Purchase of a new washing machine - low-failure, durable, low water consumption
mjkmjk1 6432 15
Which durable, low-failure washing machine with a large load capacity and low water consumption should I buy to replace my 11-year-old Siemens WM14E460PL/3?
The thread points most strongly to Bosch/Siemens BSH WAN-series washing machines, especially the WAN2426EPL: 8 kg capacity, 1200 rpm, many programs, Water Plus, and a design described as proven, fully serviceable, and quiet [#16833663] Another reply says you should not chase low water consumption at the expense of wash quality, because good washing depends more on technology and detergents than on using the least water [#16833766] If you trust Bosch/Siemens, the advice was simply to look through Bosch’s offer, with the seller’s claim that the higher 8 series is made in Germany, while 4 and 6 series are made in Poland/Russia [#16833766] As an alternative for maximum durability, one user suggested buying a used Miele about 5–6 years old, claiming it can last much longer and that the manufacturer rates operation up to 20 years [#16856305]
  • #1 16832921
    mjkmjk1
    Rate: 12
    Hi
    Unfortunately, after 11 years of intensive and failure-free use, my Siemens WM14E460PL / 3 washing machine has perforated the rear drum wall. From what I read on the forums, the repair does not make sense. Therefore, I am forced to buy a new washing machine and I would like to ask for help in choosing.
    Having confidence in the brand, I lean to Bosch / Siemens, but I don't insist. My priorities are 1) durability and failure-free operation, 2) high load capacity, 3) low water consumption. The price is of secondary importance - I would prefer, for example, to around 2,000. PLN, but if it makes sense to pay 3 or 4 thousand (from what I read on the forum, not too much), I can also consider more expensive models.
    Of course, I really care about time, so I am asking for advice.
  • #2 16833048
    arekb81
    Help: 135
    Rate: 746
    Think carefully about whether you want well-washed clothes or low water consumption.
  • #3 16833090
    mjkmjk1
    Rate: 12
    Of course, well washed is the most important thing.
    My point was that I have a septic tank at home and if I had to choose, I would prefer less water, but of course not at the expense of washing quality.
    Any specific suggestions or will you end up only with pincers?
    baconp
    Rate: 53
    The question is whether you live in a block of flats or in a cottage. I recommend LG for the block, because there is no V-belt to drive, only the engine is directly behind the drum, which makes it quiet. Doesn't crush or whistle like a jet plane. For 2 years I have the F10B8ND model (6kg and 4 5cm deep), so far it works, the only downside is the lack of a spin-only program (there is only a rinse with spinning). If you are considering buying a clothes tumble dryer in the future, choose a washing machine with a higher speed, from 1200 up (I bought a dryer without a Bosch heat pump thanks to the electrode, but I would not want Bosch washing machines). Samsung and LG give 10 years warranty for the inverter motor, but Samsung is on the belt. So far, I haven't found another company like LG that has a silent drive. As for water, lower consumption is associated with longer washing time and under-washing. In practice, despite the multitude of programs, I only use one program "60 minutes washing".
    PS, whatever washing machine you would buy, buy a washing machine filter (the cartridge lasts for six months), washing every week.
  • #5 16833611
    mjkmjk1
    Rate: 12
    Thanks for the answer. I live in the house and the washing machine is in such a place that I am not bothered by noise. I don't really need a filter, because I have a water treatment plant and the water is soft throughout the house. I have a lot of confidence in the Bosch / Siemens brand, because both in the previous apartment and now in the house we have everything Bosch or Siemens and the washing machine is the first device that broke down. From what I read on the forum, 12 years is a pretty good result anyway, considering that we raised our two children from birth. From what I've read, most new B / S washing machines now also have a 10 year motor warranty.
    agdrtv.info
    Help: 13
    Rate: 25
    mjkmjk1 wrote:
    I have great confidence in the Bosch / Siemens brand.
    And then you can trust BSH. WAN washing machines have been available for some time, which are very quiet, fully serviceable and based on the proven design of WAE washing machines. For example, a model is worth recommending WAN2426EPL - 8 kg, 1200 rpm, a very large number of programs. And the water plus option for more thorough washing.
