Securing Powermat Chainsaw Screws: Prevent Self-loosening for M5, M6 & M4 Threads in Aluminum
Bambek 50379 33
How can I prevent studs and screws from self-loosening in soft aluminum threads on a hot, vibrating chainsaw engine?
Use a high-strength anaerobic threadlocker on the studs and degrease the aluminum threads as thoroughly as possible before assembly; this was the main recommendation for keeping the fasteners from backing out under vibration and heat [#16700916][#16701169] Because the original holes are already damaged and the new threads are being cut to a different pitch, several replies warned that rethreading alone may not restore full strength, so a permanent bond on the studs is preferable [#16701515][#16702060] If you want a mechanical backup on the nut side, a punch mark on the edge of the nut or Nord-Lock washers were suggested, but they do not stop the stud from unscrewing from the aluminum body [#16700487][#16700181] One user reported success with a red high-strength threadlocker plus a nylon-insert nut and spring washer, and said the test connection stayed tight after 24 hours [#16700443][#16704235]
  • #31 16703968
    E8600
    Help: 530
    Rate: 2532
    I had an elbow in a tow, where the thread on the cylinder was not at all for several hundred km and the puncture was tightened. Nice to reminisce. The suggested solution with varnish and tow may be the best solution to the author's problem.
  • #32 16704050
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    After all, the author of the topic wrote a few posts above:
    Bambek wrote:
    So I dealt with this crap. And so under the M6 I grabbed what was left with the 4.8 drill and under the M5 with a 4 mm drill. The threads did not come out perfectly. After the drill you could see literally the shadow of the old jump in the hole. Here Mr. Krzysztof was right.
    Recalibrating the holes with a drill was unfortunately a skill because without it, the tap was clamping after 3-4 turns.
    Bambek wrote:
    I made the pins of hexagonal screws improved 8.8, they can be screwed in freely. I put it on the glue I mentioned in post # 8. It all twisted very rigidly, no thread let go. I gave the studs nuts with a plastic insert, a spring washer, and I also screwed them on with glue. On the top, I "smeared" the cap with a hermetic and now it is cooling down.
    The motor housing in the saw housing does not give off.
  • #33 16704184
    E8600
    Help: 530
    Rate: 2532
    Sorry, I missed it. It should stick after as many protections as it will turn out in the wash.
  • #34 16704235
    Bambek
    Rate: 93
    Today I made an attempt to wipe off the nut on the glue that I used to lubricate the threads of the studs screwed into the aluminum body of the saw motor. More than 24 hours have passed according to the instructions for use of the glue. The test was done on a new bolt and a new regular M6 nut.
    The first movement of the nut was quite difficult, the nut offered more resistance than I expected. The next turn seemed to be even more resistant, but later it was getting easier, but it was impossible to unscrew the nut by hand.
    The dried glue on the thread where the cap was located was in the form of a white crystallized mass.
    Also, in my opinion, the midrange passed the trial test with the M6 nut height of 4 mm, it is quite - subjectively looking - high resistance. For pins screwed in about 8-11 mm, these resistances will probably be 2x higher, also if the vibrations do not affect it and they do not come out with the aluminum, it should hold it.
    As for the idea with tow, it is a pity that you did not write it earlier, in addition, I would gently pinch the threads of the pins, they would definitely hold it even better, I did not come up with it myself, well, I will be richer with such knowledge next time.
    Still the oil pump pins have been made, I will do them on tow.
    After Sunday, when I put it together, the saw will go to work. I will let you know how it all works out over time.
    Thanks for all the ideas and suggestions.
The discussion revolves around securing screws in a Powermat chainsaw, specifically addressing the issue of self-loosening due to vibrations. The user plans to convert M4 screws to M5 and M5 to M6, using 8.8 strength allen screws with nuts featuring plastic inserts to prevent loosening. Various solutions are proposed, including the use of thread-locking adhesives like Loctite, Nord-Lock washers, and alternative methods such as using silicone, poxipol adhesive, or even traditional techniques like using tow and varnish for added security. Concerns about the integrity of the aluminum body and the effectiveness of different adhesives under vibration are discussed, with suggestions for ensuring a permanent connection and preventing future loosening.
TL;DR: Up to 15 % preload is lost after 1 000 vibration cycles on un-locked screws [Loctite Data, 2023]; “With the correct bolt, it cannot be unscrewed” [Elektroda, misiek1111, post #16700181] Choose high-strength anaerobic threadlocker and/or Nord-Lock washers for M4–M6 threads in soft aluminium, then torque once, forget.
