Renault Kangoo 1.5 dci - sometimes goes out on idle, pressure drops on the ramp
Piotsztykiii 25869 17
Why does my Renault Kangoo 1.5 dCi sometimes stall at idle when the rail pressure drops, while it drives normally otherwise?
Start with an injector leak-back/overflow test on a hot engine, because Delphi injectors often cause this kind of idle pressure drop [#16212071][#16213456][#16213725] Check the fuel dose control valve on the high-pressure pump and the rail pressure sensor connector, especially the pins, because vibration can deform the contacts and cause intermittent pressure loss [#16214593][#16214605] If the injectors and connectors are okay, the next suspect is the high-pressure pump/regulator in the pump, which one user said is present on this Delphi system and can be expensive to replace [#16213561] One reply also noted that a crankshaft sensor fault can reduce injected fuel and rail pressure, but another pointed out that cam/crank sensor problems usually cause much worse starting issues than the symptom described [#16215963][#16214605] In the thread, the owner improved the pins in the sensor and valve and the problem almost disappeared, which supports checking those connections first [#16220147]
  • #1 16211797
    Piotsztykiii
    Rate: 30
    Recently, I have Kangaroo 2005 1.5dci 82km delphi equipment. I have only one small problem with him. The engine sometimes dims or extinguishes only when idling. It doesn't happen when the engine is cold, but only when the temperature starts moving a little. Sometimes 30 times a day (usually standing on red) and sometimes not even once. I suspected with the interface that during this dimming there is a drop in fuel pressure on the ramp to about 100 bar but I do not know if this value is correct because it is a crap interface. But there are 100% pressure drops. Apart from this, the engine works great. No problems when driving. It has power, it doesn't smoke, idle no wave, it fires normally, combustion is normal. I replaced the air and fuel filter. There were no filings in the old one. I read somewhere on the forum that someone had identical symptoms and helped to replace the "fuel pressure regulator" however I have delphi equipment and probably do not have this regulator. Anyone have any ideas what can I check?
  • #2 16212071
    daras41
    Help: 57
    Rate: 315
    Start with the injection overflow test.
  • #3 16212455
    Piotsztykiii
    Rate: 30
    okay i will do the test but i have to do it during this fading or even if it goes well i can do it
  • #4 16213456
    daras41
    Help: 57
    Rate: 315
    Do it on a hot engine.
    marekwodniak
    Help: 14
    Rate: 194
    A colleague had similarly checked what was possible was the high pressure pump. The regulator you have in the pump cost about 340 PLN. I have the year 2002 and there is a fuel regulator in the pump.
    daras41
    Help: 57
    Rate: 315
    The regulator can also be, but I always start with an overflow injection test, because Delphi valves fall quite often. The regulator is not cheap and I prefer not to change it for free, as it turns out that the injections let go ;)
  • #7 16214344
    jankopolo
    When starting the engine, the pressure on the fuel rail should be 150 bar, at idle no less than 240 bar.
    Remove the plug from the fuel pressure sensor on the fuel rail and correct the pins (bend) then do the same on the fuel dose control valve plug mounted on the rear wall of the high pressure pump.
  • #8 16214493
  • #9 16214593
    Piotsztykiii
    Rate: 30
    Thanks to everyone for your interest.
    The idle pressure is about 280 bar. Declines occur only when it dims or goes out. When the engine is running correctly, there are no idle drops. I have refueled twice with better fuel, drove a bit and it's a little better. It only dims and does not go out and it happens less and less often. Today, for example, it has only faded twice. It looks like something is hanging. I also suspected this pressure sensor in the ramp or the fuel pressure regulator but I came across such a photo on some forum and it probably confused me:
    1 Pre-pump
    2 High pressure pump
    3 Temperature sensor
    4 Low pressure cylinder
    5 Hydraulic head
    6 Fastening holes
    7 Oil inlet
    driving
    8 Oil return system
    driving
    9 High exit
    pressure
    I understand that No. 4 is this regulator, right?
    And if there was something wrong with the injections, wouldn't there be other symptoms? As I wrote, there are no other problems, the engine is really cool.
    jankopolo
    No. 4 is the fuel dose control valve, it is responsible for the amount of fuel delivered to the high pressure section.
    While the motor is running, vibrations occur that cause the pins inside the plug to deform after some time.
    That is why I suggest bending the pins in the fuel dose control valve plug (No. 4) and the fuel rail pressure sensor.
    A damaged or malfunctioning crankshaft position sensor causes significant difficulties in starting the engine, if the camshaft position sensor also works poorly, the engine controller will not give permission for fuel injection.
  • #11 16214617
    Piotsztykiii
    Rate: 30
    Cool. I podoginają and write what and how. I didn't suspect the shaft sensor because I know from experience with gasoline players that it would be problems with starting.
  • #13 16220147
    Piotsztykiii
    Rate: 30
    Hello. The problem is practically no longer present. Practically, because it has not faded for two days :) I have prophylactically improved the pins in the sensor and valve. Maybe I am still tempted to add some fuel, I will just find out how effective it is. Also, thank you all for your help, in the future if the problem returns I will know where to look for a fault.
    As for the interface, I understand what the individual parameters mean, but I'm not sure how accurate it is in live data. But I think it's cool. There are no saved errors but I have to look for some good program for Renault on elm 327 maybe something will be there.
  • #15 16221099
  • #16 16223125
    jankopolo
    I had the opportunity to clean DELPHI injectors after applying the 2T treatment.
    Only 2 pieces were saved. Carbon deposits from burnt 2T oil rendered them perfectly harmless.
    The difference in the amount of fuel dose at different speeds reached 35%.
  • #17 16223741
  • #18 19820267
    pax1990
    I will refresh the topic a bit because I have a similar problem, 1.5dci, after heating it does not want to start, it catches but does not fire, after unplugging the temperature sensor it fires, the pressure at start-up is about 350 bar. I changed the temperature sensor
✨ The discussion revolves around a 2005 Renault Kangoo 1.5 dCi experiencing intermittent engine stalling at idle, particularly when warm. The user noted a drop in fuel pressure to about 100 bar during these incidents, although the engine performs well otherwise. Suggestions include conducting an injection overflow test, checking the high-pressure pump, and inspecting the fuel pressure sensor and fuel dose control valve. The user reported improvements after refueling with higher quality fuel and adjusting sensor pins. The conversation also touched on the potential role of the crankshaft and camshaft position sensors in maintaining fuel pressure. The issue has reportedly diminished significantly after these interventions.
