LG 37ED450 TV Not Detecting Pendrive: USB Device Connection Failed - Troubleshooting Steps
19Yakuza46 30120 5
  • #1 16700560
    19Yakuza46
    Hello, I have a LG 37ED450 TV set.
    I recently wanted to connect a USB flash drive to watch the video but unfortunately I encountered a problem in the form that connecting USB flash drive pops up and message appears on the screen, the connection with the USB device failed to remove the device and try again. I pulled them out several times and it did not help my buddy, I also checked the pendrive does not work, I formatted it and nothing. I do not know what else could cause
  • #2 16700670
    mr_slimm
    Help: 9
    Rate: 12
    What file system do you have on a USB stick?
    Some hardware can not cope with NTFS. Try FAT32 or ExFAT.
  • #3 16701054
    1 PAWEL
    Help: 674
    Rate: 1364
    LG 37ED450 type in correct name tv some may not support certain formats of USB memory.
  • #4 16705809
    19Yakuza46
    pendraiv has the FAT32 file format
  • #5 16705861
    mr_slimm
    Help: 9
    Rate: 12
    Well, he should manage it. And you checked other USB sticks?
  • #6 16705894
    E8600
    Help: 529
    Rate: 2520
    How much GB does this pendrive have? When was the pendive formatted? If you do not remember, start with the format because the file system may have spilled out (it has errors).