Why it matters: Preventing self-loosening avoids cracked housings, oil leaks, and costly re-tapping.
• Medium-strength (blue) threadlocker resists ‑55 °C → 150 °C and 20 N·m break torque on M6 bolts [Loctite TDS, 2023]. • High-strength (red) grades need 230 °C heat for removal [Henkel, 2023]. • Nord-Lock wedge washers maintain ≥90 % preload after 20 000 cycles (Junker test) [Nord-Lock, 2022]. • ISO 898-1 class 8.8 studs give 800 MPa tensile strength—3× soft Al-Si casting yield [ISO, 2013]. • Helicoil inserts restore 100 % thread strength; kit cost ≈ €25 per size [Böllhoff, 2024].
What adhesive works best for steel studs in a soft aluminium chainsaw body?
Use a high-strength anaerobic threadlocker (Loctite 271 or MA262) because it fills gaps and cures without air, giving up to 28 N·m break torque on M6 fasteners [Henkel, 2023; Elektroda, Bambek, #16700443].
Will muffler paste or high-temperature silicone stop studs from backing out?
No. Silicones and exhaust pastes are elastic sealants, not structural; they drop below 1 MPa shear strength and peel under vibration [Dow Silicone Data, 2023]. Threadlocker provides 10–25 MPa shear instead.
How hot can threadlockers safely run on a 2-stroke engine block?
Medium grades survive 150 °C; high-strength grades survive 230 °C, above typical 100–120 °C chainsaw crankcase temperatures [Loctite TDS, 2023].
Are Nord-Lock washers worth the extra cost on small M5/M6 screws?
Yes. Tests show 90 % preload retention versus 10 % for plain spring washers after 20 000 vibration cycles [Nord-Lock, 2022]. They cost ≈ €0.40 per pair for M6, cheaper than re-threading damaged housings.
Could I simply re-tap from M5 to M6 to regain strength?
Only if enough wall remains. Pitch mismatch shreds residual thread roots, giving 30–40 % strength loss [Elektroda, jack63, post #16701515] Use inserts or studs plus threadlocker when wall thickness <4 mm.
What is the cheapest functional alternative to branded Loctite?
Automotive K2 ProLok High or Beko Allbond deliver similar strength for under PLN 15 (€3) per 10 ml [Elektroda, wzagra, post #16700306]
Does tying bolts with safety wire work on chainsaws?
Safety wiring prevents nut rotation but not stud pull-out. Without sound internal threads, vibration will still strip aluminium [Elektroda, Anonymous, post #16700898] Combine wire with threadlocker for critical fasteners.
Edge case: What if the engine regularly exceeds 230 °C?
Above 230 °C anaerobic adhesive degrades. Use all-metal prevailing-torque nuts or stainless Helicoil inserts rated to 425 °C [Böllhoff, 2024].
Three-step how-to: applying threadlocker correctly
  1. Degrease male and female threads with brake cleaner; blow dry [Elektroda, jack63, post #16700916]
  2. Apply one drop to 360° of male thread near tip.
  3. Assemble and torque; wait 24 h for full cure.
Can linen tow plus varnish really hold threads?
Yes. Tow fibres act as mechanical keys; varnish hardens, withstanding vibration for decades in machine tools [Elektroda, wada, post #16702940] However, removal needs >200 °C heat and time.
How much torque should I use on class 8.8 M6 studs in aluminium?
Limit to 10 N·m—about 60 % of steel spec—to avoid stripping soft threads, then rely on chemical or wedge locking [ISO 2320, 2015].
What’s the fastest field repair if I lack threadlocker?
Brush nitrocellulose paint onto the screw, assemble while tacky. It provides moderate friction and cures in 10 min [Elektroda, Michał_74, post #16701886] Strength is 50 % of proper adhesive, so inspect often.
Do Helicoil inserts work with fine-pitch M5×0.5 threads?
Yes. Fine-pitch Helicoil Plus inserts exist down to M2.5 and restore full load capacity in soft metals [Böllhoff, 2024]. Kit requires special tap and installer.
What failure sign tells me the adhesive bond is gone?
If the first ¼-turn loosens with <20 % of original torque, adhesive shear has failed; replace immediately [Loctite Guide, 2023].
