Lenovo Z710 Laptop Fall Issue: Won't Turn On, Power & Webcam LED Blinks, BIOS & Drive Detection
MrDoimer 5346 16
What could have happened to a Lenovo Z710 after it was dropped, when the BIOS sometimes stopped detecting the drive and later the laptop only briefly lit the power/webcam LEDs and would not start?
The most likely cause is physical damage on the motherboard from the fall, especially cracked BGA/chipset solder balls or other broken board connections; the BIOS chip could also be damaged, and on some Lenovo models a dead BIOS battery can prevent startup [#16654757] [#16655358] [#16656557] Before any rework, measure the laptop’s startup current and identify the exact motherboard model, because that helps distinguish a power-sequence fault from a board-level short or chipset problem [#16654747] [#16655483] If the board connections under the chipset are broken, simply heating it will not fix the fault; reballing only helps when the chip’s balls themselves are the problem [#16655483] [#16655768] The fact that the boot menu later showed only network boot also points toward chipset or BIOS/input damage rather than a normal drive issue [#16655358] In the worst case, the drop may have caused microcracks in the PCB tracks, making the board only suitable for parts [#16655358]
  • #1 16654739
    MrDoimer
    Help: 271
    Rate: 125
    A friend provided me with a laptop as in the subject. Her laptop fell from a height of about 1.5 m. The effect is that sometimes the BIOS did not detect the drive at all, and sometimes the system fired normally. I had 5 minutes to sit with it and wanted to run Linux Live from USB. Several times I turned the laptop on and off from the button. After some time, it suddenly does not give a sign of life except for the "Power" diode for 1 second and the webcam diode will flash for a fraction of a second.
    What could have happened? Of course, I tried to remove the battery, fire from the power supply itself, etc., but nothing is still the same.
  • #2 16654747
    xoree
    Level 30  
    Help: 129
    Rate: 174
    What current does the laptop consume at startup?
  • #3 16654757
    Dydelmax
    Help: 654
    Rate: 965
    Enter the designation of the motherboard.
    MrDoimer wrote:
    The effect is that sometimes the BIOS did not detect the drive at all, and sometimes the system fired normally. [...] After some time, it suddenly does not give a sign of life, except for the "Power" diode for 1 second and the webcam diode will flash for a fraction of a second.
    It is possible that the balls under the chipset broke off as a result of the fall - heat it up diagnostically with a hot air soldering iron for several seconds and check the results.
  • #4 16654820
    xoree
    Level 30  
    Help: 129
    Rate: 174
    I wouldn't heat it right away.
    The bios charge could still be damaged.
  • #5 16655298
    MrDoimer
    Help: 271
    Rate: 125
    When I am at home, I will measure the power consumption.
    I note that it does not have tools such as hot air.
    I would like to know how it is possible that the laptop suddenly stopped working when it turned on until recently.
    It is true that sometimes at the start of the Lenovo logo, it was restarted.
    I would like to add that after connecting the pendrive from Linux Live, after entering the Boot menu, the only option of booting from the network was visible, so I could not even start Linux.
    Anything else I can do at home?
    Thank you for your answer.
  • #6 16655358
    Dydelmax
    Help: 654
    Rate: 965
    This may indicate damage to the chipset or its connection to the board. It can also be a problem with the BIOS input - the programmer is necessary here (at home it can be assembled from an LPT plug and a few resistors - https://www.elektroda.pl/rtvforum/topic2602823.html).
    You specialize in "computers, electronics", so I think you'll find a match. ;)
    The worst possible scenario may be the failure of the plate as a result of microcracks in the tracks due to a fall - then the plate may only be suitable for donating parts.
  • #7 16655424
    MrDoimer
    Help: 271
    Rate: 125
    Stationary :D
    Dydelmax wrote:
    so I think you will find a match.
    A dryer with a narrow nozzle probably won't work, right :) ? I won't find anything else.
    Moderated By RADU23:
    All types of household appliances are not devices used to repair computer components. We do not talk about them in the "Computers" sections.
    I understand that the only way to be sure this is by heating the circuit? Apart from the possible damage to the BIOS.
  • #8 16655483
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1541
    From the fall?
    If the connections under the system were broken, heating will not do anything.
    No.
