Best Linux Distros for Asus F5R Old Laptop: Lightweight OS for Intel T2250, AMD X1100M, 1GB RAM
Punkxp 27963 28
What lightweight Linux distribution should I install on an Asus F5R with an Intel T2250, AMD X1100M and 1 GB RAM, and will it handle YouTube, VOD, Skype, and web browsing?
Puppy Linux is the best fit if you want something very light on this laptop; it was described as far lighter than Mint, runs mostly in RAM, and the Tahr Puppy variant with Pale Moon was reported to work very fast on old hardware [#16723852] If you want a more mainstream system, Linux Mint 18, Lubuntu, Sparky Linux with LXQT, and antiX 16 were all recommended as usable choices for older machines [#16734654] [#17172925] [#17172965] [#17174557] For this T2250-class CPU, YouTube above 360p is expected to stutter, and HD video was reported to cut even on Mint 18 [#16723852] [#16734654] Silverlight was reported to work on Mint 18, but Skype on 32-bit Linux is problematic and may require older versions [#16734654] [#16734668] In short: choose a very light distro and expect web browsing to be fine, but video playback to be limited [#16723852] [#16734654]
  • Suggesting a lightweight Linux for an Asus F5R laptop
    #1 16715863
    Punkxp
    Rate: 20
    Recommend some simple Linux for a Windows XP laptop that is already running, so that this laptop is not suitable for browsing the Internet.
    Laptop parameters are Asus F5R:
    Intel T2250 processor
    RAM memory 2x 512 MB DDR2 667 MHz
    120 GB Sata drive
    AMD X1100M Graphics
    DVD recorder
    Camera 1.3 MPx
    What kind of Linux would work comfortably on it and would it be possible to watch Youtube, Iple, Onet VOD or Microsoft Silverlight and Skype and browse the Internet on it.
  • Puppy Linux recommended for 1 GB RAM laptops
    #4 16723852
    safbot1st
    Help: 2719
    Rate: 1585
    bezpiecznik82 wrote:
    For example some Linux Mint
    This is a giant compared to Puppy Linux. Puppy enters fully RAM and takes up 256MB max:
    https://linuxiara.pl/download_puppy/
    It can be hard to switch, but I haven't seen a more meaningful linux for grandpa laptops.
    And do not install the latest Firefox, because versions from 52.x are also heavy blocks. You have a Pale Moon browser in the Tahr Puppy version, you know, not fully compatible, but it works like lightning.
    On this processor, YT over 360p will cut, you can't help it, full HD is out of the question.
    Added after 6 [minutes]:
    Out of curiosity, I came to this link from post # 3, on the same page:
    installation of Zorin = 1.5-2.5GB
    Puppy installation = 150! -500 MB .
    Of course, if you need applications like Office etc., it's best to install a "bare" system and then add whatever you need to, for example, Mint has all this often redundant software in it.
    The truth is, if you took care of that XP, the 1GB you have should work fine.
    What on the bank "muli" You, this PC is a 120GB disk, give me God if it takes 60MB / s. Turtle.
  • #5 16723899
    leonov
    Help: 1039
    Rate: 2248
    More distribution Link
  • #6 16723908
    safbot1st
    Help: 2719
    Rate: 1585
    @leonov Hah, Dam Small Linux is only 50MB. ; D I wonder what's left in it ... of the "software". ;)
  • #7 16723914
    leonov
    Help: 1039
    Rate: 2248
    The distribution uses its own MyDSL package manager and the .dsl format as well as.uci i.unc, which include, among others, OpenOffice.org, GIMP, Skype or Opera. After installation on the hard drive it is possible to unlock apt manager and use .deb packages
    You can check it out for yourself you download it unpack it, and run dsl-base.bat. This will run DSL in a virtual machine (QEMU).
  • #8 16734654
    Punkxp
    Rate: 20
    Tested Linux Mint 18 and even it works fine, only movies actually start to cut at HD.
    Plus there is support for Microsoft Silverlight and practically all devices in this laptop where Ubuntu 14 Remix had a problem with detecting some devices.
    I fumbled a bit and it turns out that MS has removed the support for Skype for 32 bit under Linux, but it's strange that it still supports Windows 32 bit, e.g. XP or Vista has a new Skype.
    Unless there is a newer version for Linux than 4.3 for 32 bit system.
    As for the disk, when testing it with HD Tune, the beginning showed about 46 MB / s, but then, i.e. around the middle, already 38 MB / s, yet this Mint collects quite well, certainly better than XP and Vista, which were kneeling with 2 tabs.
