Securing Powermat Chainsaw Screws: Prevent Self-loosening for M5, M6 & M4 Threads in Aluminum
Bambek 50379 33
How can I prevent studs and screws from self-loosening in soft aluminum threads on a hot, vibrating chainsaw engine?
Use a high-strength anaerobic threadlocker on the studs and degrease the aluminum threads as thoroughly as possible before assembly; this was the main recommendation for keeping the fasteners from backing out under vibration and heat [#16700916][#16701169] Because the original holes are already damaged and the new threads are being cut to a different pitch, several replies warned that rethreading alone may not restore full strength, so a permanent bond on the studs is preferable [#16701515][#16702060] If you want a mechanical backup on the nut side, a punch mark on the edge of the nut or Nord-Lock washers were suggested, but they do not stop the stud from unscrewing from the aluminum body [#16700487][#16700181] One user reported success with a red high-strength threadlocker plus a nylon-insert nut and spring washer, and said the test connection stayed tight after 24 hours [#16700443][#16704235]
  • #1 16700026
    Bambek
    Rate: 93
    I am asking for advice on securing screw threads against self-loosening.
    The case concerns a Chinese petrol chainsaw with the trade name "powermat", such a tiny branch for one hand.
    As a result of vibrations, all 4 M5 screws securing the motor body to the saw housing and 2 M4 screws securing the oil pump to the motor body have twisted or cut, and the holes in the aluminum body have torn or dented threads.
    Today I disassembled this crap into the first parts, and it can still be saved, I will convert the M4 screws to M5 and M5 to M6.
    I only combine it in such a way that instead of screws, I will screw into the aluminum body pins made of 8.8 strength allen screws, and on the other side, nuts with a plastic insert so that they do not unscrew by themselves.
    However, due to the fact that the lengths of the threads in the aluminum body are about 8-11mm, the pins have to hold tightly together and cannot unscrew themselves because in a moment the effect will be as above and drilling to the next diameter is no longer an option, because it simply will not be possible "meat" and from which to drill.
    The material of the motor body is quite soft some kind of aluminum alloy.
    Therefore, the threaded connection of the steel pin with this aluminum body must be glued with something else, not stick together, I don't know ... secure it so that it does not unscrew.
    Now the question is: what to screw it, what to use, paint, hermetic, some glue, high-temperature silicone? Please take into account that the engine body gets hot from the cylinder.
    I found on the internet some wonderful American anti-loosening agent called "pro seal thread lock" but I have never used anything like this or similar preparations. Has anyone had experience with this?
  • #6 16700278
    Bambek
    Rate: 93
    misiek1111 wrote:
    Use Nord-Lock:
    https://youtu.be/IKwWu2w1gGk
    https://www.youtube.com/watch?v=cDlmbMV9ICU
    the bolt must fit this washer (undercut at the head). With the correct bolt, it cannot be unscrewed (during vibration, because the bolt can of course be unscrewed with a wrench).
    Well, it is already within the portfolio.
    Still, there is the issue of securing (immobilizing) the thread of the pin-motor body against loosening. When looking at the saw standing on the table, two screws are held vertically from the side of the table and two screws vertically from the ceiling. The plastic housing has metal sheets embedded in it under the mounting screws. It is enough for the pin to loosen in the body and it will screw out all the way with the nut and the nord-lock washer. Therefore, according to just me
    secured thread plus nordc-lock guarantees a permanent connection.
    What do you think about using a paste to seal car mufflers, will it be able to fix the thread effectively?
  • #8 16700443
    Bambek
    Rate: 93
    In the morning I ran around the shops and in the automotive industry they offered me one for PLN 110 a 50 ml bottle, of course, I gave up such an expense, but in another store I got exactly what I was here: http://www.amtra.pl/katalog-produktow,709/threadlock-high- strength-red-ma262? brand = 961 for PLN 12.
    Today I will make a test connection and see how it holds static.