    You were supposed to give the power consumption, the plate designation.
  • #9 16655495
    MrDoimer
    Help: 271
    Rate: 125
    If the laptop is handed over for reballing (they have a 3-month warranty on offer), what does it look like? They will heat up and say "no sorry, but the connections under the system have broken off, so $$ and goodbye"?
    I won't make it today, but I will provide this data tomorrow.
  • #10 16655768
    xoree
    Level 30  
    Help: 129
    Rate: 174
    boro1234567 wrote:
    From the fall?
    Not from a fall, but from switching off and switching off during the diagnosis (he walked - he stopped walking).
    Added after 11 [minutes]:
    No Reball involves removing the old binder (usually lead-free to lead-based binder) and replacing with the new one. Of course, it has a positive effect if the balls in the core of the BGA chip are not damaged.
  • #11 16656523
    ul1002
    Help: 303
    Rate: 138
    Of course, the bios may spill out from the fall, it springs out spontaneously under the influence of such interference as a fall, all the more so. However, the fault indicates broken pads under the BGA. greetings
    Almar Serwis Roland Piszczelok
    Gliwicka, Rybnik, 44-200 | Tel.: 506XXXXXX (Show) | Company Website: www.almar-serwwis.pl
  • #12 16656530
    xoree
    Level 30  
    Help: 129
    Rate: 174
    Maybe, but unlikely, rather constant switching on and only damaged the batch.
  • #13 16656557
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    In some, Lenovo will not start if the bios battery is dead. Maybe somewhere she got hit after the fall?
  • #14 16726706
    MrDoimer
    Help: 271
    Rate: 125
    Welcome back!
    A friend took the laptop for service, but it is a "neighborhood shop" and she did not even receive a repair report. She claims that "they exchanged some arrangement" and she paid PLN 300. I think they probably did reballing. Now the laptop turns on and works, but only the USB3.0 ports are working (!) [On the left side, both] and on the right side USB 2.0 shows no sign of life.
    Sound is also not working. The drivers are all there, no yellow exclamation marks in the device manager. In the audio mixer, you can see the system "deliver" the sound, but you can't hear anything. No response after plugging in the headphones.
    The service told her, when she reported the above-mentioned faults, that "they got a laptop with a symptom of not turning on and they took care of it" ....
  • #15 16726776
    Dydelmax
    Help: 654
    Rate: 965
    MrDoimer wrote:
    Now the laptop turns on and works, but only USB3.0 (!) [Left side, both] ports are working, and on the right, USB 2.0 shows no sign of life.
    The fragment I bold could give hope that the website forgot to plug in the tapes from the PCB with USB and 3.5 mm Jack sockets. However, I do not want to believe that they did not connect the speakers either.
    At the moment, the words of a colleague may be prophetic boro1234567 :
    In the service, they apparently ended up heating up ...
  • #16 16727054
    xoree
    Level 30  
    Help: 129
    Rate: 174
    You need to check the series and year of production of the system + see if there are any traces of soldering (flux, damaged laminate of the system - from the reball as they screwed into the stand).
  • #17 16727805
    slawmix1234
    Level 32  
    Help: 130
    Rate: 102
    Advertise the service or demand a refund because for such an amount it should be like from the factory, I do not tolerate bungling and incompetence
The Lenovo Z710 laptop experienced failure after a fall from approximately 1.5 meters, leading to intermittent BIOS detection issues and eventual complete power failure, indicated by blinking power and webcam LEDs. Users suggested potential causes including damage to the chipset, broken connections under the motherboard, or BIOS corruption. Recommendations included measuring power consumption and considering reballing as a repair option. After service, the laptop was operational but exhibited issues with USB 2.0 ports and audio output, raising concerns about the quality of the repair and possible oversight in reconnecting internal components.
TL;DR: A 1.5 m fall can leave a Lenovo Z710 that "does not give a sign of life," with only brief power/webcam LED flashes. Start by checking chipset/BGA integrity, BIOS health, and I/O board cabling. [Elektroda, MrDoimer, post #16654739] Why it matters: This FAQ helps Lenovo Z710 owners quickly triage no-boot, LED-blink, USB/audio loss, and BIOS/drive-detection issues after a drop.
