[Solved] Logitech G430 Headset Microphone Not Functioning Post-Windows 10 Update
Piesiu0804 6534 4
  • #1 17226236
    Piesiu0804
    Hello, help please, because after updating Windows 10 my microphone from Logitech g430 headphones stopped working. I will add that the microphone works if I enable the listening function of this device. I have already tried to install the drivers but they are the latest. I will add that when I connect these headphones to another computer, everything works as it should
    I would be very grateful for help.
    Thank you
  • #2 17226352
    delag
    Have you checked the drivers? many things don't work after the last update (such as mouse, keyboard drivers etc.)
  • #3 17226913
    francus11
    Check if it is the default device (also for communication). Right click on the volume in the bar and choose something that is related to the microphone (I don't remember what it's called and I don't have the right way to check it now) select your microphone and set it as default. It is important that these options are set to default. Forgive me for such vague words but I don't have a computer at hand and I rely on my own memory. If you can't figure it out, write and I will explain it to you better at home.
  • #4 17228041
    Piesiu0804
    @ francus11 everything is as you wrote and nothing helps
  • #5 17229790
    Piesiu0804
    I enabled the microphone settings in privacy settings for the second time
