Handling Ford Mondeo 2007 2.0 Petrol's Emergency Mode & Lame Condition: PCM Errors P0607, P2110
kamiloooxxx 11667 2
  • Check PCM power, grounds, and wiring continuity
    #1 17347662
    kamiloooxxx
    Rate: 48
    Hello. Today on the wallpaper I have a Mondeo from 2007 2.0 petrol 145KM. The problem is that the car at idle speed or after adding gas and slowing down, goes into emergency mode and is terribly lame. Errors in PCM: P0607, P2110
    === PCM DTC P0607: 00-A8 ===
    Code: P0607 - Efficiency of the control module
    Status:
    - Pre-set DTC - Not present at time of command.
    - The fault indicator light is on at this DTC
    Module: Engine Control Module (Power Train Chain Control Module).
    === END PCM DTC P0607: 00-A8 ===
    === PCM DTC P2110: 00-A8 ===
    Code: P2110 - Throttle actuator control system - forced RPM limit
    Status:
    === END PCM DTC P2110: 00-A8 ===
    === OBDII DTC P0607-C ===
    Status:
    - Confirmed - the fault is confirmed
    Module: On-Board Diagnostics II
    === END OBDII DTC P0607-C ===
    The throttle has already been replaced with a new one. Installation from the damper to the controller checked. I suppose the throttle error crashes because the car goes into emergency mode. The power supply and ground to the motor controller have been checked. Any hints what else to check? Maybe someone had a similar case?
  • #2 17991341
    czesterek
    Rate: 80
    Have you dealt with this problem? Because I have the same :(
  • #3 19592391
    PojsoNQ
    Rate: 33
    Hello, I also have this problem and I don't know what to do?