What does a 1-second power LED and webcam blink mean after a fall?
Combined with intermittent drive detection, this pattern points to board-level issues. A frequent culprit is a disturbed BGA/chipset joint from impact. Technicians often start by confirming chipset connectivity before pursuing storage or OS causes. This aligns with reports linking such symptoms to chipset connection problems after mechanical shock. [Elektroda, Dydelmax, post #16654757]
How do I check startup power consumption to narrow the fault?
Record the current draw at power-on using an inline meter or bench supply with ammeter. Technicians request this first because abnormal inrush or early drop-outs help isolate shorted rails, CPU initialization, or chipset faults. Share the reading along with the motherboard designation to speed diagnosis. [Elektroda, xoree, post #16654747]
Is heating the chipset a real fix or only a test?
Heating is not a repair. It may briefly restore contact, but if BGA connections are broken, "heating will not do anything" long term. Proper repair requires rework or replacement. Use heating only as a diagnostic hint, not as a solution. [Elektroda, boro1234567, post #16655483]
What is reballing and when does it help?
Reballing removes the original solder balls and replaces them, often with a different alloy. It helps only if the internal chip balls and die are intact. If core or substrate damage exists, reballing will not restore function. "Reball involves removing the old binder... and replacing with the new one." [Elektroda, xoree, post #16655768]
Could BIOS corruption be the reason it won’t start?
Yes. Technicians flagged possible BIOS damage following repeated on/off cycles during diagnostics. A compromised BIOS can stop boot, hide devices, or reset mid-logo. Address BIOS health before chasing OS issues. [Elektroda, xoree, post #16654820]
How can I reflash or verify the BIOS at home?
Use an external programmer to read, back up, and write a clean BIOS image. One approach uses a simple programmer build and clip access to the chip. Flashing bypasses a bricked onboard process and restores known-good code paths. [Elektroda, Dydelmax, post #16655358]
Only USB 3.0 works, but USB 2.0 and audio are dead—what does that imply?
This points to a disconnected side I/O daughterboard cable or incomplete post-repair checks. USB 3.0 ports on the left may be mainboard-native, while right-side USB 2.0 and 3.5 mm jack sit on a cabled board. Re-seat ribbons before deeper board repair. [Elektroda, Dydelmax, post #16726776]
How do I check the right-side USB/audio daughterboard connection?
  1. Power down, unplug AC, and remove the main battery.
  2. Open the bottom cover; locate the ribbon to the right-side USB/audio board.
  3. Re-seat the ribbon and lock the latch; reassemble and test ports and sound. [Elektroda, Dydelmax, post #16726776]
What details should I provide for faster help?
Share the measured startup current and the exact motherboard designation. Repair pros ask for these first to map symptoms to power rails and board revisions. This shrinks guesswork and targets known failure clusters. [Elektroda, boro1234567, post #16655483]
Why does the boot menu show only network boot after inserting a Linux USB?
That behavior can indicate chipset connection issues or corrupted BIOS input, which blocks USB media enumeration. In such cases, confirm chipset health and consider BIOS programming before blaming the USB stick. [Elektroda, Dydelmax, post #16655358]
Can a dead CMOS/bios battery stop certain Lenovo laptops from starting?
Yes. Some Lenovo models refuse to start with a depleted CMOS battery, especially after a shock. Check and replace the coin-cell if the system shows no progress or loses clock and boot settings. [Elektroda, xury, post #16656557]
What’s the worst-case scenario after a 1.5 m drop?
Microcracks in motherboard traces can cause intermittent or permanent failures across subsystems. If present, the board may only serve as a parts donor because such fractures are widespread and uneconomical to repair. [Elektroda, Dydelmax, post #16655358]
I paid PLN 300, and now audio/USB 2.0 still don’t work—what should I do?
Request a proper repair report and invoke the shop’s warranty or ask for a refund. Quality repair should restore full function or clearly document limitations. Insist on accountability for any post-service regressions. [Elektroda, slawmix1234, post #16727805]
Did repeated power cycling during testing make things worse?
It can. Members noted constant switching could corrupt the BIOS batch, compounding faults seen after the fall. Minimize power cycling during diagnostics and move promptly to structured tests and firmware checks. [Elektroda, xoree, post #16656530]