    ^ToM^
    Help: 495
    Rate: 2940
    From the free technologies, after tightening the nut, you can punch it with a punch at the point of contact with the bolt. You have to put a good punch on the nut, right next to the thread and hit it once. The edge of the nut will slightly deform. Certainly, it will not unscrew anymore, but if you want to unscrew it yourself, it will also be possible, but you will have to use a little more force. I have such marked wheels on an old lawn mower and I can say that they have not unscrewed for many years.
    Greetings!
    kpodstawa
    Help: 234
    Rate: 245
    I will share my doubts, although I may be wrong. A "rethread" of 1 mm across the diameter may degrade the strength of the joint, not improve it. The thread grooves may come out in such a fragment that the vibration and the notch effect scatter it onto the undulated tube. If you plan to use nuts anyway, it might be better to make "smooth" holes and use "classics" - bolts with flat washers under the heads and nuts, and security in the form of additional screw spring washers. Let the workshop mechanics specialists have an opinion on my thinking. Krzysztof Podstawa
  • #11 16700818
    Bambek
    Rate: 93
    Mr. Krzysztof, your doubts are quite right, but there is no way to do it on the M8 because the tabs from the body in which the screws are screwed in will have a wall thickness, as I do not know what to compare, but let it be like a pen casing.
    If it were possible, I would have done it.
    It's just that the body is made sparingly and at the same time cheesy that you would have to see it with your own eyes, just a disposable one. The material of the body itself, in its mechanical properties, does not resemble, for example, aluminum, for example from an old motorbike engine, it is simply soft.
    This repair, if it is successful, will be fine, and if the pins "come out" of the body in some time, it will only be disposal.
    I was considering converting to an M7 thread, but it's all unusual. You have to buy online (in the shops I was there, they didn't have a tap, dies, bolts or nuts). Now buy it all, it will cost PLN 100 for the same crap. The new Chinese saw costs about PLN 300 (by the way, I will never buy something like this again) And for the M6 I have everything in my garage at hand, I gave it up. I'll try what will be ...
    But thanks to your suggestions, I will do a test in some piece of aluminum thread conversion from M5 to M6, I will see how the thread comes out.
  • #12 16700847
    szkieletor11111
    Help: 63
    Rate: 149
    Buy the simplest silicone and lubricate the screw thread before screwing on the nut.
  • #13 16700854
    Bambek
    Rate: 93
    Now a friend told me to screw the pin into the body of the poxipol. Also this is some way I just have to read the flyer as with the temperature resistance of the glue.
    Edit. I have already read, poxipol can withstand up to 120 degrees.
    This is the glue I bought, it has a resistance of up to 150 degrees.
    The cap will also go on the glue, I will additionally score it.
  • #14 16700878
    szkieletor11111
    Help: 63
    Rate: 149
    This is exactly what you can do. What is permanent - with glue, and what with the possibility of twisting - with silicone.
  • #16 16700916
    jack63
    Help: 851
    Rate: 2828
    The stupidest and most harmful advice.
    No scoring !!!! Even for steel with these diameters it is risky.
    Anaerobic glue is enough. I have used it for repairing motorcycles many times.
    Just remember to degrease the connected elements as much as possible, which will be difficult for the internal thread. Good solvent from painters + compressed air will do the job.
  • #17 16700952
    szkieletor11111
    Help: 63
    Rate: 149
    Anaerobic glue is enough. I have used it for repairing motorbikes many times.
    You have the right to think so, but your colleague will do and as he sees fit.
  • #18 16701157
    Bambek
    Rate: 93
    As for degreasing, of course I have a very good spray brake degreaser (not the one from the lidl, this one is much weaker) takes it all.
    In the end, I decided that everything would go to thread glue, the nut too, and I will paint it on top.
    In fact, scoring can only destroy this toy.
    jack63
    Help: 851
    Rate: 2828
    Thread adhesives are usually also .... anaerobic.
    There are only two types. Those that only prevent rotation and those that normally stick. Since you will not unscrew the studs and the threads are already damaged and additionally cut by threading to a larger diameter (other pitches), it is better to seal them permanently. This will increase the strength of the connections.
