Lenovo P2 Won't Turn On: Red LED, Vibrations, Not Recognized by PC - Battery or Motherboard Issue?
limonkowyfaz 4554 3
  • #1 16708091
    limonkowyfaz
    I have got Lenovo P2 for a year. A month ago I just turned it off and hasn't worked since. After connecting to the charger, the LED lights up red, then goes off and the phone vibrates every 10-20s, the computer does not see it, the same happens when I disconnect the phone from charging, it vibrates until the battery is discharged. Today, I disassembled the phone, removed the battery and connected to the computer, the phone vibrated several times with high frequency on the screen there was information that the PC does not recognize this device. Is this a sign of a defective battery or a motherboard failure?
  • #2 16708110
    nutergsm
    Help: 1034
    Rate: 1665
    You had to give it in for a warranty repair. Check battery voltage.
  • #3 16708126
    limonkowyfaz
    I do not have a guarantee due to the cracked screen, I will check well soon.
  • #4 16830173
    zuBerSTW
    Hey buddy I have the same problem. ... did you untie him?
