Vw golf vi 1.6 tdi cayc - Starts hard, new injectors have high corrections
dyzma46 6417 3
  • #1 16710944
    dyzma46
    Hello, golf after cooling the engine down (usually after the whole night stopped in the garage) while firing the stove in gray. The smoke is so strong that you can see it in the rearview mirror, it smells of unburnt oil. The car does not have dpf, the computer does not crash any errors, the new vcds injection shows corrections from -0.4 to +0.6. This happens regardless of the outside temperature. It also happens that it will fire without any problems and will not even let go of smoke. What can this be caused and why do new injectors have such corrections?
  • #2 16711208
    piotrek gti_abf
    Help: 7
    Rate: 37
    Injector corrections do not always suggest damage. They can be a sign of engine wear, so I suggest measuring the compression pressure in the cylinders.
  • #3 16711277
    dyzma46
    Compression was measured and is equal
  • #4 16715412
    sebap
    Help: 538
    Rate: 1078
    dyzma46 wrote:
    is equal
    So what?
