Mazda 323f BA 1.5 Petrol + LPG 1994: Unsteady Speed, Choking, Power Loss Issues
byrt_s50 5004 4
  • #1 16252422
    byrt_s50
    Hello. I have a problem with the car. The patient is a Mazda 323f ba 1.5 petrol + LPG 1994. The problem is the undulating speed and the fact that he chokes terribly, which means he has a lack of power and does not want to drive. The turnover can drop even so that it goes out ? Has anyone had such a problem? I am asking for quick help what may be wrong with her. Thank you in advance and best regards.
  • #2 16252552
    robokop
    Help: 1763
    Rate: 6371
    Z5 engine? Flow meter -> pipe to the flow meter -> around the throttle and bypass.
    Does it work well on gasoline or the same?
  • #3 16254444
    byrt_s50
    Same on petrol and LPG. The flow is rather efficient (this wire behind the grate is in place): / it chokes terribly and does not want to go, now there is a very heavy launch ? the throttle is cleaned
    Added after 4 [minutes]:
    1.5 ba engine
  • #4 16254477
    robokop
    Help: 1763
    Rate: 6371
    byrt_s50 wrote:
    The flow is rather efficient (this wire behind the grille is in its place)
    Congratulations on your optimism. What is the flow rate at idle?
    byrt_s50 wrote:
    throttle cleared
    And the idle contact? The driver sees a closed throttle?
    byrt_s50 wrote:
    1.5 ba engine
    Z5 no "ba".
  • #5 16256014
    art342
    Rate: 24
    Hello, I had a mazda 323c 1.5 16v, I also had such problems with starting, and in particular in the morning it was a massacre, everything checked, fuel pressure, flow meter changed, still the same lack of power and hard enthusiasm, it turned out! tight valves and there was no compression, valves there are regulated by plates
