Intel Pentium G4560 vs G4600: Comparing Performance, Pros & Cons, and AMD Alternatives
DrabU 3882 7
  • #1 16714821
    DrabU
    Hello. Which processor is better? I'd like a few arguments for playing computer. I also mean the pros and cons of these processors.
    Or something from AMD with similar or better performance?
  • #2 16714860
    n.vision
    Help: 108
    Rate: 260
    Advantages and disadvantages? G4600 a more robust integrator, that's where the important differences end. The only alternative from AMD is the Ryzen 1200. Alternatively, a handset from Intel, but then you have old motherboards
  • #3 16714865
    dt1
    Admin of Computers group
    Help: 7319
    Rate: 8299
    The G4600 is better - 0.1GHz faster, has better integrated graphics (admittedly it will not be used for games). Given that the price of these two is similar, the G4600 wins.
    When it comes to performance at a low price, these Intel have rather little competition. The cheapest Ryzen 1200 costs 50% more, game performance similar.
    Here one of many tests, just included Ryzen 1200 and G4560 - G4600 will be slightly more efficient than G4560: https://www.purepc.pl/procesory/premiera_test...esorow_amd_ryzen_3_1200_vs_intel_core_i3_7100
  • #5 16714940
    DrabU
    So if the price is lower then I could take g4600? If I wanted to, performance in 4-core amd game better?
  • #6 16714943
    Pedros050
    Help: 2471
    Rate: 3927
    Of course.
  • #7 16714964
    DrabU
    And how do you recommend the best performance for the price? g4600 is cheaper than g4560 for apricots ?? is that good
  • #8 16715013
    dt1
    Help: 7319
    Rate: 8299
    Very good. You'll get a better processor for less. Some time ago the G4560 became more expensive, they may still have old supplies. Nothing but be happy that the G4600 is cheaper than it.
The discussion compares the Intel Pentium G4560 and G4600 processors, highlighting that the G4600 offers a slight performance advantage due to its higher clock speed (0.1GHz faster) and better integrated graphics, although the latter is not significant for gaming. The G4600 is considered a better value as it is often cheaper than the G4560, which has seen price increases due to limited supply. An AMD alternative mentioned is the Ryzen 1200, which is more expensive and offers similar gaming performance. Overall, the G4600 is recommended for those seeking better performance at a lower price.
