[Solved] Mazda 6 2.0 Petrol + LPG: Engine Jerking at 2000 RPM, Throttle & Flow Meter Cleaned, Tested
pucian 8454 4
  • #1 16715306
    pucian
    Rate: 12
    I have a problem with the above-mentioned car. 2.0 petrol + gas engine, 6-speed gearbox version. The problem occurs when driving at about 2000 revolutions, you can feel the jerking of the engine on the steering wheel and in the seat. This is quite annoying. There is no problem at higher revs. Throttle, cleaned, also tested on another and the same, flow meter, cleaned and replaced, candles replaced. The problem occurs on gas and petrol, even more so on petrol. What could be the reason? I would also like to add that when I start the car and the engine idles, you can hear it every now and then when it is choking. Maybe something has to do with the other? Please help.
  • #2 16715319
    szwagros
    Help: 232
    Rate: 271
    And any diagnostics? Is it only replacement for a stick?
  • #3 16715340
    pucian
    Rate: 12
    After connecting to the computer, nothing shows completely, everything is normal, checked by two mechanics. And replaced, preventively cleaned, to exclude.
  • #4 16716858
    gregorius-up4
    Rate: 16
    In this engine, valve clearances are regulated by replacing glasses of the correct thickness.
    Maybe it's worth checking if your valves are not supported.
  • #5 17095863
    pucian
    Rate: 12
    The problem turned out to be unsealing at the negative pressure.