  • #7 16833744
    mjkmjk1
    Rate: 12
    Thank you very much for this opinion. I will check if there is anything 9 kg in this line, because I want the largest drum possible. On the other hand, I still have to check if the increase in kg = the increase in the volume of the drum.
    Unfortunately, only WAY, WAW and WAT are 9 kg
    Ryszard49
    Help: 312
    Rate: 1011
    mjkmjk1 , see Bosch's offer, it's worth getting acquainted with it.
    Link
    Link
    Whether it is washed well does not depend on the amount of water, but on technological solutions and, of course, detergents,
    Felini
    Moderator
    Help: 124
    Rate: 433
    mjkmjk1 wrote:
    [...] I have great confidence in the Bosch / Siemens brand [...]
    "Vertrauen ist gut, Kontrolle ist besser" [trust is good, control is better], my German friend from a car service used to say.
    The best - in my opinion - seems to be limited trust.
    We had three Bosch / Siemens devices, all purchased in the 1990s. Two of them are still operating today. Bosch WOH 4210 washing machine - after more than 15 years of operation, the engine stopped working, I replaced the brushes, it works to this day. Siemens HE48E54 oven - only replacing the bulbs illuminating the inside of the baking chamber.
    In the Siemens ceramic hob (it is not an integral part of the oven, but was sold with it) the heating zones burned out several times. Original box bought
    on the website it costs about PLN 400-600, I bought a field with the same diameter / power parameters for PLN 85. Both fields, original and replacement, are made by the same EGO company. The Bosch refrigerator was an infamous exception, as it broke probably 3-4 times in about 2 years. At that time, the refrigerant was filled, the electronic controls were replaced, eventually the post-warranty service surrendered and could not repair the refrigerator.
    In the case of the washing machine and oven, one can speak of durability and reliability, however, when it comes to the refrigerator, I was very disappointed with the Bosch brand.
  • #10 16833797
    mjkmjk1
    Rate: 12
    My friends were similarly disappointed with the Siemens refrigerator. For me, the Bosch refrigerator lasted almost 10 years and I sold it together with the apartment. Now I have a second one that works for 2.5 years without failures. Other equipment too. Maybe it's luck, or maybe I'm buying the more expensive models. I do not know. Maybe both.
    Link
    Link
    I was on the Bosch website. I read and analyze. Unfortunately, the manufacturer's comparison site does not sin with transparency (if it starts at all and does not crash soon).
    baconp
    Rate: 53
    I remembered that my sister has a Samsung washing machine with this kind of active air bubble system, a marketing hoax. And don't believe these things like washing in cold water. It's like washing dishes in cold water :)
    LG has 6 different movements of the drum during washing (you have videos on YT) from practice, because once I do my laundry at home and once on an old electrolux washing machine and I can see the differences. This 6-drum function does not work with all programs - that's a minus, unfortunately no info in the manual. I mentioned the filter because I noticed that the detergents foam more in soft water than when I did not have the filter.
    Also note that the washing machine selects water for washing, but not for rinsing.
    Below are some photos of my washing machine filter. Reliable cast iron risers.
    Purchase of a new washing machine - low-failure, durable, low water consumption Purchase of a new washing machine - low-failure, durable, low water consumption
    Added after 8 [minutes]:
    It turns out that there is no one company that is good at everything.
    In the 90s, it seems to me that the durability of the products was slightly different. So far, Sony TV works for me.
    Parents have a 90s Zanussi refrigerator, still working.
    All in all, you are looking for a company that has simple design solutions to be able to repair it yourself, or the costs will not exceed the purchase of a new device. So what if most manufacturers give a 10-year warranty on the washing machine motor, since the electronics will probably fail faster.
  • #12 16834842
    mjkmjk1
    Rate: 12
    I was in the shop. The seller suggested the 8 series from Bosch because it is made in Germany. Series 4 and 6 reportedly in Poland and Russia. I don't know if it matters in this case. It's hard to be a patriot in this country.
    Ryszard49
    Help: 312
    Rate: 1011
    mjkmjk1, The seller is right.
