Bosch WLK24240PL Washing Machine - Drum Stops Spinning at Higher Speeds
CLX3185 5835 1
  • High-speed spin stops after two seconds
    #1 16698249
    CLX3185
    Level 4  
    Hello, I have a problem with the Bosch WLK24240PL washing machine, it does not spin the laundry. The entire washing cycle will run smoothly until it is spinning. There, the drum spins at low speed, but when you try to enter the set higher speed, it simply stops (after about 2 seconds) and starts spinning slowly again. This is repeated until the end of the program time. When you turn on the spin mode, the same thing happens. The fault occurs with both the load and an empty drum. What could be the problem?
