Ryzen 3 2200G Universal PC Build: ASRock AB350M, 8GB RAM (2x4GB) 3000MHz – Recommendations?
diyManiek 3885 7
  • #1 17133954
    diyManiek
    Help: 130
    Rate: 65
    I plan to assemble a computer that would be universal.
    I chose Ryzen with integrated graphics because I just need such a graph, I am not an avid player.
    I also think that 4 cores and 4 threads are probably future-oriented.
    As an ASRock AB350M motherboard.
    RAM 8GB in dual 2x4GB 3000MHz
    I will not overclock Prock in the future.
    I also want the fund to be as low as possible.
    Can this set be? Possibly what do you recommend different?
  • #2 17134003
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    Hey. The motherboard does not allow the use of integrated graphics, so the plan will not come out. I suggest MSI B350M PRO-VDH to replace Asrock. You may need to update the BIOS. A BIOS update may be needed to run the Ryzeny 2xxx series on this board (by the way, on each board, because most of the available boards were designed before the 2xxx series processors).
  • #3 17134016
    diyManiek
    Help: 130
    Rate: 65
    Thanks for the helpful answer. In that case, I will take MSI B350M PRO-VDH although I can see that it has dimensions of 244x244, and I have a small casing silentiumpc brutus s30 and I do not know if this disc will fit there.
  • #4 17134048
    dt1
    Help: 7315
    Rate: 8292
    Open the cover and see. If it is a similar design to the S20, it seems that there is no special limit in width, because there is no basket for disks (the plate for disks hangs on the opposite side to the casing).
    If there is a problem with this, then https://www.morele.net/plyta-glowna-msi-b350m-pro-vd-plus-7b38-004r-1507403/ is similar in price - but it has two RAM slots and costs all in all similarly. And there is no HDMI :)
  • #5 17134073
    diyManiek
    Help: 130
    Rate: 65
    Two slots are enough for me :) I will measure the inside of the case and see which plate will fit. Thanks again for your help.
    Because there are no alternatives to this Ryzen? I don't care what the percentage is, that it should be forward-looking and have a good price / performance ratio.
    Ryzen should be good to me, but I don't know much about comps.
  • #6 17134123
    dt1
    Help: 7315
    Rate: 8292
    The alternative may be the Pentium G4600, weaker graphics, but despite the 2R / 4W it is doing quite well. At the beginning of April next generation Pentiums are to appear - if you do not buy right now - you can take a look. With the premiere of Pentiums, cheaper motherboards are also supposed to appear - so such a Pentium G5xxx with an H310 motherboard could be an interesting solution (and cheaper than Ryzen 2200G). On the other hand, this Ryzen is currently priced similarly to the I3-8100 (4R / 4W) - unfortunately it is currently losing when it comes to motherboard costs - about PLN 450. After releasing cheaper CDs to the market, it will be quite an interesting proposition.
  • #7 17134419
    diyManiek
    Help: 130
    Rate: 65
    I noticed the i3-8100, but the price of the motherboard is too high.
    I will be putting the computer together in April so I'll wait, maybe something interesting will appear as an alternative to Ryzen.
    At the moment, in my opinion, Ryzen 3 2200G is a great option when it comes to prock with integrated 4R / 4W graphics.
    It's also energy efficient because G4600 probably would have to be with a separate graphics card. I don't know how the integrated one is doing.
    I read that Vega is quite OK and in my case it would be enough for me.
  • #8 17134432
    dt1
    Help: 7315
    Rate: 8292
    The integrated Vega 8 card in the R2200G is quite OK - weaker than the GT1030, or even GTX750 or 650Ti, but generally almost 2x faster than that in the Pentium G4600.
The discussion revolves around building a universal PC using the Ryzen 3 2200G with integrated graphics. The user initially selected the ASRock AB350M motherboard but was advised that it may not support integrated graphics. A recommendation was made to switch to the MSI B350M PRO-VDH motherboard, which may require a BIOS update for compatibility with Ryzen 2xxx series processors. The user expressed concerns about fitting the motherboard in a small case and considered alternatives like the Pentium G4600, which has weaker graphics but may be more cost-effective. The Ryzen 3 2200G was ultimately deemed a good option due to its energy efficiency and integrated Vega 8 graphics, which outperform the Pentium's integrated graphics.
