Huawei P8 Lite Won't Turn On: Red and Green Diode Blinking, Detected by Computer
misiekmik 15303 10
Why does a Huawei P8 Lite only blink red and green LEDs and not turn on, even though it is detected by the computer?
The phone is likely suffering from a deeply discharged battery: leave it on the charger for 24 hours or try a stronger charger, because 3V is too low [#16423399][#16425084] If that does not help, test the phone with another battery [#16425688] If it still shows the same red/green blinking, try flashing new firmware [#16427511]
  • #1 16423366
    misiekmik
    Rate: 26
    Hello, I have a problem with the Huawei p8 lite. The phone does not want to turn on when you press the switch, the red diode blinks alternately with the green one and that's all you do not want to enter. The cover is detected by the computer. The phone was bought used as if it was a wine program or memory.
  • #2 16423399
    qpalzmwoskxn
    Hold it on the charger for 24 hours.
  • #3 16424940
    misiekmik
    Rate: 26
    Nothing gave as I roll it just after flashing alternately green red and nothing 0 reaction battery has 3 amps not inches
  • #4 16425084
    nutergsm
    Help: 1034
    Rate: 1665
    misiekmik wrote:
    the battery has 3 amps not inches
    Rather 3V and not Ampera. It is too discharged, plug the charger with more power.
  • #5 16425492
    misiekmik
    Rate: 26
    Should not the LED be on all the time? In my case it will light up and blink alternately green, red in this way as it plugs in and then goes out.
  • #6 16425688
    nutergsm
    Help: 1034
    Rate: 1665
    It would fit to substitute other batteries and then check.
  • #7 16425789
    misiekmik
    Rate: 26
    Should the LED light up while charging all the time?
  • #8 16427502
    misiekmik
    Rate: 26
    I've connected a new battery and it's not the same, it's not the fault of the boot loader because 1 person suggested it to me.
  • #9 16427511
    nutergsm
    Help: 1034
    Rate: 1665
    Try to upload a new firmware, but rather a CD to be replaced.
  • #10 16427522
    misiekmik
    Rate: 26
    Any ideas what you can try yet
    I never uploaded to huaw, I do not know much
  • #11 16434503
    misiekmik
    Rate: 26
    I sold the end of the phone topic
The Huawei P8 Lite is experiencing a failure to power on, indicated by alternating red and green LED blinks, while being detected by a computer. Initial suggestions include charging the device for 24 hours and using a charger with higher power. The user confirmed that the battery is not the issue, as they have tried a new battery without success. Further recommendations involve checking the firmware and considering the possibility of a faulty bootloader. The user expressed uncertainty about uploading firmware due to lack of experience.
