Lenovo G50-70 Microphone Issue: Stops Working After CS:GO Download & Using Headphones (Windows 8.1)
Chlebek1993 6978 15
Dlaczego w laptopie Lenovo G50-70 mikrofon przestaje działać po podłączeniu słuchawek i jak to naprawić w Windows 8.1?
To wygląda na problem ze sterownikami, a nie z samym mikrofonem: po aktualizacji sterownika grafiki/ATI mikrofon zaczął działać ponownie [#16715688] Po tej aktualizacji w sterownikach audio pojawiła się też opcja wyboru słuchawek, której wcześniej nie było [#16773208] Wcześniej sugerowano także odinstalowanie sterowników i ponowne uruchomienie laptopa [#16715267]
  • #1 16715241
    Chlebek1993
    Hello, I have a lenovo G50-70 laptop with a built-in microphone, I just made a format and everything was ok, the microphone worked 100%, then I downloaded the game (CS: GO) I plugged the headphones (without the microphone) And suddenly the microphone does not work ... you hear nothing. I went into the settings and the microphone sees one and it is active and not muted, I unplugged the headphones, I chose the option to listen to this device and a mega irritating squeak started coming from the speakers .... And how do I fix it? Somewhere I read that you need to buy a 2xjack-> 1xjack adapter, but why do I need an adapter if it was OK so far; x
    Added after 5 [minutes]:
    Oh, I will add that windows 8.1, and if I do not choose the option "listen to this device," and I enter the sound recorder, the sound is recorded cleanly without noise, etc ...
  • #3 16715252
    Chlebek1993
    64 bit, updated
  • #4 16715253
    1 PAWEL
    Help: 674
    Rate: 1364
    Try to scan on Lenovo.
  • #5 16715254
    Chlebek1993
    Scan on Lenovo? How?
    And that didn't help, the microphone is still silent ...
  • #6 16715257
    folkswagen
    Help: 7
    Rate: 12
    Please set the sound card to "record from external source". You can also use the system sound recorder, which allows the so-called temporary record to check the operability of the equipment - for example :D
  • #7 16715260
    Chlebek1993
    Yyy ... but my point is, the computer should use the built-in microphone :D And this is a record from an external source ?? Where to find it? :D
    Added after 11 [minutes]:
    I scanned and found nothing, I also did Windows problem detection and everything shows that it is ok ...
  • #8 16715262
    1 PAWEL
    Help: 674
    Rate: 1364
    Chlebek1993 wrote:
    also everything shows that it is ok ...
    If it works, congratulations, best regards.
  • #9 16715264
    Chlebek1993
    Well, the problem is that it does not work ... and it shows that everything is fine
    1 PAWEL
    Help: 674
    Rate: 1364
    You tried uninstalling the drivers and restarting your laptop.
  • #11 16715268
    Chlebek1993
    yes but still nothing ....
    folkswagen
    Help: 7
    Rate: 12
    Here you should probably act methodically.
    Is it the "latest copy of the system"? If "just" a colleague tries to come face to face!
  • #14 16715688
    Chlebek1993
    1 PAWEL wrote:
    I am already installing ATI drivers, the rest of the topics in this link do not apply to me or have already been tested
    I updated the graphics and the microphone works -.- Thanks; D
    1 PAWEL
    Help: 674
    Rate: 1364
    You've been working a lot lately, but it finally worked, congratulations and best regards. :)
  • #16 16773208
    Chlebek1993
    As I wrote, the graphics driver update added an option to select headphones in the audio drivers (previously there was a choice of headset, microphone and line input).
The discussion revolves around a Lenovo G50-70 laptop experiencing a microphone issue after downloading the game CS:GO and using headphones. Initially, the built-in microphone functioned properly, but it ceased to work after the game installation. The user confirmed that the microphone is recognized in settings and is active, yet no sound is captured. Suggestions included checking sound card settings, uninstalling drivers, and performing system scans, but these did not resolve the issue. Ultimately, updating the graphics drivers restored microphone functionality by enabling headphone selection in the audio drivers.
TL;DR: On a 64‑bit Windows 8.1 Lenovo G50‑70, one driver update fixed the mic. "I updated the graphics and the microphone works." [Elektroda, Chlebek1993, post #16715688]
Why it matters: This FAQ helps Lenovo G50‑70 users fix built‑in mic issues triggered after installing games or plugging in headphones.