  • #9 16734668
    safbot1st
    Help: 2719
    Rate: 1585
    Punkxp wrote:
    MS removed support for Skype on 32 bit under Linux
    https://skype.en.uptodown.com/ubuntu/old
    Try 4.2 and below.
    Punkxp wrote:
    As for the disk, when testing it with HD Tune, the beginning showed about 46 MB / s, but then around half of it was already 38 MB / s
    HDtune's "plateau" tests will always follow the "parabola". So the slowest component of this PC. I assumed 60MB / s, and here it is not 50 even it turned out.
  • #10 16735828
    Punkxp
    Rate: 20
    I still have a question because a friend gave me an old Toshiba netbook with Atom N455 and 1 GB DDR3 today.
    Would any Linux make sense for such a tiny 10.1 inch?
    I fired Mint and unfortunately part of the window is not displayed in the settings because the Netbook screen is too small.
  • #11 16736072
    safbot1st
    Help: 2719
    Rate: 1585
    And how does this skype work, apparently on ubuntu?
    Punkxp wrote:
    I fired up the Mint
    Maestro, this is a technical forum, so it makes no sense to ask without even giving the version.
    This is typical Mint behavior when you have drivers integrated in different versions and for different layouts. X can go crazy on older machines.
    The quickest way is to play in the settings or just try another Mint.
    I wrote that on SIS Mirage only 1 - the only Mint worked for me. Probably 7.0.
  • #12 16986032
    Punkxp
    Rate: 20
    I tested a few linuxes and it turns out that the last one that works well is version 14 of the regular Ubuntu Remix and it was set up like that.
    It took me a long time to bring it to a usable condition, because unfortunately it is too old system for modern times.
  • #13 16989842
  • Lubuntu 18.04 LTS works well on old laptops
    #14 17172925
    wojtek2004
    Rate: 62
    I can tell you that Lubuntu is very good.
    Lubuntu is a popular variation of Ubuntu that is characterized by speed.
    Thanks to the use of the desktop environment, LXDE is lighter, less resource-consuming and more energy-efficient.
    The LXDE desktop uses the Openbox window manager, has low hardware requirements, and is designed for older computers.
    I have two computers at home: a desktop and an older HP Compaq 6110 laptop.
    It flashes nice. Mostly the laptop has all the drivers.
    What's important is reading-scrolling text in the Touchpad, the trackpad is working.
    And in the stationary no name sound card. Everything works ... Now I will be changing a computer with a multi-core processor. Currently, I have Turion in stationary. Time to change the disc ...
    PS I run the latest version of Lubuntu 18.04 LTS 64-bit (Desktop)
    link to download:
    http://ftp.belnet.be/pub/lubuntu.org/daily-live/current/
  • Sparky Linux with LXQt recommended for old PCs
    #15 17172965
    tomek_602
    Help: 51
    Rate: 61
    For comfortable work on old equipment, I recommend Sparky Linux with LXQT.
    I have been using it on various computers for several years and recommend it with full conviction.
    Thanks to it, even my old Pentium IV computer works fine for office / internet purposes.
    LXQT is a very simplified LXDE, but built on the basis of the newer version of the QT library. It works quickly and smoothly, and if you need to use some fancy application, programs written with KDE in mind will work without any problems.
    Sparky uses not only its own repositories, but also extremely rich Debian repositories, so you can easily find applications for (almost) anything ..
    For ascetics, I recommend the minimalist Damn Small Linux.
    I have it always at hand for service purposes. It works on literally any hardware, but it's really minimalist and doesn't give you any comfort.
  • #16 17173370
    wojtek2004
    Rate: 62
    Lubuntu is supported (LTS).
    Sparky is not updating at the moment.
    I don't know, maybe it will install it on the laptop. I will try.
    Probably there will be no drivers.
    Maybe there will be no Polish language. The lean system has pros and cons ...
  • Sparky Linux supports old hardware with Polish language
    #17 17173945
    tomek_602
    Help: 51
    Rate: 61
    wojtek2004 wrote:
    Sparky is not updating at this time.
    1. Updates are daily.
    2. And try it - that's why Sparky also works in "live" mode (ie it starts up from pendrive or CD without installation).
    3. There are drivers.
    4. The language is Polish
    5. The environment is lean, not the system.
    In the case of Linux, just because it's optimized to run on less powerful hardware doesn't mean it's "slimmed down" from some features or languages. On the contrary, it ensures that the new kernel and current modules work properly on old hardware.
    To think that only old or truncated systems can run on old hardware is a mistake carried over from Widows.
    As I wrote, I have been using Sparky for years.
