wrong. Let me add that all date formats are the same: short date.
    Prot
    Help: 574
    Rate: 297
    gnat1985 wrote:
    " Between :?: [forms] [Report form]! [Date from] and :?: [forms]! [Report form]! [Date to]"
    And in which Access or SQL expressions can be used Between :?: whether and :?: :D
    Are the relevant fields in the form also properly formatted or masked (with a typing pattern)?
  • #3 16692851
    gnat1985
    The code obviously has 'Between' and 'and'. Cells are formatted without an input mask.
