Finding 2.5mm x 3.5mm Cross-Countersunk Head Screws for Repair & Upgrade of Electrical Devices
slepy29 38345 14
Where can I buy a 2.5 mm diameter, 3.5 mm long cross-countersunk screw for repairing a small electrical device?
You can usually get this kind of screw from a specialty fastener supplier or by salvaging it from old electronics. One reply recommends srubex.com as a place that rarely lacks uncommon screws [#9260144], and another mentions TME as carrying similar small screws/threads from about 1.6 mm upward [#9261731] If you cannot buy one directly, people suggest taking them from computer equipment, DVD laser modules, cameras, or camcorders, where these small screws are common [#9261403] Another practical source is old devices from municipal e-waste collection points, such as computers, appliances, and printers [#9261560]
  • #1 9260115
    slepy29
    When repairing or upgrading electrical devices, it may happen that we need a really SMALL screw. That's my problem.
    I broke the thread in a screw with a diameter of 2.5 mm, length of 3.5 mm, cross-countersunk head. Thread about 0.5mm.
    Where the hell should I get such a new one?
  • #3 9260788
    lukas12
    Help: 5
    Rate: 54
    Go to an hardware store or something like that, maybe they'll have it there :!:
  • #4 9261161
    Tommy82
    Help: 455
    Rate: 1074
    With this type of surprises, the most helpful is the recovery of clocks or voltmeters from some toys or watches. If you hit something inch, acid is the worst.
  • #5 9261164
  • #7 9261403
    c4r0
    Level 36  
    Help: 155
    Rate: 565
    2.5mm in diameter is not such a small stub. 1mm would be small. Whenever I "demolish" something, I collect such screws and throw them into the box of ticks :D I already have two full ones, and more than once I have found some valuable "replacement" screws there. You can find this type of screws in computer equipment (I have dealt most with DVD laser modules - there are a lot of screws, but they are usually varnished) or in cameras and camcorders.
  • #8 9261525
    retrofood
    Help: 1140
    Rate: 4800
    Motronic wrote:
    With the disassembly of other devices. If someone thinks that he will buy 2mm 2.2 or 2.4 screws in iron, someone is probably not serious.
    The nearest warehouse is from the subway. Entire shelves.
  • #9 9261543
  • #10 9261560
    ziemek56
    Help: 24
    Rate: 186
    From time to time, you should approach the municipal problem waste collection point and take the old computer, household appliances, and printer from them, and then return them in small amounts.
    Nipples, bolts, nuts, ... miracles, wreaths otherwise impossible to get, on the order of 2.5 to 4 mm.
    Cost: flower or beer = depends on the employee (ca).
  • #11 9261615
    radio-service
    Help: 229
    Rate: 212
    And I thought that it would be enough to call the shop where he supplies himself and to which I gave the link. And here are so many options.
  • #12 9261636
    ziemek56
    Help: 24
    Rate: 186
    I'm sorry, but in the screwdriver in Szczecin (very often) they only have 4.0 ... sometimes 3.5. I can see the Warsaw city by its location is "focused" and "mine" focuses on mechanics - you can buy even 30.0
    That's why I throw away something only after I remove all the threads.
  • #13 9261731
    andrzej lukaszewicz
    Help: 626
    Rate: 2126
    Oh, electronics ... Most of the mechanics are wrong ... (Motronic is about to pounce ...) In TME, where you often look, there is this product from a meter, various threads from 1.6 up ...
    I still have supplies from the famous BOMIS, M2, M2.5, 2.6 and various quirks ...
  • #14 9264319
    xml2000
    Help: 9
    Rate: 20
    I solve this type of problem with glue, for example Poxipol, I pour the thread carefully, then screw it in, wait until it sets (enough to unscrew it, but not to "pull" behind the screw) and I have a perfectly matched thread.
  • #15 9265000
    slepy29
    Ok thanks for the answers. I wrote to Śrubex, maybe I will see it in TME.
    To close.
The discussion revolves around sourcing 2.5mm x 3.5mm cross-countersunk head screws for repairing or upgrading electrical devices. Users suggest various solutions, including checking specialized suppliers like Śrubex and TME, visiting local hardware stores, and salvaging screws from old electronics such as computers, cameras, and toys. Some participants recommend collecting screws from disassembled devices or municipal waste collection points. Additionally, one user mentions using adhesive like Poxipol to repair stripped threads as a temporary solution.