    Felini
    Moderator
    Help: 124
    Rate: 433
    cakp wrote:
    It turns out that there is no one company that is good at everything [...]
    Talking to a German salesman in a store, I heard that Bosch does not necessarily make good refrigerators, but washing machines are ok. This and other German sellers mentioned the Liebherr brand as the manufacturer of the best domestic refrigeration equipment, in my case it works for now.
    As for the durability of household appliances from the 90s, let's look at how much on average monthly salaries such a Bosch washing machine then bought and how much it costs today.
    I also recently said goodbye to Sony Trinitron, he worked for about 23 years, but then it cost PLN 3500-4000 + inflation. Today we buy 42 "for e.g. PLN 1900.
    I had a friend who worked in a fairly high position in a well-known company producing household appliances in Poland. He said they once got a very large order for products from one of the Scandinavian buyers. There was one condition; we take so many pieces, but the price must be such and such. Either the producer meets the conditions, or the contract thread. What did they do? The engineers were given a job; "you have to meet certain specific costs." So they started to count, as if using a thinner sheet, instead of 0.5 mm to 0.4 mm, instead of using more expensive plastic to make this part from cheaper, lower quality, and they continued their reasoning. The price pressure exerted by the recipient translated into the quality of the product. You can ask yourself whether the market, on the other hand, is not putting pressure on producers in this direction?
    As for the place of production, Poland, Germany or another country, I think it is of secondary importance, the class of equipment seems to be more important. My Liebherr fridge and freezer are premium class and I don't even know where they were made. So far, both have been operating without failure, one for over 6 years, the other for over 3 years.
  • #15 16840224
    baconp
    Rate: 53
    I have a BOSCH hair dryer series 6, with a label made in poland. LG f10b8DN washing machine, made in poland
    Hopefully the devices have been around for a long time :) The washing machine was supposed to be quiet
    LG constructed the engine in an interesting way
    https://www.youtube.com/watch?v=GrYFFVso0KQ
    Marketing looks like this, but if you screw up your clothes, it shakes slightly but only slightly, the glass of water will not spill out
    it looks technically more interesting
    https://www.youtube.com/watch?v=2Ys1X85eIjE
  • #16 16856305
    MikroPstryczek
    Rate: 22
    Buy a used Miele, 5-6 years old. I've been using mine for the fifth year with no problems, and it has already 11. The manufacturer guarantees its operation for up to 20 years. If I cannot afford a new Mercedes, I buy a used one and recommend it
The discussion revolves around selecting a new washing machine after the user's Siemens WM14E460PL / 3 failed after 11 years of use. The user prioritizes durability, high load capacity, and low water consumption, expressing a preference for Bosch or Siemens brands. Various participants recommend LG for its quiet operation and innovative direct drive motor, while also suggesting Bosch models like WAN2426EPL for their reliability and features. Concerns about water consumption versus washing quality are raised, with insights on the importance of technological solutions and detergent effectiveness. The conversation also touches on the longevity of appliances, with some users advocating for high-quality used models like Miele for their durability.
TL;DR: A quiet, durable pick is a Bosch WAN (8 kg, 1200 rpm), but remember, “lower consumption is associated with longer washing time.” A compact LG Direct Drive option notes 6 kg and ~45 cm depth. [Elektroda, baconp, post #16833410]
Why it matters:** You want a washer that actually cleans well, fits your space, and won’t flood your septic or wallet.
Should I prioritize low water use or cleaning performance?
Prioritize cleaning performance first. Low water use can compromise rinse quality and extend cycle times. As one expert put it, “Think carefully whether you want well‑washed clothes or low water consumption.” If you have a septic tank, favor programs with extra rinses or Water+ to avoid detergent residue. [Elektroda, arekb81, post #16833048]
Is Bosch/Siemens still a durable, low‑failure choice in 8 kg class?
Yes, the Bosch WAN line is praised as quiet, fully serviceable, and based on a proven WAE design. A recommended pick is the WAN2426EPL with 8 kg capacity, 1200 rpm, many programs, and a Water+ option for better rinsing. “Trust BSH here,” one contributor advised. [Elektroda, agdrtv.info, post #16833663]
Which Bosch Series are made in Germany?