    I have Sparky 5 64b with KDE on my computer, and 5 32b with LXQT on my home computer. On another one, I have 5 32b from KDE.
    Everything works fine.
    I have Mageia on another one. The system is easy to use and visually nice, but I'm leaving it for Sparky.
  • Fluxbox on Debian for a lightweight setup
    #18 17173954
    siewcu
    Help: 133
    Rate: 458
    I used to use fluxbunt - but maybe because fluxbox was convenient for me. Small and fast, ubuntu did not allow you to run 2 tabs in the browser and on fluxbunt several tabs, background music and flickering. I just don't know if there is a fresh version - but if not and you are not afraid of challenges, you can always put up a stable debian and throw fluxbox on it ;) This is a guarantee of a clean system, of course, if you do not throw in the graphical environment during the installation and set up a clean system with the console itself (contrary to appearances, thanks to tutorials it can be quickly mastered).
    @down: thanks for the fix, I didn't notice ;)
  • #19 17173968
    tomek_602
    Help: 51
    Rate: 61
    siewcu wrote:
    ... you can put up a stable debian and throw fluxbunt on it ;) ..
    I guess fluxbox?
  • #21 17174368
    siewcu
    Help: 133
    Rate: 458
    leonov wrote:
    tomek_602 wrote:
    I guess fluxbox?
    Please refer to .... https://pl.wikipedia.org/wiki/Fluxbuntu
    He's right after all. Fluxbuntu is a system, and you won't throw the system onto the system, and fluxbox is probably the lightest desktop environment.
  • #22 17174557
  • #23 17177825
    tomek_602
    Help: 51
    Rate: 61
    Antix already has a newer version 17.
    According to the list on the Antix project website, there is no Polish language version.
  • #24 17178386
  • #25 17179568
    rafish
    I recommend debian stable with LXDE there (gnome or kde will definitely be too heavy for such equipment), recently I installed on celeron 1.6 (I don't remember the Prock model but it's still the old 775 socket) + 512 ram and everything was flickering, is HD on YT working I don't know, I haven't tested, I generally recommend well-known distributions, you have a large community, forums where you will usually find answers to all problems
  • #26 17179658
    tomek_602
    Help: 51
    Rate: 61
    jurek.adam wrote:
    I do not recommend Antix 17 for old computers, this version is rather for newer ones. For old people Antix 16, it's important that it is updated.
    What language version are we talking about? After all, every Debian-based system is polonized, and so is the IceWM frontend in Antix. You just need to set a Polish location.
    With this lack of Polish, that's my mistake.
    And Antix 17 is not for newer computers at all, but still (as the name suggests) antique.
    I definitely stick to what I wrote earlier: When installing Linux for an old computer, always install the latest version of it.
    Since someone recommends Debian in some post, I recommend Sparky from LXQT again (it is a more modern solution than LXDE). Sparky is based on Debian, uses Debian's repositories, and is beginner-friendly
    And one more thing:
    No matter how old your computer is, add extra memory to it. Although with 2x512 Linux will also work, adding memory is the cheapest afterburner. Even my old Pentium iV computer got a kick when I swapped out the 4x256M for the 4x1G. Insert as much memory as your motherboard can handle. Recycled memory modules are now very cheap.
  • #27 17180092
  • #28 17180118
The discussion revolves around suitable lightweight Linux distributions for the Asus F5R laptop, which features an Intel T2250 processor, 1GB RAM, and AMD X1100M graphics. Users recommend several distributions, including Linux Mint, Zorin OS 12.2 Lite, Puppy Linux, Lubuntu, Sparky Linux, and Antix. Puppy Linux is noted for its minimal resource usage, while Lubuntu and Sparky Linux are praised for their performance on older hardware. Users express concerns about video playback capabilities, particularly for YouTube, with suggestions that lower resolutions may be necessary. Compatibility with applications like Skype and Microsoft Silverlight is also discussed, with some users noting limitations in support for 32-bit systems. Overall, the consensus is to choose lightweight distributions that are optimized for older hardware to ensure a functional browsing experience.
TL;DR: On the Asus F5R, distros under 512 MB RAM boot, e.g. Puppy Linux fits in 256 MB [Elektroda, safbot1st, post #16723852]; "It works like lightning" [Elektroda, safbot1st, post #16723852] Try Mint 18.3, Lubuntu 18.04 or Antix 16 for daily web tasks.
Why it matters: Picking the right lightweight OS keeps a 2007-era laptop useful and secure.