  • #20 16701358
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    Theoretically, the hole for the thread for the size of the M 6 screw is the minimum diameter of the hole (and at the same time the drill) should be 4.917 mm, and the maximum is 5.153, and it is practically assumed that the hole (drill) for the M 6 thread is 5 mm. So if the M 5 bolts were screwed in there, everything is correct, the threads should be fairly good (not counting, of course, how the holes for the M 5 bolts are now made). If M 5 screws were screwed in there, then just if the holes with the "old thread" are not too machined, then selecting the old thread with a 4.9 mm drill bit, for a good threading, there should be a hole for the "full thread" M 6, i.e. as above he wrote "meat only" for the M 6 thread.
  • #21 16701363
    jack63
    Help: 851
    Rate: 2828
    The hole diameters alone are not enough. Find the pitch table M4, M5, M6 .... and compare.
  • #22 16701432
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    Well, I do not know so much, but for example a hole (drill diameter) for the thread M 6x0.75, tolerance 6H, that is, the minimum is 5.188 mm, maximum 5.378 mm, nominal 5.2. For the thread M 6 M 6x1, the diameter of the drill is given in the range of 5 - 5.1 mm, so it is also equal to the average of the "former bolt" (where the diameter is measured on the bolt on the "outer edge of the thread) and is 5 mm, i.e. everything is within tolerance with these holes.I am a layman in these matters, but the nominal hole for the M 5 thread is 4.2 mm in diameter and after tapping with a tap, the diameter of the hole itself does not change. whether a "threaded" hole or a hole drilled for the thread, we will not insert a rod much larger than 4.2 mm into it, i.e. as much as the thread core of the M5 screw, after all this thread is on the inner edges of the drilled hole. the thread is only about the diameter of the thread on the bolt. I don't know if I am thinking right or not. If not, please give me some simple explanation.
    jack63
    Help: 851
    Rate: 2828
    I cannot find any relation to your argument, neither with the topic nor with what I wrote. What do you mean?
    The author of the topic has to repair damaged threads with a homemade method. He planned to convert the M5 thread to M6 and probably M4 to M5.
    Since the threads are in a relatively soft material, if you don't need it, it would be harmful!
    Unfortunately, the pitches of the broken thread and the new thread are different and the threaded holes are "broken", so threading, despite the increase in diameter, will not provide the full height of the new thread. The outer part will be OK, but the part closer to the center of the hole will be shredded by a 1.0mm pitch thread with a 0.7 pitch thread.
    Therefore, it is better to apply pins and paste them permanently.
  • #24 16701742
    Bambek
    Rate: 93
    Gentlemen, take it easy. A simple workshop method for making threads is the thread diameter times 0.8, and we have the drill diameter in mm. For M6 so 6x0.8 = 4.8 we have 4.8mm drill bit. Do not look for fits in tolerance classes and in the 3rd decimal place this is not a thread on a micrometer screw (micrometer).
    For the purposes of this task, let's not open workshop guides ;)
    So I dealt with this crap. And so under the M6 I grabbed what was left with a 4.8 drill and under the M5 with a 4 mm drill. The threads did not come out perfectly. After the drill you could see literally the shadow of the old jump in the hole. Here Mr. Krzysztof was right.
    Recalibrating the holes with a drill was unfortunately a skill because without it, the tap was clamping after 3-4 turns.
    On a school scale of 1-6, I would rate it 4+ or 5- if you prefer. Only one of the most broken ovals was the stretched 3+. At the same time, these M5s came out great and this one M6 with an oval 3+. I made the pins of hexagonal screws improved 8.8, they can be screwed in freely. I put it on the glue I mentioned in post # 8. It all twisted very stiffly, no thread let go. I gave the studs nuts with a plastic insert, a spring washer, and I also screwed them on with glue. On top, I "smeared" the cap with a hermetic and now it is cooling down.
    The motor housing in the saw housing does not give off.
    I am still waiting for the delivery of the oil pump because, of course, when it all started, it got a cross and (the screw), i.e. the pump drive, also hit the road by cutting a little pump gear.
    PS If not everything was too easy, the rubber plug began to leak through which the fuel hose passes from the tank to the carburetor, I moved it as I unfastened the fuel hoses.
    Normally k &% / # and only have attractions ...!