Why did my Lenovo G50‑70 mic stop after installing CS:GO and plugging in headphones?
Driver changes can remap audio inputs. In this case, updating the graphics (ATI/AMD) driver restored the mic and correct device routing. The update exposed proper audio selections again, resolving silence after CS:GO and headphone use. "I updated the graphics and the microphone works." [Elektroda, Chlebek1993, post #16715688]
How do I stop the loud squeal when I enable “Listen to this device”?
That option monitors the mic through speakers, which can create feedback loops and squeal. Disable “Listen to this device,” lower mic boost, and monitor only through headphones if needed. The reporter heard a “mega irritating squeak” immediately after enabling the option, confirming feedback behavior. [Elektroda, Chlebek1993, post #16715241]
My recording is clean, but live monitoring squeals—what does that mean?
Your mic and driver can record cleanly, but speaker monitoring is feeding back. The thread author noted clean Sound Recorder captures yet squeal during monitoring, reported within 5 minutes of initial testing. Keep monitoring off or use closed‑back headphones to avoid loopback. [Elektroda, Chlebek1993, post #16715241]
Do I need a 2×jack to 1×jack adapter for this laptop?
Not for the reported case. After updating drivers, the audio panel allowed selecting Headphones separately, and the built‑in mic worked again without any adapter. Adapters are useful only when using a headset mic with separate plugs. [Elektroda, Chlebek1993, post #16773208]
Which driver actually fixed the microphone in this case?
Installing the ATI/AMD graphics driver solved it. After that update, the mic started working immediately on the Lenovo G50‑70. As the reporter put it: "I updated the graphics and the microphone works." [Elektroda, Chlebek1993, post #16715688]
Uninstalling and reinstalling audio drivers didn’t help. What next?
In the thread, removing drivers and restarting did not restore the mic. The successful step was updating the graphics driver, which re‑enabled correct audio input choices. Try GPU driver updates if audio reinstalls fail. [Elektroda, Chlebek1993, post #16715268]
Windows says everything is OK, but the mic is still silent—how should I proceed?
Treat it as a routing or driver exposure issue. The reporter saw “everything is fine” while the mic stayed silent. Update device drivers (including GPU) and recheck the input device list afterward. [Elektroda, Chlebek1993, post #16715264]
How can I quickly verify my microphone hardware works?
Make a short test in Windows Sound Recorder (or Voice Recorder). In the thread, recordings were clean despite monitoring squeal, confirming the mic and driver captured correctly. Use this to separate hardware faults from feedback or routing issues. [Elektroda, Chlebek1993, post #16715241]
What does “record from external source” mean in audio settings?
It tells the system to use an external input (like a headset mic) instead of the internal mic. A helper suggested switching sources to test functionality. Use it only if you intend to record from a plugged‑in microphone. [Elektroda, folkswagen, post #16715257]
Can a Lenovo support scan help identify the issue?
It’s a reasonable first step to audit missing or outdated drivers. A helper advised running Lenovo’s scan. If it reports nothing, still try manual driver updates, including the GPU. [Elektroda, 1 PAWEL, post #16715253]
After the fix, where do I select between Headphones and Headset?
Post‑update, the audio driver interface gained a distinct “Headphones” option, separate from Headset/Microphone/Line‑in. Choose Headphones when using earbuds without a mic so the internal mic remains active. [Elektroda, Chlebek1993, post #16773208]
Step‑by‑step: how do I try the Lenovo scan approach?
  1. Open Lenovo support for the G50‑70 and choose auto‑detect.
  2. Install the detection tool and run the hardware/driver scan.
  3. Apply recommended updates, then retest the mic input selection. [Elektroda, 1 PAWEL, post #16715253]
Should I update Windows before troubleshooting drivers?
Yes. A helper urged methodical action and ensuring a current system state. After confirming updates, proceed to driver checks and input selection. This reduces conflicts and missing dependencies. [Elektroda, folkswagen, post #16715273]
Did CS:GO itself break the microphone?
The timing suggests configuration or driver exposure changed when headphones were used around the CS:GO install. The confirmed fix was a driver update rather than a game setting change. [Elektroda, Chlebek1993, post #16715241]
