Ford Galaxy MK2 2004 GHIA Version: Seeking Wiring Diagram for Interior Lighting Issue
JanuszK777 16023 9
What wiring diagram do I need for a 2004 Ford Galaxy MK2 GHIA with interior lights staying on and an "open passenger door" message?
The interior light problem was caused by a faulty door lock sensor, not by a missing wiring diagram: when the door was closed, pressing the lock/sensor from the inside made it stop connecting and triggered all the interior lights [#17102685] Replacing the door lock sensors fixed the issue, and the repair was cheap and easy to remove [#17102685] The thread also notes that the exact engine code would have helped identify diagrams, but the vehicle data given was a Ford Galaxy 1.9 TD 130 hp, and the engine code was said to be encoded in the VIN [#17100488][#17100843]
  • #1 17092748
    JanuszK777
    I have a disco with lights inside the vehicle and I get the message open passenger door,
    You can also hear the chirping of the relay
    I am an electrician but not a car electrician
    do you have the wiring diagram for Ford galaxy MK2 2004 version GHIA
  • #2 17100189
    marcin.koz2910
    Help: 91
    Rate: 387
    what exactly do you need because I have diagrams but in the program and you can not dump to pdf or other files
    I can do PrtSc
    give the engine capacity and code if you know
  • #3 17100488
    JanuszK777
    Data from the Vehicle Card 1.9TD 130kM No. 4L23470
    when I was in Ford, they wrote in the position: Make / Model FORD GALAXY 2000 5D HIGH SERI 1.9L 130 6 SPD MAN
    THIS IS A SPECIFIC VEHICLE INTERIOR LIGHTING SYSTEM
  • #4 17100793
    marcin.koz2910
    Help: 91
    Rate: 387
    the engine code would make things a little easier
  • #5 17100843
    JanuszK777
    that the engine code is encoded in VIN: WF0GXXPSSG
    marcin.koz2910
    Help: 91
    Rate: 387
    Ford Galaxy MK2 2004 GHIA Version: Seeking Wiring Diagram for Interior Lighting Issue Ford Galaxy MK2 2004 GHIA Version: Seeking Wiring Diagram for Interior Lighting Issue Ford Galaxy MK2 2004 GHIA Version: Seeking Wiring Diagram for Interior Lighting Issue Ford Galaxy MK2 2004 GHIA Version: Seeking Wiring Diagram for Interior Lighting Issue
  • #7 17102685
    JanuszK777
    Thank you very much for your help!
    and I inform you: it turned out that one of the door lock sensors, despite their closing, when they were pressed strongly from the inside, stopped connecting and all the interior lighting bulbs came on (when I was driving at night, on uneven asphalt it looked like I was riding on "beacons "), replacing the door lock sensors, fortunately, it was not a big cost and it was easy to remove
  • #8 19312784
    Slawekstudent77
    Hi. where do these diagrams come from? is there any program?
  • #9 19312832
    madamsz1
    Help: 1057
    Rate: 1711
    Yes, these just come from Tolerance Data
  • Starter spins but engine still won’t start
    #10 20322704
    laskowskiireneusz78
    Hello, please help
    I have a Ford S-Max 2.0 L CDTI, I put the car for 2 weeks, I wanted to start it and the starter does not spin, I thought the battery was weak, I charged it and still nothing lights normally everything as it should be but the starter does not give any response. I checked all the masses to the engine and to the housing nothing is happening still the same as I screwed up the starter is spinning but the car does not start please help what else can I check the fuses I checked
The discussion revolves around a Ford Galaxy MK2 2004 GHIA version experiencing an interior lighting issue, indicated by a message about the passenger door being open and a chirping relay sound. The user, an electrician, seeks a wiring diagram to diagnose the problem. Responses include offers to provide diagrams, with one user sharing links to images of the wiring. The author later identifies that the issue was due to a malfunctioning door lock sensor, which, when pressed, failed to connect properly, causing all interior lights to activate. The sensor was replaced at a low cost, resolving the issue.