  • #25 16701886
    Michał_74
    Help: 189
    Rate: 629
    Ordinary nitro paint on the thread to apply and screw on - old school and proven.
    And the hoses are leaking? Degrease the holes and new hoses 1mm larger. In the Chinese scythe, I have also been doing this since the application of calm. The fact that these hoses were paid for in my case and it was still terribly expensive.
    Greetings.
  • #26 16701979
    Bambek
    Rate: 93
    Greetings.
    It does not leak on the hoses, only around the circumference between the plug and the saw housing - the tank. To replace the cork, you need to choose one that is tighter by 1-2 mm.
  • #27 16702060
    kkknc
    Help: 1916
    Rate: 6721
    As for the threads, helicoil inserts can always be provided. Of course, there are also fine threads.
    As for adhesives, their holding drops significantly with the temperature. And if you have unbalanced elements that vibrate strongly, nothing will help. When they stop unscrewing, they will start to crack and so on.
    So sometimes combining doesn't do much. First, give a thread insert. And you don't need ordinary paint. Because you will get nothing more.
  • Loose tapped aluminum threads need a different fix
    #28 16702822
    E8600
    Help: 530
    Rate: 2532
    The topic developed. :)
    Coming back to the problem, if the new holes have been tapped with a finisher (taps are divided into: stripper, intermediate and finisher). There is not much that can be done anymore. Anaerobic adhesives will not help even the most expensive ones because the thread will be too loose. I have practiced 2 kinds in this case as has the author. 1 - screwing in screws without threading (Chinese aluminum is so soft that it threads itself from the screw (I advise against this method in places where it can break because there is little material). the threads unscrewed from vibrations there is paint but it requires drying. problems with cylinder sweating from the exhaust.
    Even from the old days I remembered hermetic for engines.
  • Linen tow and varnish resist vibration in aluminum threads
    #29 16702940
    wada
    Help: 168
    Rate: 732
    And from even older times, even watchmakers used torn threads, and even without re-threading, a few hairs of linen tow are wound on the screw (even very thin) and the varnish is screwed in - it can withstand a lot of vibrations and vibrations. I have a dozen or so M4 - M6 bolts screwed into the aluminum body in the lathe (more carbon and sand than aluminum), and it has been holding the entire gear and covers for over 25 years - and the vibrations are very high there.
    And the combination of hermetic and tow is a total cosmos :D To unscrew it, you need to heat the screw to over 450 ° C. The varnish softens and releases at over 200 ° C
    Elefant
    Wagonowa 34, Wrocław, 52-231 | Company Website: literyzmetalu.pl
  • Using FSO 1500 spark plugs as a workaround
    #30 16703768
    Michał_74
    Help: 189
    Rate: 629
    As for the tow. I used to have a SAM tractor, a Dzik 21 gearbox, a self-made frame and a 600cc Maluch engine. I broke the spark plug threads in the head and because I did not want to repair, I screwed in the candles from the FSO 1500 on the tow. The fact is different heat and all the rest of the other, including thread length, but kept over 4 years of garden work.
    So good nature won over our technique.
The discussion revolves around securing screws in a Powermat chainsaw, specifically addressing the issue of self-loosening due to vibrations. The user plans to convert M4 screws to M5 and M5 to M6, using 8.8 strength allen screws with nuts featuring plastic inserts to prevent loosening. Various solutions are proposed, including the use of thread-locking adhesives like Loctite, Nord-Lock washers, and alternative methods such as using silicone, poxipol adhesive, or even traditional techniques like using tow and varnish for added security. Concerns about the integrity of the aluminum body and the effectiveness of different adhesives under vibration are discussed, with suggestions for ensuring a permanent connection and preventing future loosening.
TL;DR: Up to 15 % preload is lost after 1 000 vibration cycles on un-locked screws [Loctite Data, 2023]; “With the correct bolt, it cannot be unscrewed” [Elektroda, misiek1111, post #16700181] Choose high-strength anaerobic threadlocker and/or Nord-Lock washers for M4–M6 threads in soft aluminium, then torque once, forget.
Why it matters: Preventing self-loosening avoids cracked housings, oil leaks, and costly re-tapping.
