VW Passat B5 1.9 tdi 101 km - Description of the parameters of unit injectors in
stacjapawel 8259 17
Why does my VW Passat B5 1.9 TDI smoke white on cold start and show a cylinder 2 misfire/correction value of 2.99 in block 13?
Block 13 injector corrections show cylinder contribution, not injector quality, so a value of 2.99 on cylinder 2 points to a cylinder/power issue rather than proving a bad injector [#16380544] Check compression first; the suggested healthy range is 25–31 bar [#16381923] If compression is OK, swap injector 2 with another cylinder and see whether the fault follows; if the value stays on cylinder 2, inspect the injector-to-ECU wiring and the shaft/cam condition [#16382409][#16382500] Since the oil level is rising, also check the pump injector O-rings and the tandem pump, because fuel can get into the oil there [#16392464][#16392601] White smoke on cold start can fit with this kind of fuel leak or injection sealing problem [#16392464][#16392601]
  • #1 16380127
    stacjapawel
    Rate: 11
    Hello, I recently bought a Passat 1.9 tdi 101 km AVB from the beginning, when the engine was cold, it started to smoke white after a few minutes as it got hotter.Everything was ok. I connected the car to the vag and showed me error 16686 (Cylinder 2 - misfire) in group 13 - the cylinder 1,3 and 4 were in the range, while the 2 had a result of 2.99 and it did not even tremble after replacing the unit injector at the first firing, it still smoked, I deleted the vag, I drove a few kilometers so that the engine warmed up and in group 13 it was still on cylinder 2 there is the same value I will add that group 18 is ok and 23 all values are below 30. Please help me because I have already invested some money and I do not know what to do next
    best regards
  • #2 16380544
    WBART
    Level 19  
    Help: 20
    Rate: 156
    Injector corrections are an indicator of cylinder power and not the quality of the injectors. Check compression, combat condition and hydraulics.
  • #3 16380584
    stacjapawel
    Rate: 11
    Ok and what should be the correct compression
  • #4 16381923
    toku74
    Help: 123
    Rate: 727
    Compression 25-31 bar
  • #5 16381987
    matimon22
    Help: 51
    Rate: 336
    And you have not replaced the turbine recently ??
  • #6 16382063
    stacjapawel
    Rate: 11
    yes in the same, and could it have any meaning? The car is still smoking with white smoke as it is cold after warming up like a weed in the vagu, still in block 13 on the second cylinder, the value of 2.99 although it drops to 2.1 more than once, I don't know.
  • #7 16382101
    moto-kord
    Help: 137
    Rate: 504
    Well positioned injector pins in the plug checked.
  • #8 16382141
    stacjapawel
    Rate: 11
    The pins of the mechanic were checking with me, he was cleaning something there, so okay, it may be a proof, for example, that in group 18 and 23 the parameters are ok, i.e. in 23 the first two cylinders are in the minus of approx - 5 to 9 in the 3rd and 4th cylinder about 20 to 40 as to the correct setting, I think it's good, unless you have some advice, I could give the mechanic something, it's my friend, so I don't think he will be offended
  • #9 16382154
    matimon22
    Help: 51
    Rate: 336
    It can make a difference because the cranks can be crooked. Check the cranks.
  • #10 16382306
    stacjapawel
    Rate: 11
    Cranks or what is the crankshaft? Somewhere I have already read something about cranks, but I don't really know what's going on
  • #11 16382409
    moto-kord
    Help: 137
    Rate: 504
    Let the mechanic change the injections, for example, 2 from 4 and check the parameters.
  • #12 16382422
    stacjapawel
    Rate: 11
    So how to transfer the injection from cylinder 4 to cylinder 2 where there is a parameter of 2.99 and it will continue to be unchanged, can it be a woman's curve?
  • #13 16382500
    moto-kord
    Help: 137
    Rate: 504
    If it is still the same, check the connection between the injector and
    engine controller, shaft what colleagues wrote above.
  • #14 16392167
    stacjapawel
    Rate: 11
    Hello, I have an appointment for compression on Saturday, so it will turn out, but it only started to worry me, the oil level on the dipstick is rising, the coolant is not decreasing, the color pink is what can it be?
  • #15 16392464
    moto-kord
    Help: 137
    Rate: 504
    Seals (O-rings) on pump injectors to be replaced,
  • #16 16392537
    stacjapawel
    Rate: 11
    All mentioned
  • #17 16392601
    moto-kord
    Help: 137
    Rate: 504
    It can also get through a tandem pump.
  • #18 16392714
    stacjapawel
    Rate: 11
    Could this be the reason for white smoke when starting when the engine is cold?
✨ The discussion revolves around a VW Passat B5 1.9 TDI (101 km) experiencing white smoke upon cold start and a misfire error (16686) on cylinder 2. The user has replaced the unit injector but continues to see a misfire with values around 2.99 in group 13. Responses suggest checking compression (ideal range 25-31 bar), injector positioning, and the condition of the crankshaft. There are concerns about rising oil levels and potential coolant issues, indicating possible seal or tandem pump failures. Recommendations include swapping injectors between cylinders to diagnose the issue and checking connections between the injector and engine controller.
