Mazda 6 2.0 03r in Emergency Mode, Error P0093: Fuel Flow Issue, Engine & Traction Light On
marfal4 6324 2
  • #1 16702257
    marfal4
    I am asking for help, 3 mechanics have already failed.
    After the engine warms up, it enters the emergency mode (mazda 6 2.0 2003) and the engine and traction light comes on and the fuel flow error pops up (after cooling, these lights are still on, but there is no emergency mode). it all started with a worn tooth on the shaft and the mechanic, before he figured out what it is, he was looking for 2 weeks and after the repair there are these circuses.
    what was done / checked:
    -Total regeneration of 2 injections and cleaning the rest in an authorized service center (after checking the transfer, everything is +)
    - replacement of the fuel filter, SCV valve and high pressure turbine
    - the pressure, fuel flow and power rail for injections have been checked
    - replacement of injection seals and valve seals
    - verified transfers on a cold and warm engine and everything is cool only when checking on the computer with a warm engine 1 of the injectors does not work 2 weakly and 2 high above the level.
    The last mechanic said that the only option could be injection coding and until the next one he returns with a computer problem and should be deleted.
    I am asking for advice, maybe someone has already had such a situation, because so far he is spending money on buying parts that do not change anything.
  • #3 16703307
    marfal4
    "I changed the fuel filter with the housing and the car zapier ...." so that was the reason in your case? only as I marked the fuel filter replaced with the housing because, as I know, there is no other model for this model, but all the luck that you succeeded because I am so lucky I do not have 2 bellows without a car and I have already spent 2k, fortunately I had injection regen after acquaintances in one of the best companies in Poland
