Fabia Central Locking Controller Installation: Tips on Accessing Control Cables & Colors
stawpol2 15387 6
  • #1 16715717
    stawpol2
    Rate: 67
    Hello, I am at the stage of installing the central locking controller (factory key central) I already have a plus and minus connected, but I have a problem with the control cables, the seller sent the instructions, I quote the yellow and blue cable in the driver's door pass, plug in with the control there, the problem is that getting to these cables between the doors is physically impossible, no access even the hand does not enter, does anyone know where these wires go out in the cabin? which bone do they reach? what color do they have? from the inside nothing can be seen because this connector is under.
    I will be grateful for tips
  • #2 16715799
    bubu1769
    Help: 1177
    Rate: 2374
    Everything is cool but what car?
  • #3 16715852
    stawpol2
    Rate: 67
    but a setback !!! the dumper is fabia I year 2002
  • #5 16716078
    stawpol2
    Rate: 67
    it's bright but I can't locate this big 23 pin cube !!
    sk700
    Help: 173
    Rate: 420
    It's a cube from the comfort module. Such a black can placed vertically above the accelerator pedal, you need to unscrew the cover and airflow on the driver's legs.
  • #7 16716488
    stawpol2
    Rate: 67
    thanks to the hints succeeded
The discussion revolves around the installation of a central locking controller in a 2002 Skoda Fabia. The user faces challenges accessing the control cables, specifically the yellow and blue wires in the driver's door. Despite having connected the power supply, they struggle to locate a large 23-pin connector, which is identified as part of the comfort module located above the accelerator pedal. Helpful responses provide guidance on accessing this connector by removing the cover and airflow components near the driver's legs, ultimately leading to a successful installation.
