[Solved] Intel Core i3-8100 vs AMD Ryzen 3 2200: MSI B350M PRO-VDH or Gigabyte B360M DS3H Mobo Choices
ajpe_ninja 3459 10
Should I choose a Ryzen 3 2200 with an MSI B350M PRO-VDH motherboard or an Intel Core i3-8100 with a Gigabyte B360M DS3H motherboard for gaming?
Without overclocking, the Intel i3-8100 with the Gigabyte B360M DS3H is slightly faster, but the Ryzen 3 2200 with the MSI B350M PRO-VDH is the better value if you want to save about PLN 100. For gaming, the i3-8100 is only a little better, with the difference described as small. The Ryzen offer is cheaper by about PLN 100, while the performance gap is said to be around 10 fps. Since you are using a GTX 1050, integrated graphics are not important, and several replies note that without OC the Intel option is the safer pick. Also, 4 GB RAM is too little for this setup, so more RAM is needed anyway. In the end, the thread’s asker chose Ryzen because of the lower price and only minimal performance loss. [#17348505][#17348512][#17348592][#17348693][#17348703]
  • #1 17347882
    ajpe_ninja
    Hello, I don't know what to choose Ryzen with MSI B350M PRO-VDH mobo or Intel with Gigabyte B360M DS3H mobo the difference is quite big.
    AMD set approx. PLN 735
    Intel set approx. 825 PLN
    The difference is about PLN 100
  • #2 17348296
    daminek1234
    Help: 61
    Rate: 88
    We don't know what RAM you have for this set.
    What application?
  • #3 17348474
    ajpe_ninja
    For playing (for gaming)
    Ram I have 4Gb 2400MHz CL16
    Crucial Balistix Sport LT Red
  • #4 17348505
    Piterixos
    Help: 38
    Rate: 56
    OC or without OC? Somehow integrated graphics are you going to use?
    You have 4GB of RAM and instead of buying more you are going to replace the processor? No sense.
    With such slow RAM, I think the set on the Intel better, just forget about OC in the future.
  • #5 17348506
    ajpe_ninja
    Rather without liability
    Added after 50 [seconds]:
    I don't particularly look at itnegre because I will have GTX 1050 outside of it
  • #6 17348512
    Piterixos
    Help: 38
    Rate: 56
    Well, without OC, it's definitely intel.
    I don't know what the rest of the components look like today, but you definitely need to buy more RAM
  • #7 17348516
    ajpe_ninja
    Just remember that the Intel set is about PLN 100 more expensive and with amd it will be only 10fps less
    Added after 33 [seconds]:
    I have 2x 4GB
  • #9 17348601
    ajpe_ninja
    But only a little and rice is 100 PLN cheaper
    Added after 9 [minutes]:
    It is ryzen 3 2200 or i3 8100 the difference is that the amd offer is PLN 100 cheaper
  • Intel slightly faster for 100 zł more
    #10 17348693
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    The same subject multiplies without much sense all the time. My colleague received exactly the same answers from me - https://www.elektroda.pl/rtvforum/topic3483503.html - with that topic closed by my colleague as solved.
    Assuming that the equipment is under the game, without OC - in this and that thread gently won Intel. For this colleague got processor comparison tests in the previous thread.
    Now it's not ours, it's our friends decision whether to buy slightly slower equipment for 100 zlotys cheaper. or slightly faster for PLN 100 more.
  • #11 17348703
    ajpe_ninja
    I think I will decide about a bit slower :)
    Added after 41 [seconds]:
    Who knows, maybe in the future I will be interested in OC :)
    Added after 43 [seconds]:
    I already know what to choose, thank you all for your help :)
    I choose Ryzen because of the price with the motherboard and with a minimum lower performance than the mentioned Intel model :)
The discussion revolves around choosing between the AMD Ryzen 3 2200G with the MSI B350M PRO-VDH motherboard and the Intel Core i3-8100 with the Gigabyte B360M DS3H motherboard. The user is considering the price difference of approximately PLN 100, with the AMD option being cheaper. Responses highlight the importance of RAM, with the user having 4GB of 2400MHz RAM, and suggest that for gaming without overclocking, the Intel option is slightly better. However, the performance difference is minimal, and the user ultimately decides to go with the Ryzen due to its lower cost and adequate performance for their needs.