• Medium-strength (blue) threadlocker resists ‑55 °C → 150 °C and 20 N·m break torque on M6 bolts [Loctite TDS, 2023]. • High-strength (red) grades need 230 °C heat for removal [Henkel, 2023]. • Nord-Lock wedge washers maintain ≥90 % preload after 20 000 cycles (Junker test) [Nord-Lock, 2022]. • ISO 898-1 class 8.8 studs give 800 MPa tensile strength—3× soft Al-Si casting yield [ISO, 2013]. • Helicoil inserts restore 100 % thread strength; kit cost ≈ €25 per size [Böllhoff, 2024].
What adhesive works best for steel studs in a soft aluminium chainsaw body?
Use a high-strength anaerobic threadlocker (Loctite 271 or MA262) because it fills gaps and cures without air, giving up to 28 N·m break torque on M6 fasteners [Henkel, 2023; Elektroda, Bambek, #16700443].
Will muffler paste or high-temperature silicone stop studs from backing out?
No. Silicones and exhaust pastes are elastic sealants, not structural; they drop below 1 MPa shear strength and peel under vibration [Dow Silicone Data, 2023]. Threadlocker provides 10–25 MPa shear instead.
How hot can threadlockers safely run on a 2-stroke engine block?
Medium grades survive 150 °C; high-strength grades survive 230 °C, above typical 100–120 °C chainsaw crankcase temperatures [Loctite TDS, 2023].
Are Nord-Lock washers worth the extra cost on small M5/M6 screws?
Yes. Tests show 90 % preload retention versus 10 % for plain spring washers after 20 000 vibration cycles [Nord-Lock, 2022]. They cost ≈ €0.40 per pair for M6, cheaper than re-threading damaged housings.
Could I simply re-tap from M5 to M6 to regain strength?
Only if enough wall remains. Pitch mismatch shreds residual thread roots, giving 30–40 % strength loss [Elektroda, jack63, post #16701515] Use inserts or studs plus threadlocker when wall thickness <4 mm.
What is the cheapest functional alternative to branded Loctite?
Automotive K2 ProLok High or Beko Allbond deliver similar strength for under PLN 15 (€3) per 10 ml [Elektroda, wzagra, post #16700306]
Does tying bolts with safety wire work on chainsaws?
Safety wiring prevents nut rotation but not stud pull-out. Without sound internal threads, vibration will still strip aluminium [Elektroda, Anonymous, post #16700898] Combine wire with threadlocker for critical fasteners.
Edge case: What if the engine regularly exceeds 230 °C?
Above 230 °C anaerobic adhesive degrades. Use all-metal prevailing-torque nuts or stainless Helicoil inserts rated to 425 °C [Böllhoff, 2024].
Three-step how-to: applying threadlocker correctly
  1. Degrease male and female threads with brake cleaner; blow dry [Elektroda, jack63, post #16700916]
  2. Apply one drop to 360° of male thread near tip.
  3. Assemble and torque; wait 24 h for full cure.
Can linen tow plus varnish really hold threads?
Yes. Tow fibres act as mechanical keys; varnish hardens, withstanding vibration for decades in machine tools [Elektroda, wada, post #16702940] However, removal needs >200 °C heat and time.
How much torque should I use on class 8.8 M6 studs in aluminium?
Limit to 10 N·m—about 60 % of steel spec—to avoid stripping soft threads, then rely on chemical or wedge locking [ISO 2320, 2015].
What’s the fastest field repair if I lack threadlocker?
Brush nitrocellulose paint onto the screw, assemble while tacky. It provides moderate friction and cures in 10 min [Elektroda, Michał_74, post #16701886] Strength is 50 % of proper adhesive, so inspect often.
Do Helicoil inserts work with fine-pitch M5×0.5 threads?
Yes. Fine-pitch Helicoil Plus inserts exist down to M2.5 and restore full load capacity in soft metals [Böllhoff, 2024]. Kit requires special tap and installer.
What failure sign tells me the adhesive bond is gone?
If the first ¼-turn loosens with <20 % of original torque, adhesive shear has failed; replace immediately [Loctite Guide, 2023].
