toyota / avensis / t25 - Automatic gearbox not working - no response.
Łysoldrift 11520 8
  • #1 16326170
    Łysoldrift
    Rate: 178
    Auto avensis t25 2.0 petrol with automatic year 2003.
    Car bought with damaged gearbox - also no history.
    When I put in d or r, zero reaction speed does not drop (to want to move.)
    The oil in the gearbox is - is the scoop.
    If I disconnect the battery and the back scream, it goes backwards correctly.
    AS I bother nothing - no reaction.
    As I turn off or yells P - then neither reverse nor to the rush no longer goes.
    The computer was attempted to read and can not - no connection - unless the equipment fails.
    Where can you possibly look for a gearbox driver?
    What, if necessary, check further so that it is known whether the box is to be repaired or another defect?
    Fuses and relays - spr.
    Plugs on the chest - all right.
  • #2 16326453
    MarcinS70R
    Help: 52
    Rate: 290
    It would also fit some other hardware to read the error codes.
  • #3 16327221
  • #4 16327447
    Łysoldrift
    Rate: 178
    I checked the oil level - transparent, unburned oil level.
    From what I learned, the gearbox controller is together with the engine driver as one module.
    No errors.
  • #5 16327679
  • #6 16333082
    Łysoldrift
    Rate: 178
    Behind the storage space I found only the engine controller, light module and some smaller controller but certainly not from the box.
    This engine is 89661-05750
    Added after 13 [hours] 15 [minutes]:
    I called the Toyota service and was told that the engine and transmission controller are indeed one module.
  • #7 16335284
  • #8 16335384
    romuald-f
    A/T specialist
    Help: 407
    Rate: 1551
    Before you start any work on the box, check if it will start in emergency mode (third gear + reverse). Disconnect the plug (rectangular) at the gearbox from the solenoid valves.
  • #9 16524865
    Łysoldrift
    Rate: 178
    Thanks for the hints.
    Chest damaged mechanically - for replacement.
The discussion revolves around a 2003 Toyota Avensis T25 with a malfunctioning automatic gearbox. The owner reports no response when shifting into drive or reverse, despite checking the oil level, which is clear and unburned. Attempts to read error codes from the vehicle's computer were unsuccessful, leading to inquiries about the gearbox controller, which is integrated with the engine controller. Suggestions include checking the solenoid valve plate for pressure issues, verifying if the vehicle can start in emergency mode, and considering a replacement gearbox due to mechanical damage. The owner confirmed the need for a replacement after further investigation.
