Toyota Auris MMT Gearbox: Adaptation Instructions, Clutch Replacement & N Flashing Issue
leonek4 23688 7
  • #1 16701889
    leonek4
    Help: 104
    Rate: 638
    Hello!
    I need a detailed gearbox adaptation / initiation instruction.
    After the clutch is replaced, no gear is engaged, "N" flashes after ignition.
    The car fires but no reaction to the gas pedal, only slow revolutions. Does this fault have something to do with the lack of adaptation of the box ???
    bandi21
    Level 30  
    Help: 126
    Rate: 655
    If nothing is broken during the exchange, then adaptation remains. An intelligent tester or technician is needed.
    manta
    Help: 463
    Rate: 1533
    Adaptation, the driver does not see the transmission. Launch will do it. One question, are you sure you have put a hold on this box? Unfortunately, it differs from the usual, also priced ...
    bandi21
    Level 30  
    Help: 126
    Rate: 655
    the box was removed without putting into service and this is the main mistake. The clutch actuator is probably not right because it was definitely unscrewed from the box. It is possible to adapt this box without a diagnoscope only with the aid of a gear shifter but I do not get it too complicated.
  • Bad gearbox adaptation caused no gear indicator response
    #6 16703845
    leonek4
    Help: 104
    Rate: 638
    After several dozen hours of torture with manual adaptation.
    The initiation / adaptation of the ECU and the clutch moved immediately, the problem was with the adaptation of the box. After the bad adaptation of the chest, there is no icon from the chest position and no response to the gas pedal. Disconnection of aku for a few hours and from the beginning until the effect. Without a tester, it can only take much longer and nothing can be omitted in the procedure with the gear shift lever.
    bandi21
    Level 30  
    Help: 126
    Rate: 655
    I used to try the lever a few times in my life and never managed to do anything. I'm reprimanding for patience because I'm over the top.
  • MMT clutch actuator adjustment and calibration steps
    #8 21651798
    siemensol831
    The answer is simple. In this situation, we do an adaptation. If the N is still flashing, it means that you need to adjust the clutch actuator, or actuator, so that it pushes harder on the fork to push the clutch in harder. In the Toyota Auris, you have to push as far to the right as possible. If still nothing, you can push lightly on the fork with some kind of rod, move the actuator and tighten. I'm sure it will work.
    Instructions from calibration can be found if you have a problem.
    I insert the cable into pins 4 and 13 and we wait about 10-15 seconds. We turn the ignition switch. We wait again for about 10 seconds. We quickly press the brake pedal a minimum of 7 times until the computer beeps. We shift the gear lever into manual. Minus 4 times, holding the brake all the time.
    We return to neutral. Let go of the brake. Press in once. The computer beeps again a few times. Release the brake and press 3 times quickly. The computer should beep several times. Switch off the ignition.
    Wait a minimum of 10 seconds. Remove the cable from the pins. Turn the ignition without firing up and without the brake. You should hear the gears changing. Wait for about 50 seconds after turning the ignition. Then turn the ignition off and start the car with the brake pressed. N should flash a maximum of 3 times and illuminate permanently.
Discussion about Toyota Auris MMT gearbox after clutch replacement, where no gear engages and the N indicator flashes after ignition. The car starts but does not respond to the accelerator and only idles slowly. The main cause identified is missing or incorrect gearbox adaptation/initiation after clutch or actuator work. Responses recommend performing adaptation with a diagnostic tester such as Launch, or using a manual calibration procedure via brake pedal and gear lever if no tester is available. The follow-up confirms that ECU and clutch adaptation succeeded, but the gearbox adaptation was the critical issue; after incorrect adaptation there was no gearbox position icon and no throttle response. Disconnecting the battery and repeating the procedure from the beginning was also mentioned.
