Installing Universal Central Locking in Skoda Fabia I Hatchback 1.2 54HP: Actuators & Switchboards
mateon969 18096 11
Which universal central locking controller should I choose for a Skoda Fabia I so I can lock/unlock, open the trunk, optionally honk the horn, and add dashboard buttons or master-actuator logic?
Use a central locking controller that supports a master actuator in the driver’s door; you can wire extra dashboard buttons in parallel with the master actuator contacts, and the master’s switched contact is what informs the controller about lock open/close state [#16851801][#16864297][#16865282] For the trunk, a separate logic path is simpler than a timer: you can let the actuator pull only while the remote/handle button is pressed, and just inhibit that button when the central lock is closed [#16859664] Standard controllers usually treat trunk release and horn/lokout as alternative extra functions, so they are typically programmed as one or the other rather than both at the same time [#16851801] If you want to trigger trunk release from the handle microswitch, the thread does not confirm a ready-made controller for that exact input, so you would need extra relay logic around the switch [#16851801][#16859664] For the trunk light, the factory-style solution is to put the cut-off relay in series with the bulb so the light turns off automatically after a fault or timeout [#16859664] The master actuator itself is not “smart”; it has only an extra contact, with three wires where the common contact connects to one of the others depending on position [#16865282]
  • #1 16848946
    mateon969
    Hello everyone, my name is Mateusz, this is my first post written thanks to the CameR user who gave me points (thanks :) . I have been registered on Elektroda for a long time but I used only as a reader.
    I wanted to install the central lock in the Skoda Fabia I Hatchback 1.2 54HP, this is a poor version without any amenities, hence the easiest way to buy a set of universal cylinders and a switchboard.
    On Allegro, I found a set of actuators dedicated to Fabia for about 125 PLN, which seems quite interesting due to the appropriate plates, cylinders like in any other set.
    First case
    - which switchboard to choose which will allow me to:
    - opening / closing the door
    - opening the damper with a dedicated remote control button
    -waking up the horn with a dedicated button or by pressing the closing button on the remote control twice quickly (searching for a car in the parking lot)
    Second case
    - does any central control support the microst contact in the damper handle? In addition to the remote control, I would like to be able to open the hatch manually with the handle when the lock is disarmed. At the moment I have a "bare handle", I plan to buy a version with a contact.
    Third case - is there an option to add buttons on the dashboard that I can close to open the central locking?
    It seems to me that it would be possible to use the alarm control panel and use the relay opening the starter cord, give a time trial and set on it that after 0.5s of holding the handle microstock, it will give voltage to the damper lock cylinder 0.9s (I think it should be?). When the alarm was armed, the starter relay would be open and no current would flow to the actuator. What do you think about this? maybe there are simpler ways. Alternatively, a PLC powered by 12V could perform all functions but it is probably too power-consuming for the car, especially if it would stay longer.
    Opening the flap from the remote control could be omitted altogether if it could be controlled by the microswitch in the handle?
    In general, it would be a great solution to confirm by means of an LED diode physical closure of all locks (maybe it can be done on factory locks?) - is this practically used?
    Thank you for all suggestions and answers, I have already bought some things besides servomotors and central unit. Below are photos of optimal pilots :)
    I saw the following one with the fourth red button from below:
    I will be grateful for any suggestions and advice on practical aspects of using universal central locks.
  • #2 16851801
    CameR
    Moderator of Vehicle Security
    Help: 1139
    Rate: 3272
    mateon969 wrote:
    Case one - (...) opening / closing the door
    Every switchboard can do it.
    mateon969 wrote:
    Case one - (...) flap opening from the remote control / horn activation
    These two options are usually programmed interchangeably, i.e. the control panels do not perform both functions at the same time.
    mateon969 wrote:
    Case two - does any control unit support the microst contact in the damper handle?
    I do not know this exact central control unit
    mateon969 wrote:
    Case three - is there an option to add buttons on the dashboard that I can close to open the central locking?
    You need a central locking controller that supports the "master" actuator in the driver's door.
    In parallel with the working contacts of the "master", you connect additional buttons on the console.
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • Advice on trim removal and flap switch control
    #3 16853109
    mateon969
    With this master actuator, I didn't think so :)
    There are such remote controls with four buttons, e.g. the one from auction allegro nr: 6572397357 anyway there are a lot of them - none of them will handle horns and flaps?
    I understand that the control of the micro-contact in the flap is also impossible in these units :( ?
    I would like to ask you for advice on how to remove the sides in the fabia, maybe someone knows from which side to start, to break as little as possible - I took off the cover of the flap nicely but in the covers of the trunk pillars I broke the sockets of the clips :( (I am dismantling the flap, because the trunk lighting is installed and I bought a lock with a limit switch).
  • #5 16859412
    mateon969
    I came up with this solution because I was guided by Camer on the signals controlling the master servomotor, I will use a bistable relay switched by the signals controlling the servomotors.
