Gorenje EIT 695-ORA-E Induction Hob: Error E6 on Right Burners, IGBT Transistors & Rectifier Bridge
robibest 9408 1
  • #1 16712670
    robibest
    The problem is as in the topic - after turning the hob on, the display for the burners on the right, top and bottom, shows level 0, i.e. ok, but when the power is set to 2 and higher, E and 6 appear alternately for them.
    The burners on the left are working normally. After some cooking time, the left side of the E6 for the right side stops flashing and you can cook normally.
    I read that the IGBT transistors and the rectifier bridge may be damaged, but if after some time the right side starts to work, the transistors and the bridge are working.
    What could be causing this?
  • #2 16712754
    Piotr2608
    Help: 851
    Rate: 4485
    robibest wrote:
    I read that the IGBTs may be damaged
    Everyone reads, reads and the effects are zero.
    If you've read that these are damaged transistors, why haven't you checked them yet?
    The knowledge of the website is based on work - measurements, analysis, time.
    Everyone is counting on a ready-made and thinks that someone has a magic ball on the other side.
    According to what I found, E6 is communication disturbance between the filter and the power module or a damaged (faulty) temperature sensor.
    Added after 8 [minutes]:
    Is it a gas or an electric induction hob?
    The induction hob has cooking zones.
    ZimTech Piotr Zimny
