Archer TL-MR6400 Router: External Antenna for Improved Signal & Performance in Szklarska Poręba?
ilikeaudio 9321 5
  • #1 16713665
    ilikeaudio
    I have a Router Archer TL-MR6400 router and with it Plus LTE internet in Szklarska Poręba. I use it mainly to view from the camera what works, but the Internet almost does not go at all, or loads pages very slowly.
    Can you advise me if mounting an external antenna will improve the signal? There are 2 antennas in the router, but changing the position or location of the router does not help.
    If I had to buy the antenna (s), which is the best? I don't care about the speed being stunning. Just as it begins to load pages and mail as normal. Youtube, radio or other streams are not a priority.
  • #2 16713701
    sosarek
    Help: 9320
    Rate: 15532
    For testing, disconnect a colleague from the router camera and then check the network speed.
    Z
    Pka, Poznań, 60-850
  • #3 16713942
    matek451
    Help: 4352
    Rate: 5808
    And what street in Szklarska Poręba do you use LTE1800aero2 or LTE800Sferii, what signal parameters and DL / UL results in speed test?
  • #4 16714067
    ilikeaudio
    Słowackiego 9
    Even before connecting the camera there was a problem loading pages. I don't know which LTE I use (I will be there at the end of October and it will be difficult for me to provide this information)
    Is it not enough to connect an antenna such as the one in the link?
    http://www.dipol.com.pl/antena_atk-log_alp_lt...2x2_5m_przew_wtyk_sma_800-3000mhz_A7054_5.htm
  • #5 16714452
    matek451
    Help: 4352
    Rate: 5808
    Buy and find out. you made a mistake once when you bought the MR-6400. the router cannot select the LTE band. The nearest BTS Plus at the Bornit Hotel (Mickiewicza 21) is LTE1800Aero2 and LTE800Sferii. it's hard to say which one you're connecting to. On LTE1800 aero2 has 20MHz bandwidth in MIMO2x2 and DL up to 150Mbps, LTE800Sferii is only 5MHz in MIMO2x2 and DL up to 37.5Mbps. LTE800 range greater. Plus BTs in many locations are massively overloaded with low speeds.
  • #6 16876454
    ilikeaudio
    Buying the ATK-LOG ALP LTE MIMO 2x2 antenna 5m cable 800-3000MHz SMA plug solved the problem. I did not check the speed, but the page loads as it should and it was enough for this assessment. Previously there was a problem loading the page correctly.
    Thanks for the information about where the transmitter is located. I directed the antenna towards him. Archer TL-MR6400 Router: External Antenna for Improved Signal & Performance in Szklarska Poręba?
    I close the topic.