    When the central locking releases, the NO contact of the relay "gives" a positive or ground transition. This signal will power up the time switch controlled by the microstock in the flap. If the central one locks, the time will not be charged.
    The time is to be that when I push the microstock in the flap (rising slope - impulse), it will set the voltage on the flap bolt and the flap will open for 1s (around). I found the ASE 4RSM bistable relay, which should fulfill this task, but in the conduction state (open switchboard) it consumes 40mA and I do not know if it would be better to use a typical electromechanical one or two coil, I'm afraid that it will switch on potholes.
    Alternatively, instead of a bistable relay, I can use an end switch which will be switched by a rod moved by an actuator, e.g. in the driver's door.
    I will then use the additional channel on the remote control to connect the horn to search in the parking lot.
    I'm still lighting the trunk and I'm wondering whether to connect the shortening relay to directly turn on the light. Apparently only 10 Watt, but in the event of a breakdown of the limit switch it would turn off the light e.g. after 3 minutes.
    What do you think about these solutions? :)
  • #6 16859664
    tzok
    Help: 3176
    Rate: 6549
    I think that with a clear conscience you can skip the time system in the control of the damper actuator - let it "pull" the pull rod as long as the button on the remote control / handle is pressed. You only need to power the button so that it does not work when the central lock is closed. On the relays you can perform any logical functions, you just have to remember that in the "idle" all relays have turned off the power of the coils, because they consume a lot of current. In the case of "automotive" relays, you do not have to worry about accidental activation / disconnection due to vibration.
    This is how it works at the factory. The shortening relay is connected "in series" with the bulb.
    They are highly recombined.
    mateon969 wrote:
    I would like to ask for advice on how to remove the bellies in the factory
    Look for some Skoda forum with photos. First unscrew all the screws hidden under the caps in the door handles, do not forget about when adjusting the mirrors / door handle (underneath). First "tear" the latches at the bottom, then go up. You can remove the strip near the glass. Due to the "triangles" on the mirrors, you remove the bacon upwards from the side of the door.
  • #7 16859712
    mateon969
    Thanks for the answer, I will give the lights to the shortening, to the microstatic of the flap I will not give anything, if it will not do it, I will add something, but ...
    Still the issue of locking the flap as the central unit is blocked. I have short pulses - 0.9s switching actuators, polarization changes at close / open. I could give a bistable one coil or limit switch.
    I am now leaning for a bistable car - it still consumes 1mA, and when the control unit is unlocked - 40mA.
    • Installing Universal Central Locking in Skoda Fabia I Hatchback 1.2 54HP: Actuators & Switchboards 1.jpg (120.86 KB) You must be logged in to download this attachment.
  • #8 16860131
    tzok
    Help: 3176
    Rate: 6549
    ... can't you just use the signal from the master cartridge? It may not be such an elegant solution as a bistable relay, but much simpler and cheaper. The fact that it will then only react to the driver's door, but it's probably not a big problem.
  • #9 16862048
    mateon969
    I have not yet reached the set of servomotors and the control unit. I don't know what signals are available in the master actuator :( whereas how they were controlled I knew :) All in all, if something could be used, it would be the most :idea:
  • #10 16864297
    tzok
    Help: 3176
    Rate: 6549
    In the master actuator you have an additional limit switch - 3 wires: one common is shorted with one of the others depending on the position of the actuator (open / closed).
  • #11 16864927
    mateon969
    So the master on three signal wires switches from COM plus or ground between the other wires (there is probably NO and NC contact). Maybe I will buy another master servomotor, mount it in the door, e.g. left rear, connect only the engine power supply to the control panel and use two signals to give the signal to the trunk? Alternatively, an industrial switch connected to the cable in one of the doors - zero power consumption - as in both solutions.
    I don't know exactly how the master actuator works. I read that when I turn the key, the actuator will pull the key all the way and that it needs to be adjusted properly. And these control contacts are surely used for this. I would like to ask for an explanation :)
  • #12 16865282
    tzok
    Help: 3176
    Rate: 6549
    The master actuator has a switchable contact informing the central lock controller about its position, so that if the door lock is opened / closed with a key or a mechanical bolt inside, it can inform the controller about it and this will open / close the locks on the other doors. The operation of the master servo itself is no different from the slave servomotor - apart from this switched contact, there is no additional electronics and does nothing by itself.
The discussion revolves around installing a universal central locking system in a Skoda Fabia I Hatchback 1.2 54HP, focusing on selecting appropriate actuators and switchboards. The user seeks advice on a switchboard that can control door locking, trunk opening, and horn activation. Responses indicate that most switchboards can handle these functions, but specific configurations may be required for the master actuator in the driver's door. Suggestions include using a bistable relay for controlling the trunk actuator and utilizing the signals from the master actuator to simplify the installation. The conversation also touches on the challenges of disassembling the car's interior without damaging components.