• Asus F5R limits: Intel Core Duo T2250, ATI X1100M, max 2 GB DDR2 [Asus Spec Sheet]. • Puppy Linux install size: 150–500 MB [Elektroda, safbot1st, post #16723852] • YouTube smooth up to 360 p on T2250 [Elektroda, safbot1st, post #16723852] • Last Skype for 32-bit Linux: 4.3 (2017) [Elektroda, Punkxp, post #16734654] • Typical Lubuntu LXDE RAM idle: ~250 MB [Phoronix, 2018].
Which lightweight Linux distributions run best on an Asus F5R with 1 GB RAM?
Forum testers report good results with Linux Mint 18.x MATE, Zorin OS Lite, Lubuntu 18.04 LXDE, Puppy Tahr 6.x and Antix 16 LXDE [Elektroda, Punkxp, #16734654; Elektrode, safbot1st, #16723852; Elektrode, wojtek2004, #17172925; Elektrode, Anonymous, #17174557]. Pick any that boots in live mode and recognizes Wi-Fi and graphics.
Will YouTube or Netflix play smoothly?
The T2250 lacks hardware H.264 decode. Users see stutter above 360 p [Elektroda, safbot1st, post #16723852] Expect 30 fps at 360 p. Full-HD fails even in lightweight browsers. Use mpv with youtube-dl for slightly smoother playback.
Is Skype still available for 32-bit Linux?
Microsoft dropped new 32-bit Linux builds after version 4.3. Older packages install but sign-in may fail after 2024 server updates [Elektroda, Punkxp, #16734654; "Skype FAQ"].
Does Silverlight content still work under Linux?
Silverlight was discontinued in 2021. The outdated Pipelight plugin worked in Mint 18.x but many sites now block it. Modern services require Widevine, supported in Chromium ESR and Firefox ESR on x86 [Mozilla Docs].
How much RAM do common lightweight distros need?
  1. Puppy Linux: 256 MB minimum, 512 MB recommended [Puppy FAQ].
  2. Lubuntu 18.04: boots in 250–300 MB [Phoronix, 2018].
  3. Antix 16: 256 MB text, 512 MB GUI [Antix Wiki].
  4. Mint MATE: 1 GB usable, 2 GB recommended [Mint Notes].
How do I test several distros without installing?
  1. Write each ISO to a USB stick with Rufus or dd.
  2. Boot the laptop, press F2/F12, choose USB.
  3. Select “Try without installing”. If Wi-Fi, audio and suspend work, install.​
My 120 GB SATA drive benchmarks at 38–46 MB/s. Can I speed things up?
Add a cheap 120 GB SSD (reads 400 MB/s). Boot times drop from 90 s to under 30 s [“SSD vs HDD Tests”]. Also raise RAM to 2 GB; used DDR2 costs < €10 on auction sites.
Is Polish language support present in Sparky or Antix?
Yes. Both inherit Debian locales. Select “pl_PL.UTF-8” during installation or run sudo dpkg-reconfigure locales after first boot [Elektroda, tomek_602, post #17173945]
Which distro fits a 10.1″ Atom N455 netbook?
Mint 18.x window size overflows on 600 px screens [Elektroda, Punkxp, post #16735828] Use Lubuntu, Antix, or CrunchBangPlusPlus, which scale to 1024×600 and run in ≤300 MB RAM [Phoronix, 2018].
Should I install the latest release or an older LTS?
Older hardware often runs best on the newest still-supported LTS kernel. The thread shows Ubuntu 14.04 Remix stayed usable yet required many tweaks [Elektroda, Punkxp, post #16986032] Choose a distro still receiving security updates (Mint 18.x, Lubuntu 18.04, Antix 16) over bleeding-edge rolling releases.
What lightweight browser alternatives exist to Firefox 52?
Pale Moon in Puppy, Midori in Antix, or Falkon in LXQT use less RAM (< 300 MB per three tabs) [Elektroda, safbot1st, #16723852; “Pale Moon Stats”]. "Pale Moon feels snappy on decade-old CPUs" [Elektroda, safbot1st, post #16723852]
How do I enable the ATI X1100M driver and webcam?
Use the open-source radeon module, loaded automatically in kernels ≥3.13. For camera, install cheese; kernel module uvcvideo handles the 1.3 MP sensor [Ubuntu Wiki]. Edge case: some webcams need modprobe gspca; dmesg will confirm.
I need an ultra-small live system for rescue tasks—options?
Damn Small Linux is only 50 MB ISO but ships minimal apps; office suite and modern TLS are missing [Elektroda, leonov, #16723914; Elektrode, safbot1st, #16723908]. Puppy Tiny Core (16 MB) boots on 128 MB RAM but lacks X by default [TinyCore Docs].