A store adviser told the OP that Bosch Series 8 models are made in Germany, while Series 4 and 6 are made in Poland or Russia. Treat this as a purchasing tip to verify on the product label at the shop. [Elektroda, mjkmjk1, post #16834842]
Is LG Direct Drive actually quieter and reliable?
Users highlight LG’s direct‑drive motor mounted on the drum for quieter operation and fewer moving parts. One owner notes two years of solid use and mentions the widely marketed 10‑year motor warranty. Direct drive also reduces belt noise compared to belt‑driven designs. [Elektroda, baconp, post #16833410]
Does low water consumption mean longer cycles or worse washing?
Yes. Contributors report that lower water usage often extends cycle time and can leave laundry under‑washed. If you choose eco modes, confirm a Water+ or extra‑rinse option to compensate. This is critical for sensitive skin or septic systems. [Elektroda, baconp, post #16833410]
What should I look for if I have a septic tank?
Use thorough‑rinse features. On Bosch, the Water+ option increases water for better detergent removal. Select normal‑temperature cycles that clean well without excessive suds, and avoid extreme low‑water eco cycles for heavy soil. “Water Plus helps with thorough washing.” [Elektroda, agdrtv.info, post #16833663]
How many RPM do I need if I’ll add a tumble dryer?
Choose at least 1200 rpm. A forum member who added a dryer recommends 1200 rpm or higher to reduce moisture before drying. Faster spin shortens dryer time and cuts energy use. [Elektroda, baconp, post #16833410]
Are bubble or cold‑water ‘miracle’ wash systems worth it?
Be skeptical. A user reports Samsung’s active bubble system as marketing and warns against promises of effective cold‑water washing. Think of it like washing dishes in cold water—results may suffer. Focus on mechanical action, time, and proper temperature. [Elektroda, baconp, post #16834661]
Is buying a used Miele a smart durability play?
Yes, if you find a good example. One user runs an 11‑year‑old Miele for five additional years trouble‑free and cites a 20‑year design claim. A 5–6‑year‑old unit can deliver premium longevity at lower cost. [Elektroda, MikroPstryczek, post #16856305]
Does a higher kg rating always mean a larger drum?
Not always. A shopper noted only certain Bosch lines offered 9 kg, and questioned whether higher kg meant larger volume. Check model specs; some series share cabinets while ratings vary. Verify actual drum volume in the store. [Elektroda, mjkmjk1, post #16833744]
Quick how‑to: compare Bosch Series for a septic‑friendly choice?
  1. Start with Series WAN; shortlist 8 kg, 1200 rpm models.
  2. Confirm Water+ or extra‑rinse availability on each candidate.
  3. Test key programs in‑store; pick the quiet, serviceable design you can maintain. [Elektroda, agdrtv.info, post #16833663]
Does country of manufacture matter more than product class?
Product class matters more. One contributor argues place of production is secondary to design and quality tier, citing premium Liebherr refrigeration as an example of focusing on class first. Apply the same logic to washers. [Elektroda, Felini, post #16835073]
Any hidden drawbacks with otherwise good LG washers?
Yes. An owner reports no dedicated spin‑only program on the LG F10B8ND—only rinse with spin. Plan your routine accordingly. This is an edge case that can frustrate users who frequently re‑spin loads. [Elektroda, baconp, post #16833410]
Will softer water increase foaming and affect rinsing?
Yes. A user observed stronger foaming with softened water and noted that washers meter water for washing, not always for rinsing. Use smaller detergent doses and enable extra rinses to prevent residue. [Elektroda, baconp, post #16834661]
Are Bosch/Siemens fridges weaker than their washers?
Experiences vary. One member praises Bosch/Siemens washers and ovens but reports repeated refrigerator failures, while recommending Liebherr for cooling. Treat brand strength as category‑specific. [Elektroda, Felini, post #16835073]
What’s a real‑world durability benchmark from the thread?
The OP’s Siemens WM14E460PL ran 11 years of intensive, failure‑free service before a drum wall perforation ended it. That’s a useful baseline for modern expectations and service decisions. [Elektroda, mjkmjk1, post #16832921]