TL;DR: Planning Fabia I central locking? Key stat: the master actuator exposes 3 wires; expert tip: "In the master actuator you have an additional limit switch — 3 wires." [Elektroda, tzok, post #16864297]
Why it matters: This FAQ helps Skoda Fabia I owners choose parts, wire safely, and avoid trim damage when adding universal central locking.
Will any universal central lock switchboard open/close my Fabia I doors?
Yes. “Every switchboard can do it.” You can choose a universal controller and standard 2/5‑wire actuators. This covers basic lock/unlock. If you want cabin buttons or master/slave behavior, confirm the controller has a master actuator input. [Elektroda, CameR, post #16851801]
Can I run both trunk release and horn search from the same remote?
Usually no. These features are typically programmed as alternate uses of the same auxiliary output, so you select one at a time. Pick trunk release for practicality, or horn search for locating the car. “The control panels do not perform both functions at the same time.” [Elektroda, CameR, post #16851801]
What is a master actuator and how is it different from a slave?
A master actuator is a standard motorized actuator plus a position-switch contact. That contact reports door state to the controller, so manual key or latch movement can trigger global lock/unlock. The servo motor itself works like a slave; only the added switch differs. [Elektroda, tzok, post #16865282]
How many wires are on the master actuator and what do they do?
It presents three switch wires for state sensing: one common (COM) shorted to one of two outputs depending on open or closed position. You still wire the motor pair for movement. The three-signal arrangement simplifies logic for cabin buttons and trunk interlocks. [Elektroda, tzok, post #16864297]
How do I add lock/unlock buttons on the dashboard?
Use a controller that supports a driver’s door master actuator. Wire the console buttons in parallel with the master’s working contacts. Keep wiring short and fused. Test with ignition on, then with key out, to confirm expected behavior. [Elektroda, CameR, post #16851801]
How should I wire the trunk release with a handle microswitch?
Skip a timer at first. Power the actuator only while the handle button is pressed, and ensure the button is disabled when the car is locked. Build the logic with relays and design for zero coil current at idle to avoid drain. [Elektroda, tzok, post #16859664]
Should I use a bistable relay to remember lock state for the trunk?
You can, but avoid constant draw. One approach is to use the driver master’s signal to authorize the trunk when unlocked. “It may not be such an elegant solution as a bistable relay, but much simpler and cheaper.” This reduces standby current. [Elektroda, tzok, post #16860131]
What pulse length should my controller send to the actuators?
Approx. 0.9 seconds is a practical baseline many kits use. This duration reliably drives the rods without overheating the motors. If adjustments are available, start at 0.9 s and test door travel before finalizing. [Elektroda, mateon969, post #16859712]
How do I avoid breaking clips when removing Fabia panels?
Work warm. First remove screw caps and all screws in door handles and behind the interior handle trim. Release bottom latches, then pull upward. Remove the glass-near strip and lift at the mirror triangles. Cold plastics crack and clip sockets can break. [Elektroda, tzok, post #16859664]
Edge case: I already snapped trunk pillar clip sockets—what went wrong?
This happens when trim is pried cold or in the wrong order. The pillar covers’ sockets can fracture if the plastic is brittle. Warm the cabin and use panel tools next time to reduce stress on sockets and clips. [Elektroda, mateon969, post #16853109]
Can I control a horn search feature while keeping the trunk channel?
Not on most budget controllers. Their extra channel is shared between horn search and trunk release. Choose the one you need more. If you must have both, you’ll need a controller with multiple independent aux outputs. [Elektroda, CameR, post #16851801]
How do I wire the trunk light so it won’t stay on forever?
Copy the factory method: place a shortening relay in series with the bulb. That provides automatic shutoff after the switch closes, protecting the 10 W lamp and your battery during faults. Keep coil current off at idle. [Elektroda, tzok, post #16859664]
Is vibration a problem for automotive relays in this install?
No. Automotive relays are designed to resist vibration-induced chatter. Design your logic so all coils are de-energized at rest to reduce current draw and heat. Good relay logic can implement any needed interlocks. [Elektroda, tzok, post #16859664]
Three-step: how do I add cabin lock/unlock buttons correctly?
  1. Confirm your controller supports a driver’s master actuator.
  2. Wire two console buttons in parallel with the master’s working contacts.
  3. Test lock and unlock with doors open, then re-check with ignition off. [Elektroda, CameR, post #16851801]
What does a universal kit for Fabia typically include and cost?
Expect actuators with Fabia-specific plates and a generic controller. A user-sourced example cost about 125 PLN. Verify remote channels match your needs before purchase, especially if you want trunk or horn features. [Elektroda, mateon969, post #16848946]
Expert tip: should I heat the car before trim work?
Yes. “It doesn’t matter the direction, it’s important to do it in a warm room.” Warm plastics flex, cold ones crack. This simple step saves clips and time during installation. [Elektroda, CameR, post #16853693]
